Howell Help - JeepForum.com
post #1 of 12 Old 09-09-2011, 10:58 AM Thread Starter
Double_DD-s
Howell Help
I got back on the TBI - HEI install yesterday. I finished up and went to fire it up ... nothing just crank....
I started on trouble shooting this morning. It has spark, has tach, check engine light is on and stays on thru crank. Figured out that i wasn't getting gas.
I called Howell, he had me check this and that. I finally figured out that i had my fuel line / return lines switched. I hook up the pump to the correct line and left the return line dangling. Fire it up... starts right away, and idles half-way decent. About then i realize my garage floor is covered with gas. Didn't realize the return line,returned that much gas.... doh!!!!
I turn off it off. I ran hoses and got the lines all hooked up the way that they are supposed to be. Went to fire it up again... nothing... just crank, but this time I am getting fuel. I called Howell back, he said try to floor it, this will cut off all fuel, since maybe its flooded. Well it didnt cut off all fuel but it did sputter to a start, but just dies when I let off gas.
I am frustrated and don't know what I am missing.
Double_DD-s is offline
post #2 of 12 Old 09-09-2011, 11:10 AM
jbolty
jbolty's Avatar
Flooring it while cranking is the clear flood mode.
Is the pump priming then stopping when you first turn on the key?
When I first installed mine it was running pretty rich and that turned out to be a bad MAP sensor. I would start with looking for codes if you can get an OBD 1 scanner, or do it with the blinking light method. It will show up as a 1987 Chevy light truck on the scanner so you can get more info about the codes form a chevy forum.
Howell support is very good but it works best if you do the basic tests before calling.
jbolty is offline
post #3 of 12 Old 09-09-2011, 11:20 AM Thread Starter
Double_DD-s
When I floored it while cranking (while on the phone w/ Howell) it just poured tons of gas in. The guy at Howell said it should stop all gas when floored. Said my throttle needs to be adjusted.
When I turn on the key, the pump primes for a second or two. When I crank it, it spits gas in the TBI as it should.
What I get is, it fired up correctly the first time. Then when I put the hoses back, it doesn't want to fire up. I tried to re-create the scenario (with the return hose going into a gas can this time) still nothing.
post #4 of 12 Old 09-09-2011, 11:28 AM
89yjparrothead
If it's flooded then try disconnecting the injectors on top of the throttle body. Crank it over and then when it starts, run back and hook up the injectors. You have to be pretty quick with this but it will at least allow you to clear it till you can get your problem solved. Good Luck!
Everything in moderation, including moderation.
89yjparrothead is offline
post #5 of 12 Old 09-09-2011, 11:48 AM
jbolty
jbolty's Avatar
or, disco the fuel pump until the flood clears
jbolty is offline
post #6 of 12 Old 09-09-2011, 12:02 PM Thread Starter
Double_DD-s
the only time it wants to start, is when i am giving it maximum gas. Then when it sputters to a "start", when i let off the gas, it dies.
post #7 of 12 Old 09-13-2011, 02:33 PM Thread Starter
Double_DD-s
OK, I got it up and going. It looks like I had turned the dizzy too much on install.
One thing, I got it up and idling good. right at about 800 rpm. I got excited and took it for a test drive around the block. It sputters until I get to about 2000 rpms and then smooth acceleration.
Ideas?
Why nothing from 1000-2000 rpms?
Is this a timing issue?
post #8 of 12 Old 09-13-2011, 06:41 PM
timatoe
timatoe's Avatar
What do you have it timed at now?
timatoe is online now
post #9 of 12 Old 09-13-2011, 08:27 PM Thread Starter
Double_DD-s
I am going with the assumption that each hash mark is 2 degrees BTDC. So it's at idle at about 8 BTDC (4 hash marks). At 1600 rpm its at about 16 BTDC. It idles good right now and picks up rpms good (in the garage). All of these are taken with the vac advance off.
So I will test it again on the road, in the morning.
Those measurement about where it should be??? I know you are at 12 and others are around 8.
post #10 of 12 Old 09-14-2011, 12:52 PM
timatoe
timatoe's Avatar
Also make sure you're connections at the HEI are good, especially if you didn't use a plug and used spade connectors there. Ooy, I chased a problem there literally for weeks.
Also you're setting your timing at curb idle right, right around six to seven hundred rpm? I only ask cause some have set their initial timing at like 1200 rpm. I don't know where mine is other than at idle really.
post #11 of 12 Old 09-14-2011, 04:28 PM Thread Starter
Double_DD-s
Does Port "J" on the TBI get plugged? If not where does a vacuum from J go to???
By the way, I passed smog today, even though it runs like crap.
And now my Jeep wont fire up again.
post #12 of 12 Old 09-14-2011, 10:09 PM
timatoe
timatoe's Avatar
One of them gets plugged, but I don't remember. I can get out and take a look at mine tomorrow and snap a couple of pics or something.
Howell TBI? Puinsai YJ Wrangler Technical Forum 21 02-02-2011 07:34 PM
Howell TBI LoggingRoads YJ Wrangler Technical Forum 4 10-01-2010 07:39 AM
Need some help with Howell TBI JJ-4 YJ Wrangler Technical Forum 4 01-02-2009 05:03 PM
Howell TBI ? timatoe YJ Wrangler Technical Forum 5 12-18-2008 05:40 PM
Howell TBI Nebfarmer YJ Wrangler Technical Forum 3 09-08-2006 01:31 AM
