Howell FI Air Filter - JeepForum.com
post #1 of 8 Old 02-09-2013, 12:23 PM Thread Starter
SLCSmoker
So the Howell kit is on and running like a champ, whats the best air filter setup to go on top? I see the instructions tell you to go buy a K&N and give you the part # but I don't see how that's going to clear the brake booster... anyone got experience here? (I did a search.. nothing conclusive). Thanks!
SLCSmoker is offline
post #2 of 8 Old 02-09-2013, 04:23 PM
NonRubicon
The main thing to keep in mind is that the neck of the Howell throttle body is 5-1/8" (5.125"). This is the same size as many carbs, so you can go from there and customize your filter setup to your desire using whatever size/shape carb style filter you like. The larger you can go on filter size, the greater the filter area, and thus the longer your filter will last without needing to swap in a new one. If you go off road, you might want to avoid the K&N style washable filters. They let a lot of small dust particles through.
I just picked up a round, generic carb air filter right off the shelf from my local parts store. Just been using regular STP brand filters for it. I think mine is about 11" diameter and easily clears the brake booster. I needed a neck spacer to better clear the electrical connectors on the throttle body.
Another option is to use a plenum type setup which would allow you to position the actual air filter in a location other than directly over the throttle body, let's the engine get cooler air if you position it right, and you can better protect it from water. A little more pricey than the carb style filters though.
NonRubicon is offline
post #3 of 8 Old 02-09-2013, 07:05 PM
jay-h
I went to pep boys and got one of these. Clears everything with no issues. The Jeep will only pull so much air, the filter is the least of your restrictions.
http://www.jegs.com/i/Edelbrock/350/...FUWo4AodsQgADw
I have read (even on JF as I remember) some tests which suggest than K&N reusable element gains flow at the cost of reduced effectiveness in filtration. You may want to google some test results before deciding.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #4 of 8 Old 02-09-2013, 07:14 PM
timatoe
timatoe's Avatar
I use this one too, well the chrome version cause it's like $14 at Napa.
timatoe is offline
post #5 of 8 Old 02-09-2013, 07:40 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Mine is just the stock box with an extension. Works fine.
Michaelgoesrawr is offline
post #6 of 8 Old 02-10-2013, 09:24 AM Thread Starter
SLCSmoker
Thanks guys, I went with the Edelbrock too after following the link. Fits great, looks great! Man this Howell FI turns it into a different Jeep completely.
post #7 of 8 Old 02-10-2013, 09:38 AM
jay-h
I did mine last summer and was well pleased with the results. Howell was helpful especially when I had some issue due to the Duraspark pickup.
The one quibble is they could stand to reorganize the installation manual. All the information is there, but it's not all easy to find.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #8 of 8 Old 02-10-2013, 12:20 PM
jbolty
jbolty's Avatar
I just went with a stock filter housing from a 4.3, as I recall it was an astro van. The filters are cheap and I change it about every other trip to the desert; the dust out there is like baby powder.
jbolty is offline
