hummer cold air intake on a YJ? - JeepForum.com
post #1 of 5 Old 10-25-2007, 09:32 AM Thread Starter
muddy93
1987 FSJ Wagoneer
after reading this writeup, http://www.jeepforum.com/forum/f27/write-up-hummer-cold-air-intake-326040/
I want to do something similar, but I've got a YJ, which means that I don't have a removable cowl, and will probably have to route the tube differently(most likely through the firewall, and up behind the dash).
so, has anyone done/seen the hummer style cold air intake on a YJ?
thanks,
muddy
muddy93 is offline
post #2 of 5 Old 10-25-2007, 12:12 PM
jeepwrnglr92
2015 JK Wrangler
ya I saw that post too and was very interested in this but never found anything for the YJ
2015 Jeep Wrangler JKU "Tank" Sport S
2002 Avalanche: To many mods to list
jeepwrnglr92 is offline
post #3 of 5 Old 05-12-2011, 07:32 PM
goAF
i am going to do this--and I am going to make it work. I will take pics. I am currently painting the hummer intake...
So, question--how much can I cut into the firewall? This may sound really stupid, but what if i made a quick-access hatch behind the battery? like, a hatch that literally has hinges and a latch of some sort? is that a bad idea? or just plain stupid?
i'm going to route a 3 inch tube from the front of the airbox, properly sealed to waterproof, around to the outside of the airbox (relocate horn) along the back of engine bay (firewall, zip tied) and punched through the firewall to the immediate right of the battery. I have to drill a 4 inch hole for the hummer intake, so i will actually be able to fit my hand in to fish the tubing through the cowling.
The biggest problem in my opinion will be making sure the intake is secure against branches, etc. i need to fashion some sort of collar that both conforms to the hood curvature (at least a little bit, i can use rubber shims and seal pads to even it out) and can properly retain the intake head. The intake head is a big piece of equipment--someone grabbing it hard or a branch smacking it with some leverage could be a problem if it is not strongly secured with a collar mounted to the body. On the TJ, this guy: http://www.jeepforum.com/forum/f27/w...intake-326040/ used a plumbing flange with 3 inch adapter, I could do the same if I could get it to bend and curve. (doubtful?) Also, it would be on the outside of the jeep body, not interior since I do not have access to the cowling...If anyone has any ideas on how I could accomplish this please let me know--in the meantime I'll be searching the net and fabricating some stuff in the shop.
Additionally, anyone know off the top of their head if they make 4inch to 3 inch tube adapters? I mean I'm sure they do...
EDIT* Or wait, on the guy above's write up--he uses spacers to level the flange--would spacers on TOP of the hood look awful? Could i feasibly tear into the firewall to install a flange from below? Would be a lot of carnage... No, shouldn't do that. Tap brakes.
If the curve isn't terrible, rubber spacers could work...
goAF is offline
post #4 of 5 Old 05-12-2011, 08:43 PM
NHfireLJ
NHfireLJ's Avatar
Dude,,,,Ritalin
BTW, read this if you haven't...
http://www.jeepforum.com/forum/f12/h...y-pics-615089/
YJ,, go driver side...
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #5 of 5 Old 05-12-2011, 09:19 PM
goAF
Ritalin for sure. Haha.
I like that write up, but he relocated a LOT of stuff, and he didnt solve the problem of making sure the air intake was sturdy and secure. I'm doing passenger side.
goAF is offline
K&N Cold Air Intake vs AEM Brute Force Intake... anyone help? TJoshX TJ Wrangler Technical Forum 25 06-25-2011 03:19 PM
Hummer "style" cold air intake question SwissK31 TJ Wrangler Technical Forum 10 12-02-2009 11:10 PM
Looking into a CAI/Hummer Intake KevinR TJ Wrangler Technical Forum 6 11-24-2009 04:19 PM
a different hummer intake question... yellowismellow TJ Wrangler Technical Forum 6 02-24-2007 08:52 AM
hummer intake yellowismellow TJ Wrangler Technical Forum 4 11-07-2006 08:30 PM
