Howell VSS Adapter - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Howell VSS Adapter
Rough Country Jeep Suspension Deals at Rockridge 4WD!JEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFThe ULTIMATE "Selectable" Locker System! Brough
Unread 03-24-2014, 04:00 PM   #1
timatoe
timatoe's Avatar
Howell VSS Adapter
Quick question...... anyone find a replacement other than through Howell for the VSS? OR,,,,, anyone who built there own TBI system find one?
The Howell part number is VSS263, but I'm finding it difficult to drop $110 for a new one. The input shaft snapped off mine, in the speedo gear, so I need a new gear as well.
timatoe is offline   Reply With Quote Quick reply to this message
Unread 03-24-2014, 04:09 PM   #2
Berniebikes
yep, put in my own TBI system. Used the one from Jags That Run, Item 1 shown on this page
http://www.jagsthatrun.com/Pages/Spe...eedometer.html
If I recall it was about $70 and hooked right up to the speedometer cable and transfer case. One wire goes to the correct ECM pin, the other to ground. Works perfect!
Berniebikes is offline   Reply With Quote Quick reply to this message
Unread 03-24-2014, 04:12 PM   #3
JeepinJeremy
http://www.dakotadigital.com/index.c...rod/prd109.htm
JeepinJeremy is offline   Reply With Quote Quick reply to this message
Unread 03-24-2014, 05:17 PM   #4
timatoe
timatoe's Avatar
Jeremy, did you use one of these? Just wonder cause the other sites show them at 2K pulses per mile, and the Dakota ones say 8K, I'd love to use one of those though if I can since they're half the price.
If not, I'll order the one Bernie posted. It's $25 cheaper than through Howell.
Unread 03-24-2014, 05:24 PM   #5
JeepinJeremy
they have what you need just give them a call.
Unread 03-24-2014, 05:27 PM   #6
timatoe
timatoe's Avatar
OK thanks.
Unread 03-25-2014, 12:34 AM   #7
Michaelgoesrawr
Michaelgoesrawr's Avatar
This. Howell buys them from jags that run, per the guy on the phone. Doesn't matter how it's hooked up. Only two wires. Lol.
Michaelgoesrawr is offline   Reply With Quote Quick reply to this message
Unread 03-25-2014, 08:27 AM   #8
Que89YJ
231 tcase? Try calling Cris:
http://www.cfoffroad.com/
He will have one at a much cheaper price
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 03-27-2014, 12:05 AM   #9
timatoe
timatoe's Avatar
Sorry Que just saw this. You think he'll have that VSS from the Howell system?
I'll try and give him a call tomorrow.
Unread 03-27-2014, 06:50 AM   #10
Que89YJ
He will have a VSS and it shouldnt matter.
Unread 03-27-2014, 08:12 PM   #11
nagel
Can't you use one from a '91 wrangler? Both mechanical and electrical.. Or is there something I'm missing here???
nagel is offline   Reply With Quote Quick reply to this message
Unread 03-27-2014, 08:19 PM   #12
timatoe
timatoe's Avatar
Don't know. I don't know how many pulses the cpu for the howell needs to see etc. Dakota Digital told me they have one that's 8k but the JTR site shows one identical to the one from Howell and they say it's a 2k. I just don't know, kinda funny though because I've obviously been running without one since Sept of last year when the speedo quit working. I just pulled it apart this week to see what was up with it.
Assuming you mean is shouldn't matter, as in one from a '91, like nagel was saying?
Unread 03-27-2014, 09:08 PM   #13
Berniebikes
timatoe, you need a VSS that is 2k pulses per mile. Here is a thread over on the Binder Planet Site that offers some alternatives to the JTR VSS. Sounds like most any will give a signal to your ecm and turn the light off. Getting an accurate speed indication and hence proper fuel regulation is something else, but Bill USN offers up some ways to do that
http://www.binderplanet.com/forums/s...ad.php?t=50649
Unread 03-28-2014, 10:05 AM   #14
Michaelgoesrawr
The guy at JTR didn't seem to think the VSS was important. Mine went belly up and it caused my speedo to bounce around something fierce and when I called and explained it I brought up not wanting to drive it. He said it doesn't really do anything.
Unread 03-28-2014, 10:46 AM   #15
Que89YJ
The vss is used for calculating engine loading by the ecu. When you are coming to a stop it will look at the vss and hold idle high to compensate for the alternator load.
