Hurricane Sandy Damage - JeepForum.com
post #1 of 3 Old 04-09-2013, 12:25 PM Thread Starter
pschardien
We got hammered by Hurricane Sandy last fall. I changed the oil & filter removing about 2 gallons of water from the oil. I suspect I have water in the Automatic Transmission too. I read about changing the fluid by dropping the pan & changing the filter. I also read to pull the lines off the radiator to flush the torque converter. I don't think the water went down the carburetor but I'm not 100% sure. Is there anything else I should be looking at? Transfer case, front & rear differentials? Its been sitting since the storm;I did not try to start it after the storm (battery was dead anyhow). Because of the cold all I've done so far is drain & replace the oil & filter as well as hosed off the entire vehicle with clean water both inside & out. Any recommendations??
pschardien is offline
post #2 of 3 Old 04-09-2013, 12:35 PM
EABiker
Besides changing the fluids, it would be a good idea to disconnect, clean then re-connect the wiring harness connections. Hard to say if water could get into the converter, but if you find it in the rest of the trans, or in the engine I would assume so.
EABiker is offline
post #3 of 3 Old 04-10-2013, 02:39 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
DO NOT turn that engine over until you pull all the spark plugs!
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
carb , engine , fluid , transmission , water damage
