hrmm 15gal tank to a 20 gallon tank?? - JeepForum.com
post #1 of 5 Old 10-20-2001, 09:40 PM Thread Starter
evilpsych
evilpsych's Avatar
umm is this website correct??Getting the Extra Value Without Paying the Extra Price.
if so.. it's the next mod i'm doin to MY jeep..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 5 Old 10-20-2001, 10:01 PM
bob91yj
That's for real.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline
post #3 of 5 Old 10-21-2001, 03:38 PM
Pantera
I actually got more than 20 gallons on my tank with that method...
Eddie H.
91 YJ 4-Banger
Omaha, NE
Pantera is offline
post #4 of 5 Old 10-28-2001, 04:55 PM
Scott Rice
Can you belive that they would build a large 4 cyl and then resrtict the air to it to lower the hp?? Well, then you can belive that they would build a 20 gallon tank and purchase and insert an extra part to reduce its capacity!! Only in America!! The procedure is actually easier than it sounds, just make sure you add WD-40 or other lubrican while pulling the tube!! And use a powerfull flashlight so you can see what you're doing!! Good luck, now you'll have 400 miles to a tank.
Scott Rice
1991 Jeep Wrangler S
2002 Land Rover Discovery SD
Scott Rice is offline
post #5 of 5 Old 10-29-2001, 06:15 PM
osburn
osburn's Avatar
That doesn't suck at all for you the way I see it. What sucks is I paid for the 20 gallon tank when I bought the Jeep.
Matt Osburn
Score 1032
osburn is offline
Has anyone done the 15 gallon to 20 gallon gas tank mod? by modifing gas vent line? tybmw YJ Wrangler Technical Forum 27 05-15-2012 09:15 PM
factory 15 gallon vs. 20 gallon fuel tank?? trickle26 YJ Wrangler Technical Forum 19 06-13-2010 05:19 PM
Anyone ever heard of a 6cyl Wrangler W 15gal tank? Methlab TJ Wrangler Technical Forum 11 09-08-2009 06:19 PM
88 15gal to 89 20 gal tank Futaba YJ Wrangler Technical Forum 6 10-30-2008 03:08 PM
When was switch from 15gal to 19gal gas tank made rholmes69 TJ Wrangler Technical Forum 6 08-26-2004 02:48 PM
