Humming sound in 4 high - JeepForum.com
post #1 of 9 Old 12-17-2010, 07:45 AM Thread Starter
Soldierfoley
We got our first real snowfall yesterday and I was deiving about 45mph in 4 hi when I noticed a slight humming noise in the front. When I shift back into 2 wd it goes away. Just wondering if this is normal or if I need to check the fluid levels and all that jazz. Any opinions would help.
Soldierfoley is offline
post #2 of 9 Old 01-10-2011, 07:02 AM Thread Starter
Soldierfoley
Cmon guys 33 people have read this and no one can say if their front end has a slight hum in 4 high? Help out a noob! I'll buy you a beer
post #3 of 9 Old 01-10-2011, 07:07 AM
YelloJeep
I am by no means an expert but this morning (snow) my Tacoma has a bit of a hum also. Haven't used the fwd Hi in my Jeep really. Only 4lo in the woods behind my house...
My guess is that it is normal. I could be wrong though. Just figured that if noone else was helping you out....
YelloJeep is offline
post #4 of 9 Old 01-10-2011, 07:33 AM
grandboost98
you probably need to get the front driveshaft balanced
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is online now
post #5 of 9 Old 01-10-2011, 07:40 AM
Mudmouse990
you should be fine fwd isnt really made for high speeds its ok on snow because it will slip but dry pavement is a no no haha i figured you knew that
90 yj 2.5l or pure power,thrush turbo, gutted cat, RC 4in lift,1" boom shackles, 33" BFG A/T's, outlaw alum rims,Rhino lined interior,overhead lights,connex 3300 cb, Homemade disco's, no rear trackbar
future mods- diamond plate rocker gaurds, fold down bus steps,home made front and rear bumpers , tube fenders, paint my doors red,possibly a winch, 302 ford or a 350 chevy, ford 8.8, cv style shaft and much more
Check out my build thread
My Home made Quick Disconnects Write up
Mudmouse990 is offline
post #6 of 9 Old 01-10-2011, 08:15 AM
WRMJeep
Clearly you are concerned about the sound. First thing I would do is check the front axle fluid level along with take a look at the front driveshaft. You may have the semi common issue of the front drive shaft rubbing against your exhaust downpipe / headpipe.
On mine the sound is more like a rusty grinding sound than a hum. But maybe once you get fast enough turns into a hum.
WRMJeep is offline
post #7 of 9 Old 01-10-2011, 09:31 AM Thread Starter
Soldierfoley
Thanks guys. @WRMjeep I don't hear any rusty sound, just a slight hum. Sounds a little like the blower motor but is coming from the front axle.
post #8 of 9 Old 01-10-2011, 09:38 AM
pasinbuy
I normally do not comment when someone states something that just makes me shake my head. But in this case I will break my silence.
" or if I need to check the fluid and all that jazz."
My opinion would be to go ahead and check the fluid.
pasinbuy is offline
post #9 of 9 Old 01-10-2011, 10:15 AM
jeepyj13
we got snow down in MS yesterday and i drove my yj in 4hi it had slight hum when i got to 45mph but i assume thats normal as long as the wheels are slipping cause the tcase is open with no center differential like awds. if your on dry pavement switch back to 2wd cause that can put wear on drivetrain and soon damage tcase. idk i could be wrong about the normal of humming but the rest is true for the tcase.
jeepyj13 is offline
high pitch humming noise nikesb4l YJ Wrangler Technical Forum 6 06-08-2009 03:14 PM
humming sound nicksbar YJ Wrangler Technical Forum 12 05-18-2008 02:22 PM
Weird Humming sound when engine turned off Jeep'nSon TJ Wrangler Technical Forum 7 06-07-2007 03:45 PM
Humming sound from rear end .. dspmans_04_X TJ Wrangler Technical Forum 3 06-27-2006 07:39 AM
Humming sound from under the hood??? 89JEEPNYC YJ Wrangler Technical Forum 0 03-22-2002 09:53 AM
