How would I fix this? - JeepForum.com
post #1 of 6 Old 06-12-2013, 10:23 AM Thread Starter
NiGhtt
The bolt that connects to exhausy manifold is either broken or completely missing. It creates a chugging noise as a result of the leak. How can I fix it?
"Two working hands accomplishes much more than a thousand hands clasped in prayer"
NiGhtt is offline
post #2 of 6 Old 06-12-2013, 10:25 AM
superj
put a new bolt in or if its broken off, ez-out to get the left over piece and put a new bolt in.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 6 Old 06-12-2013, 10:27 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
1)put a new bolt in.
2) remove exhaust manifold, drill and use an easy out to remove. Then put a new bolt in.
3) remove exhaust manifold, drill, re tap, Then put a new bolt in.
*I suggest using a new manifold gasket, your old one is most likely burned up.
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #4 of 6 Old 06-12-2013, 10:27 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
dang it you beat me to it.
March 2017 YJOTM
87TPIYJ is offline
post #5 of 6 Old 06-12-2013, 10:41 AM
firefighter315
One of the very first things I dealt with after joining here...
http://www.jeepforum.com/forum/f12/9...g-stud-580709/
My YJ Build Thread
firefighter315 is offline
post #6 of 6 Old 06-12-2013, 04:13 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Just sayin'
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
