How will my jeep look with xx" tires on x.x" of lift? - Page 95 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > How will my jeep look with xx" tires on x.x" of lift?
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-24-2008, 01:05 PM   #1411
ss454
Thanks, didn't like the bumper at first. It's starting to grow on me.
ss454 is offline   Reply With Quote
Unread 09-28-2008, 07:46 PM   #1412
letitloose06
1992 ISlander
33x12.50-15 Maxxis Bighorns
15x8 US Wheel Daytonas
4" RE Standard Lift
letitloose06 is offline   Reply With Quote
Unread 09-28-2008, 08:36 PM   #1413
+Crusader+
Originally Posted by justanotherhemi View Post
^^^^^Great looking Jeep my friend.
Thanks man ... glad you like it!.
Originally Posted by flowrida2480 View Post
joedaddy sweet jeep couple of q's though. how do you like that lift? how does it ride on/offroad? did you have to do sye or just transfercase drop kit?
I like the lift mucho ... but this is a Black Diamond lift back when Warn was making it, so there are some differences I believe?
As far as ride quality, its a Jeep, but I consider it to ride well, and I'm more the Musclecar/Sportscar type, so it depends what your definition of "good" is? I did "rebuild" my leaf packs by tearing them down, sanding the rust, and lubing the friction surfaces with marine grade grease to allow the leafs to do their thing with minimal friction, seems to help the ride of a YJ some, and fights rust.
I tow 2-3K lbs from time to time, and the springs are stiff enough to handle the load without much sag. I ditched the track bars and it does very well offroad, but there are more flexible lifts available (softer, cheap springs), but it flexes well and the springs are stiff enough to keep wheel hop to a minimum. What I really need though are M.O.R.E. greaseable boomerangs to get the full meal deal. Coming soon ... (Update: I got some, will post pics later.) The lift has 5-leafs in the rear with pinion angle shims, 4-leafs up front. The lift came with the transfer drop kit to lower the skidplate an inch or so, and it does not require a SYE or driveshaft, although I do plan on that in the future to increase belly clearance and yada yada yada (Update: I got that too, will have to post pics.) Do keep in mind my Jeep is a '93 so it has the smaller U-Joint due to smaller/shorter D35 pinion yoke. The driveshaft does not slide as far onto the transfer case output shaft as it would on a '94 or '95 YJ. I haven't had any problems and no real course vibrations, but a SYE is always better than this shorter factory driveshaft.
This is a great affordable lift and I'm 100% satisfied with it, but keep in mind this is the version that was being made by Warn, so there are probably some differences to what you get from the parent company Superlift today?
"The only physical problem Obamacare won't be able to fix, is bustin' your @$$." – Dennis Miller
+Crusader+ is offline   Reply With Quote
Unread 10-01-2008, 03:31 PM   #1414
Ptr
1992 J-Series Truck
stock with 3/4" boomerangs and 31" Goodyear Wrangler tires.
Ptr is offline   Reply With Quote
Unread 10-01-2008, 08:27 PM   #1415
usmcestep
4" Rough Country
33x12.50 Parnelli Jones Dirt Grips
15x8 Cragar's
Here she is recently with the rock panels and full cage:
05 TJ RME 4.0
3" Zone 2" BL
35x12.50 procomp xterrains
Rear smittybilt bumper with swingout tire carrier
www.tnmudders.com
usmcestep is offline   Reply With Quote
Unread 10-05-2008, 11:02 AM   #1416
BamianYJ
Great looking jeep man!
You've had to get a paint job to keep it that clean. Right?
93' YJ 2.5l, AX-5, NP-231, 33x12.50x15 BF Goodrich AT/KO's. Pacer Wheels. Herculined. Ford 8.8 w/ 4.88's, SOA
Roll Tide
BamianYJ is offline   Reply With Quote
Unread 10-05-2008, 02:24 PM   #1417
Turner
[QUOTE=usmcestep;5783223]1989 YJ Wrangler
4" Rough Country
15x8 Cragar's
[QUOTE]
Man nice jeep! I used to live in JC! if you go to Poor Richards ask for matt johnson. A good buddy of mine
--Turner--
2006 Jeep TJ
1982 Toyota Pickup 20r/22r Hybrid, 5.29s, Lockrite frt/spool rear, Longfields, Hysteer, discs, armor, dents, smiles.
1970 Ford Bronco302, dana 30, 9", 3 on the tree, show stopper.
Turner is offline   Reply With Quote
Unread 10-05-2008, 04:48 PM   #1418
usmcestep
Thanks all! It was repainted when I bought it...
I dont go into PR's anymore being a bit older and the crowd there is a bit more gangsterish...
05 TJ RME 4.0
3" Zone 2" BL
www.tnmudders.com
Unread 10-05-2008, 08:15 PM   #1419
Turner
True... alot of wangsters too... i always went about noon on the days i didn't work... got sloshed early and cheap!
--Turner--
2006 Jeep TJ
Unread 10-06-2008, 03:15 PM   #1420
Shinobi
1992 Jeep Wrangler
4.0L 5 speed
4" RC lift
1" Shackles
Custom made front bumper
Bf goodrich 285/70/r17 on Cragar's Soft 8's
Herculine'd top and doors .
Shinobi is offline   Reply With Quote
Unread 10-06-2008, 05:38 PM   #1421
Turner
hey hey i really like that yj shinobi! good work!!
--Turner--
2006 Jeep TJ
Unread 10-06-2008, 06:25 PM   #1422
GreyfoxVt
GreyfoxVt's Avatar
OK, So I just finished the 2.5 Rough Country YJ Suspension Lift. Nice... With the 1 3/4" shackles, I am up around 4". SO the fun now begins...
I have decided to add the transfer case lowering kit, and will install a new slip yoke eliminator I just purchased this weekend. I will be using a Tom Woods custom CV joint shaft to cut down on vibrations, and add some streigth.
Anyway, I wanted to post a before and after photo as to where we are right now...
Before:
After:
GreyfoxVt is offline   Reply With Quote
Unread 10-06-2008, 06:36 PM   #1423
flowrida2480
if your getting the slip yoke and cv driveshaft you won't need the transfer case lowering kit just to let you know. and also most people who put the 4" RC lift kit are ok with just the transfer case lowering kit. why not just buy the tc lowering kit and see if it improves? If it doesn't then spend the big bucks for the sye/cv. just my 2 cents trying to help
1995 YJ
4.0L inline 6
5 speed Manual
All stock except 31" tires but not for long.....
[COLOR="Red"]Red Jeep Club #490[/COLOR]
flowrida2480 is offline   Reply With Quote
Unread 10-06-2008, 08:35 PM   #1424
Barrio
Before:
After:
looks great!
www.offroadjunkies.net
www.pgh-offroad.com
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline   Reply With Quote
Unread 10-07-2008, 12:35 AM   #1425
Shinobi
thanks
