humming sound - JeepForum.com
post #1 of 13 Old 05-17-2008, 07:26 PM Thread Starter
nicksbar
humming sound
I just got my 4" rough country kit on my YJ. At the same time i had my diffs changed for a D30 and D35 with 4.10.
I now hear a humming noise when i have my foot on the accelerator.
Starts at about 10mph
When i let off the pedal the noise goes away
Ideas?
Thanks
Nick
nicksbar is offline
post #2 of 13 Old 05-17-2008, 07:35 PM
blue1989yj
blue1989yj's Avatar
Did you put new tires on with the lift?
Herculined, MC2100, Nuttered, 31" Mud Rovers
blue1989yj is offline
post #3 of 13 Old 05-17-2008, 07:37 PM Thread Starter
nicksbar
yup 33's...but as soon as i let off the gas pedal the noise stops.
So its not a hum from the tires
nicksbar is offline
post #4 of 13 Old 05-17-2008, 07:40 PM
blue1989yj
blue1989yj's Avatar
Sorry. Wasn't sure. I have MT's on mine and they start humming over 10 MPH.
post #5 of 13 Old 05-17-2008, 07:53 PM
jrollings
sounds like a problem on the drive side of the ring and pinion but not sure
1998 ZJ 4.0l, 231K, lifted 3.5" 31x10.5r15 Interco
Jason
jrollings is offline
post #6 of 13 Old 05-17-2008, 08:04 PM
ghost183
x2...
im assuming you checked the oil level in the rear?
but it could be the rear is "off shim",... if the rears were manipulated at all the backlash might be off, allowing the pinion to shift away from full contact on the ring gear, hence the humming when under power
is the pinion seal sweating/leaking?
ghost183 is offline
post #7 of 13 Old 05-17-2008, 08:34 PM Thread Starter
nicksbar
wouldn't the hum be constant if it was the bearing of diff?
the drive shaft is constantly turning
how would i check for proper shimming?
i did not install the diff, so i wouldn't know if the oil level is good
nicksbar is offline
post #8 of 13 Old 05-17-2008, 09:02 PM
ghost183
if it was a bearing ...yes,but im thinking its the shimming of the pinion.. maybe someone rebuilt the rear and didnt shim the pinion right,or assumed the shims he took out, would be the shims he put back.. not so.....
only under power is the pinion trying to rip away from the ring gear.. the driven force from the pinion against the ring gear is a twisting force due to the angle of the cut of the pinion gear, hence it trying to twist away from the ring gear under power, under de-acceleration or coasting, the effect would be reversed and the ring gear is trying to pull the pinion in close, again, due to the twist of the cut
as far as shimming, you need specified tools to set the backlash on the ring and pinion..
but... the FIRST thing you should do , is check the oil level!!
best way to do this is lift the rear of the jeep to get the pinion at a level angle, or close to it, then pop the plug off the diff cover, if oil comes out, youre good.. if not, fill till oil seeps out.. then quickly put the plug back
but im suprised you didnt check the oil level yet
ghost183 is offline
post #9 of 13 Old 05-17-2008, 09:36 PM Thread Starter
nicksbar
i also read that a bad fuel pump has the same symptoms
Also assuming it is the shimming of the pinion...can i drive like this?
nicksbar is offline
post #10 of 13 Old 05-17-2008, 10:32 PM
BamianYJ
All of the above very well could be right, but i know when i put on my 33's, i had a humming start but after a little wear it discontinued.
BamianYJ is offline
post #11 of 13 Old 05-18-2008, 06:27 AM
jrollings
i think i would take it back to whom ever performed your regear after you check the oil level.
Jason
post #12 of 13 Old 05-18-2008, 07:55 AM Thread Starter
nicksbar
it wasn't really a re-gear....it was remove my diff's and install diff's from a 4 cyl YJ
nicksbar is offline
post #13 of 13 Old 05-18-2008, 02:22 PM Thread Starter
nicksbar
could driveshaft angle cause this??
nicksbar is offline
random squeak/wierd humming sound eclipse27 TJ Wrangler Technical Forum 1 11-06-2008 07:21 PM
Weird Humming sound when engine turned off Jeep'nSon TJ Wrangler Technical Forum 7 06-07-2007 03:45 PM
front end humming brundz YJ Wrangler Technical Forum 3 10-02-2006 09:53 PM
Humming sound from rear end .. dspmans_04_X TJ Wrangler Technical Forum 3 06-27-2006 07:39 AM
Humming sound from under the hood??? 89JEEPNYC YJ Wrangler Technical Forum 0 03-22-2002 09:53 AM
