Hp dana 30 vaccume acuator seal? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Hp dana 30 vaccume acuator seal?
Year End Clearance Sale! Save 20%Savvy FREE SHIPPING!Artec Holiday Sale!
Unread 12-18-2014, 10:44 AM   #1
Bighaydn
Hello, I'm leaking oil outta my axle on the passenger side right near the knuckle. It's gear oil and I've located it to the seal at my vaccume acuator. Anyone know what this seal is called? And the best way to replace it?
Bighaydn is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 10:52 AM   #2
fishadventure
Technically it is the "CAD" - center axle disconnect. Black rtv is what I have used though.
How many old threads actually convince *you* to read all 36 pages? http://www.jeepforum.com/forum/f12/length-envy-build-thread-629700/
fishadventure is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 10:55 AM   #3
Randonexplosion
Trailer Queen
Randonexplosion's Avatar
Looks like #21 http://www.jeep4x4center.com/jeep-ax...rangler-yj.htm
Here is the first thread that came up in a search http://www.jeepforum.com/forum/f12/d...ement-1108000/
5.3/4l60e swap
August YJOTM
Exiled Offroad - Colorado
Randonexplosion is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 02:20 PM   #4
Bighaydn
I don't think we are talkin about the same seal. The axle shaft goes through this seal
Unread 12-18-2014, 02:30 PM   #5
StanF
That seal is somewhat tricky to install. I have replaced that seal, but destroyed another one in the process. Buy two, and return the extra if you don't need it.
I used a long piece of 3/4" all thread with large washers to pull in the seal. Do some searching on the technique - there are several threads on it. It's a 2-man job. One at the CAD, and the other to turn the nut to pull the seal in. I just installed my seal flush with the tube end. I didn't try to seat it fully against the step in the tube. You'll need a perfectly sized washer or socket to fit into the tube, as the seal surface isn't very wide. Or others have ground down a washer for a perfect fit in the tube.
Also, you might want to replace the driver's side carrier seal at the same time. If one went bad, the other probably won't be far behind. You will have to remove the carrier to replace that seal.
I've since gone to a one-piece shaft, which moves the seal to the carrier. It's a great upgrade, and would be a good time for you to do it.
Again, there are a ton of threads on this topic, so do some research before starting.
My Ammo Can Console: http://www.jeepforum.com/forum/f12/yet-another-ammo-can-project-finished-1498520/
My 8.8 Swap: http://www.jeepforum.com/forum/f12/yet-another-ford-8-8-swap-extras-1565339/
StanF is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 03:21 PM   #6
Bighaydn
Originally Posted by StanF
That seal is somewhat tricky to install. I have replaced that seal, but destroyed another one in the process. Buy two, and return the extra if you don't need it. I used a long piece of 3/4" all thread with large washers to pull in the seal. Do some searching on the technique - there are several threads on it. It's a 2-man job. One at the CAD, and the other to turn the nut to pull the seal in. I just installed my seal flush with the tube end. I didn't try to seat it fully against the step in the tube. You'll need a perfectly sized washer or socket to fit into the tube, as the seal surface isn't very wide. Or others have ground down a washer for a perfect fit in the tube. Also, you might want to replace the driver's side carrier seal at the same time. If one went bad, the other probably won't be far behind. You will have to remove the carrier to replace that seal. I've since gone to a one-piece shaft, which moves the seal to the carrier. It's a great upgrade, and would be a good time for you to do it. Again, there are a ton of threads on this topic, so do some research before starting.
I've have done research. Is this seal just called an axle shaft seal?
Unread 12-18-2014, 04:40 PM   #7
Partsmke
1987 YJ Wrangler
If you want to beef up your 30 and stop the oil leaks and other vacuum operated issues. Buy a set of one piece axles from a wrecking yard or new. They have larger ujoints and seal much easier. It requires a new seal in the axle housing on the right hand side of the carrier, the axle are found in TJ's and many other Jeep vehicles that came original manufacture non-vacuum operated. Yes the axles turn all the time, not much of an issue, if you want strength and reliability.
Stock Spicer axle part numbers 75814-2X Right (passenger side) and 75814-1X Left (drivers side)
Partsmke is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 09:15 PM   #8
Bighaydn
I didn't my vaccume acuator awhile ago for a cable lock system and it seems to hold up nice, I think I'd swap it out with a 44 before I'd beef it up. Yeah it's a darn good little axle to and goes awesome with an 8.8 but I've been itching for full widths for awhile now
Unread 12-18-2014, 09:22 PM   #9
uhohthe50
Yes, that is the axle shaft seal like other said It can be tricky to install
My 1990 YJ Build Thread: http://www.jeepforum.com/forum/f22/might-well-start-build-thread-now-my-1990-yj-1291174/
uhohthe50 is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 09:23 PM   #10
uhohthe50
And if you went to a one piece Tj shaft you would most likely have to get your front ds balanced
