Hummer Snorkel?? - JeepForum.com
post #1 of 12 Old 03-12-2012, 06:46 PM Thread Starter
1murderedjeep
Hummer Snorkel??
Can I put a snorkel like this on the right side rather than the left? I want to put it a 90 in between the firewall and the cab. Thanks guys/gals it doesnt seem like it will be a problem just dont want to drill a hole and find there is no room for the pipe. http://www.jeepforum.com/forum/f12/h...y-pics-615089/
1murderedjeep is offline
post #2 of 12 Old 03-12-2012, 06:51 PM
idskot
I have seen them on the passenger's side as well as driver's. However, the one or two I've seen on the passenger's side were more in than the one that you posted.
EDIT:: You will have to go over the engine, and that will heat up the air more than the set up in the thread you posted... but it won't be too big of a deal.
idskot is offline
post #3 of 12 Old 03-12-2012, 07:42 PM
timatoe
timatoe's Avatar
Where are you going to put the battery?
timatoe is offline
post #4 of 12 Old 03-12-2012, 07:51 PM Thread Starter
1murderedjeep
There's enough room right above the battery. Just have to remove the air intake tube in order to remove the battery but that no biggy
post #5 of 12 Old 03-12-2012, 07:52 PM
NHfireLJ
NHfireLJ's Avatar
Sorry YJ = Driver side.
Here is my write up..
http://www.jeepforum.com/forum/f12/h...style-1257285/
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is online now
post #6 of 12 Old 03-12-2012, 07:58 PM Thread Starter
1murderedjeep
Looks good. Just have a lot of **** on that side, such as brake and clutch stuff. Do you know what's in the way on the pass. side. I guess I could just drill through the firewall and see.
post #7 of 12 Old 03-12-2012, 08:10 PM
NHfireLJ
NHfireLJ's Avatar
battery, glovebox, heating fan. There is some room but just crawl in your YJ and try to look up there. you cant...
Driver side, Tons of room!!!
The difference in mine vs the earlier thread is He relocated his fuse panel lower, (bad if in deep water) I reloacted the ecm higher .. Tons of room!! and the air box is right there too!
why the passenger side push? The ARB snorkles are driver side YJ...
SOLD
YJOTM FEB 2013
post #8 of 12 Old 03-12-2012, 08:15 PM Thread Starter
1murderedjeep
Haha yeah I looked at that, there not much room but I also have the brake booster on the drives side. I am screwed either way. Btw I'm runnin a cone and ditching the stock box. Thanks for all the help
Edit: seen how you went under the brake booster... I'm tired and looked right over that.
post #9 of 12 Old 03-13-2012, 06:26 AM
NHfireLJ
NHfireLJ's Avatar
Was just about to point that out, but see you caught that...
BTW, There is alot of wire harness to the ECM, and it can be relocated to the passenger side for mounting. (it's in someones write up). Even though it sealed, I liked installing mine off the radiator brace where its up Hi.
SOLD
YJOTM FEB 2013
post #10 of 12 Old 03-13-2012, 06:45 AM
grandboost98
go through any water crossings yet? did any water make it into the box? hows the computer holding up just hanging there?
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #11 of 12 Old 03-13-2012, 06:50 AM
NHfireLJ
NHfireLJ's Avatar
I've had water up to the headlight 1/2 way up, As deep as I want to go.
Airbox was fine and dry. My feet were a different story.
Computer is fine. Its well secured so it doesn't move around.
SOLD
YJOTM FEB 2013
post #12 of 12 Old 03-13-2012, 07:12 AM
grandboost98
good to hear, ive dunked my hood under water before with the stock setup and only had a little wet spot on the bottom of the box, filter was still dry. although it did alright, id rather not chance it again
Hummer Snorkel Complete Greg.Volkman TJ Wrangler Technical Forum 82 03-09-2011 03:03 PM
Hummer Snorkel Mod mgrammer Wrangler General Discussion 20 11-18-2008 09:45 PM
Hummer snorkel is in (Pics) cheesycook TJ Wrangler Technical Forum 32 05-08-2007 06:00 AM
Hummer Snorkel Jakemd98 TJ Wrangler Technical Forum 3 08-31-2006 06:20 AM
Hummer Snorkel JESSETHELJ TJ Wrangler Technical Forum 6 07-07-2006 09:01 AM
