hp d30 steering stabilizer - JeepForum.com
post #1 of 8 Old 01-09-2008, 07:50 PM Thread Starter
bigstinger
bigstinger's Avatar
So uh... I have a d30 that I picked up from a guy. I believe he said it came out of a cherokee and I'm pretty sure it is high pinion. I have not yet gone hi-steer steering. I do have wobble at 70 mph - I always figured it was a jeep thing but I don't know, maybe I have bad ball joints. I did just replace the unit bearing on the driver side. But to the point...
I don't have a steering stabilizer. The tie rod has a hole in the middle for a steering stabilizer. I was thinking about welding a bolt onto the axle to hold the other end of the steering stabilizer but that has got to be a lot of pressure at that point. I think I can burn it on there, but not for sure.
the only hole on the axle is for the trackbar.
Google showed me lots of TJ's with the steering stabilizer on the drag link but my drag link is a new one that I put on there and it was made for a YJ so no stabilizer bolt hole.
Any advice or pics would be very much appreciated.
4.0L Ford 8.8 4.56 lsd D30 SOA, 4.56 BFG 35 X 12.50 AT's
Ebay Bushwacker knock-off TJ flares - tuffy security console.
Stainless steel braided brake lines skyjacker pitman arm skyjacker hydros
Buy my unit bearings!
bigstinger is offline
post #2 of 8 Old 01-10-2008, 11:06 AM Thread Starter
bigstinger
bigstinger's Avatar
just a bump for a lil help
post #3 of 8 Old 01-10-2008, 11:21 AM
bob082484
A new steering stabilizer should come with a new bolt that presses in the tie rod. As far as the bolt for the other side, start cruisin junk yards or try the hardware store.
bob082484 is offline
post #4 of 8 Old 01-10-2008, 12:17 PM
northjeep
Jeep parking ONLY
northjeep's Avatar
make a bracket that is held on with u-bolts for the axle end.
-NorthJeep - >> Just Enough Essential Parts
northjeep is offline
post #5 of 8 Old 01-10-2008, 02:10 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Someone's got to ask. You can get up to 70 MPH? I wouldn't know if I had a wobble at 70 MPH, I've never been there. Also it would be helpful if you filled out your Jeep profile.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #6 of 8 Old 01-10-2008, 02:34 PM
crb577
my trailmaster SSV stabilizer that I bought about 2 weeks ago came with a new bolt for that exact hole you are talking about no need to weld one
1993 Jeep Wrangler
4.0L Tom Woods rear HD shaft
D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,SOA xj rear 100" wheelbase, homemade greasable boomerang shackles, SS braided lines, 1" prothane body lift, 35" TrXus M/T, smitty built XRC.
lots of gen right armor and rear stinger.
crb577 is offline
post #7 of 8 Old 01-10-2008, 02:51 PM
Michael_94YJ
under the track bar bracket (or either the passenger side spring perch) should be a threaded hole for the other side of your steering stabalizer. I have a factory steering stabalizer i'll sell ya for $12 shipped if you want it. Nothing wrong with it. But to be honsest, a lack of steering stabalizer shouldn't be a problem. I'm inclined to say that you have caster, TRE, or some other type of problem that attributes to your wobble. I have no issue cruising 70mph in my jeep and i'm spring over. In fact, my jeep drives 10 times better now, than it ever has. If you want the ss then let me know.
-Michael
1994 YJ 4.0L 5 spd.
flowmaster,15x12 wheels & 35x15 TSLs, sway bar discos, 3.5" leaves SOA + shackles, 2" body lift, JB steering bracket, SYE, M.O.R.E. anti-wrap bar, Bilsteins 5125s up front & BDS Hydros out back, axles in the works
Michael_94YJ is offline
post #8 of 8 Old 01-10-2008, 07:53 PM Thread Starter
bigstinger
bigstinger's Avatar
Lots of thanks for the offer of the SS. I happen to have one. I have the bolt that goes into the tie rod as well. I just don't have a threaded hold for the other side of the steering stabilizer. so I can bolt it to the tie rod but don't have anything to bolt it to on the other side.
Yep, I can do well over 80. Not a great idea but you do what you have to do on I95 between here and Northern VA.
The wobble only happens between 70 & 75. If I take it up to 80 then no wobble.
Caster is definitely off. The knuckles were not rotated to compensate. The steering wheel doesn't want to readily return to straight after turning. But would that matter from 70 to 75 and not more?
I have actually put my head out the window.... don't ask... at that speed and saw the front wheels bouncing...don't try this at home kids, stay in school, don't do drugs.
My jeep does drive better after going SOA, new shocks, etc.
Not sure how to diagnose a bad TRE....Any tips on that?
I don't know for sure but the balljoints look good...
Steering stabilizer t-bird TJ Wrangler Technical Forum 18 05-09-2010 04:53 PM
Question about Steering Stabilizer after HD steering install. Hellbound13 JK Wrangler Technical Forum 2 07-14-2009 09:29 PM
Rock Krawler HD steering + steering stabilizer Giviner TJ Wrangler Technical Forum 1 05-03-2008 07:19 PM
Steering stabilizer attachment to steering link Bill87GT TJ Wrangler Technical Forum 8 09-08-2007 08:59 PM
I need help again (steering stabilizer) Tango TJ Wrangler Technical Forum 7 10-22-2002 09:56 AM
