-   -   How would you get these bolts off (PICS) (http://www.jeepforum.com/forum/f12/how-would-you-get-these-bolts-off-pics-1543332/)
Wookiekrisps 06-30-2013 07:30 PM
In the process of doing a Monstaliner installation on the jeep tub. Want to come all the way out on the lip but cant get these two bolts off.
How would you go about getting these off. They are striped out, and torx bits are even worse when they are striped
http://i1165.photobucket.com/albums/...ps000e4cf5.jpg
http://i1165.photobucket.com/albums/...ps6035972b.jpg
http://i1165.photobucket.com/albums/...ps82c3f1e4.jpg
rshbutch 06-30-2013 07:34 PM
You could weld a nut on top,or just grind them down,or drill them out
p2555016zr 06-30-2013 07:36 PM
I would grab that head sideways with a set of curved jaw vice grips or grind that head off and the bottom will fall out. I'm assuming that torx head is stripped out and you will be replacing that hardware.
Reno72 06-30-2013 07:38 PM
PB blast them, cut a groove with dremel or cutting wheel and try a big screw driver, or square off two sides and use vise grips, or square off eight sides and use socket.
Louie4 06-30-2013 07:46 PM
I have taken my angle grinder and grinded flat spots on either side of the bolt head. Then I took vise grips and got it to turn.
Anticanman 06-30-2013 08:04 PM
http://i899.photobucket.com/albums/a...05337961AB.jpg
OldSkull75 06-30-2013 08:41 PM
Square the head off and use a wrench
jbolty 06-30-2013 09:41 PM
drill them out, or right angle grinder the heads off. You will not be reusing the bolts or nuts.
dillonjm 06-30-2013 10:20 PM
This.
I'd just cut the heads off and let the bolt fall. Then get some new hardware and call it a day.
VenomousMaximus 06-30-2013 11:50 PM
Originally Posted by dillonjm (Post 15626843)
This.
Im pretty sure the bolt will not just fall through if you grind / drill the head of the bolt off, would still need to remove the threaded part of the bolt... I would do like others have suggested, soak the hell out of them with deep creep or on blaster over night & cut flat spots with grinder and remove with wrench or cut a slot and remove with large flat blade screw driver and/or use the impact driver the one you hit with hammer and it turns, if you do not have one they sell them at harbor freight for like $5-$8
VenomousMaximus 06-30-2013 11:58 PM
You can also take a very Sharp punch and try to turn the bolt by hitting with a hammer..if anything...at least to shock the bolt so the lubricant seeps even deeper into threads... Just tapping a bolt firmly with a hammer tends to break rust free into the threads allowing the lubricant to penetrate deeply.
Feetwet 07-01-2013 05:16 AM
Those bolts hold the soft top belt rail in place. They are only threaded into the square nuts under the lip, not into the tub in any way.
Grind off the head and they will drop. Rinse, repeat.
Rproject 07-01-2013 06:47 AM
Either grind off the head or cut a slot with a Dremel tool and remove. The Dremel solution is quicker.
Wookiekrisps 07-01-2013 09:44 AM
thanks for the help yall.
everyone has amazing ideas
I was planning on grinding the heads off, but cutting holes and cutting sides off so I can wrench them off is genius.
Thanks for the help again!
Back to the grind!
Siva283 07-01-2013 11:57 AM
I cut a pie slice out of mine and used an air chisel. Worked like a charm even breaks loctite loose.
The time now is 04:01 PM.
