Hydraulic clutch bleeding - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Hydraulic clutch bleeding
Rough Country Lift Kits and Parts!Ruffstuff 10 year saleSmittybilt XRC M.O.D Bumper and Brush Guard
Unread 10-26-2001, 10:33 PM   #1
powjunkie
Anyone know if there's a way to bleed a hydraulic clutch on a 94'? I recently replaced the clutch with a centerforce and afterwards heard that they tend to put a little stress on the hydraulics. I've noticed it's a little sticky when shifting and was wondering if I had air in the line or if I needed to replace the cylinder.
94 YJ 4", SYE, 33 mud t's on MT classics; 4.10's with Detroit Truetrac in rear
powjunkie is offline   Reply With Quote Quick reply to this message
Unread 10-27-2001, 10:06 AM   #2
rev
The bleed screw is located on the top of the slave cylinder. If you don't know where the slave cylinder is its on the driver side of the transmission, just follow the line from the master cylinder. Hope this helps!
rev is offline   Reply With Quote Quick reply to this message
Unread 10-27-2001, 10:08 AM   #3
powjunkie
Thanks bro. The Chiltons manual said there's no bleeding point on a 94, I thought there must be but haven't spent much time lookin yet.
