humming sound....help! - JeepForum.com
post #1 of 4 Old 09-06-2011, 10:28 PM Thread Starter
Phil6mac
The jeep is making a constant humming sound behind the driver side rear tire. Its like a constant "HMMMMMMMMMMMM". Any thoughts? Could this be my fuel pump or something else with the fuel system? Its definitely louder on the rear driver side corner than the passenger side. Help!
Phil6mac is offline
post #2 of 4 Old 09-06-2011, 11:51 PM
notmyj
Do you only hear it when moving? or when the engine is running? If when the engine is running its the fuel pump. This is normal if the tank is low on fuel as the pump its self is no longer submerged, even though the pump pickup is. If the tank is full, then its the pump making noise. I have had a pump make noise like that for years with never a problem. But I have had pumps fail within days of making noise. Some pumps dont make any noise when they fail....
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #3 of 4 Old 09-07-2011, 08:54 PM Thread Starter
Phil6mac
I can hear the sound while driving and while parked with the engine still running. I'm on the lower side of the tank for sure (probably 5 or 6 gallons left). I have noticed the sound for maybe a month or so now...I think I've noticed it because I just put my soft top back on so its a bit quieter in the cab now (quietness is relative). No other issues though....
Should I fill the tank all the way and see if I notice the sound still? Appreciate the feedback!
Phil6mac is offline
post #4 of 4 Old 09-08-2011, 09:48 AM
bigbossd1030
Yeah fill it and see, just remember if its your pump and you fill it and it craps out, you now have a full tank to deal with when you replace your pump.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
Humming sound in 4 high Soldierfoley YJ Wrangler Technical Forum 8 01-10-2011 10:15 AM
humming sound nicksbar YJ Wrangler Technical Forum 12 05-18-2008 02:22 PM
Weird Humming sound when engine turned off Jeep'nSon TJ Wrangler Technical Forum 7 06-07-2007 03:45 PM
Humming sound from rear end .. dspmans_04_X TJ Wrangler Technical Forum 3 06-27-2006 07:39 AM
Humming sound from under the hood??? 89JEEPNYC YJ Wrangler Technical Forum 0 03-22-2002 09:53 AM
