Hub for a rear dana 60 - JeepForum.com
post #1 of 11 Old 10-04-2013, 07:27 PM Thread Starter
Wyogunman
My race keeps spinning in my hub. We tac welded in in last time and it worked for a while but has happened again. My problem is I cannot find a hub for a Dana 60 rear end. Plenty of front end hubs but nothing for the rear. Can anyone point me in the right direction? I would post a picture of the hub but the forum is not letting me
Wyogunman is offline
post #2 of 11 Old 10-04-2013, 07:52 PM
SeanB95YJ
sorry, have no clue on the D60 as I don't have one myself....
but re: pictures... I know as a "regular" member, you need like 50 posts or so before the forum software lets you attach pics... but with you being a supporting member (congrats btw for being such a new guy and coming up with support) I would've thought you could
anyway... if you have a pic of what you're talking about, email it to me and I'll post it for you... seanb.sti@gmail.com
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 11 Old 10-04-2013, 08:03 PM Thread Starter
Wyogunman
I just sent you an email. Thank you!
post #4 of 11 Old 10-04-2013, 08:16 PM
SeanB95YJ
okeedokee... originals are a little over 2MB... that's probably why they weren't posting for you. JPGs need to be under 560 or so, so I resized them
here you go:
swap/build thread:
post #5 of 11 Old 10-05-2013, 01:45 PM
jason m
Nothing but the facts
jason m's Avatar
What year and what make 60 rear? I junk 60 rears all the time, there not worth building IMO when a 14 bolt has all the beef. With that said a HD 60 will share the same hub as a 14 B and a dana 70.
So worst case if you cant find any 60's in the local junkyards, then take your races and go to the junkyard and start pulling 70/14 B hubs and try and match them up. But again your 60 needs to be a HD ( or a U ) model to match to the other axle's.
Get the pair, this way you have a spare.
One last thing don't paint a machined surface or a torque surface, like a hub face. The paint can ware off, then the torque spec on a bolt or a lug nut is lost causing the bolt or lug to loosen.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #6 of 11 Old 10-05-2013, 02:07 PM Thread Starter
Wyogunman
It's a 60 out if a 79 f250. I didn't paint the hubs, it just came that way. That's good to know so thank you. I'm not sure which one it is. Don't I have to take off the diff cover to find out?
post #7 of 11 Old 10-05-2013, 02:10 PM Thread Starter
Wyogunman
I am from Wyoming and for some reason we don't have the junk yards like the rest if the country. The only one I know of is 115 miles away. I've been trying to get ahold of them to see if they have one with no luck so far. It sure would help if you could help me with just a make and model. Thanks again for the help!
post #8 of 11 Old 10-05-2013, 04:44 PM
jason m
jason m's Avatar
78-79 Ford trucks normally don't run a HD rear 60. Look for a HD stamped on the housing chunk or large boar spindles. But every 78-79 I have pulled apart has been a small boar.
I have one under a truck, but its not slatted to be pulled till winter.
Jason.
jason m is offline
post #9 of 11 Old 10-08-2013, 12:10 AM Thread Starter
Wyogunman
Thanks everybody. Found a complete axle on Craigslist for $50.
post #10 of 11 Old 10-08-2013, 01:53 PM
JeepinJeremy
Jason.
Ford used the Dana 60 and Dana 60hd in the f250 and f350 from 1960 somthing thru 1980 something. It depended what was called for on the build sheet all the hubs were the same. spindles are all the same 2", spline count was either 16 or 30 axle width varried from 63"-69". Ford did not use larger 60 spindles unit mid 80's and they switched to a 32 spline at the same time. That being said sorry i missed your post i have a few axles laying around but probebly would of cost a ton in shipping for those heavy hubs. 50.00 buck is a good deal.
JeepinJeremy is offline
post #11 of 11 Old 10-08-2013, 07:01 PM
jason m
jason m's Avatar
That's why I said the 78-79 Fords "NORMALLY" don't run one and also said every one "I" pulled apart did not have one.
That's does not mean Ford in those years never ran one or did I imply that. I was just saying out of the 20-25 78-79 fronts ive pulled over the last 13 years all where small boar NON HD.
Jason.
jason m is offline
