Quantcast How will my jeep look with xx" tires on x.x" of lift? - Page 8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > How will my jeep look with xx" tires on x.x" of lift?
Old 04-05-2005, 04:00 PM   #106
YJ_Aaron
Ya i've got a welded carrier i'm thinking of putting in there. For street more predictable.. the detroit makes me change lanes when i shift hard.
91 YJ rebuild! Rush to get it driving/wheeling.
http://ozarksjeepthing.com/c/index.php
YJ_Aaron is offline   Reply With Quote
Old 04-05-2005, 05:47 PM   #107
Junker 91 YJ
1991 YJ
2.5L low output
3" rough country
33x12.50 procomp M/T's
lots of black paint
Black on black on black on black on black.
My Jeep
Junker 91 YJ is offline   Reply With Quote
Old 04-05-2005, 08:48 PM   #108
atomicmoose
Just call me Moose
atomicmoose's Avatar
Originally Posted by Hackle
Stock YJ New wheels
color me jealous....
atomicmoose is offline   Reply With Quote
Old 04-07-2005, 05:26 PM   #109
Hackle
Thanks for the comment.
89 YJ Nearly Stock:)
3 link w/ coilovers front. 4 link coil over rear, 39.5" IROC's, Walker Evans Beadlocks, Rear 60 w/spool, Tera Low, Front 60 w/ OX Locker, Warn 9000, & a few others. New 4.0 HO
Hackle is offline   Reply With Quote
Old 04-08-2005, 07:00 AM   #110
atomicmoose
Just call me Moose
Wish I had the kind of money to do half the mods you have done! She looks like a lot of fun!
Old 04-08-2005, 03:40 PM   #111
Mudzilla
hey raZe, i was wondering what rims you got on your jeep becuase im lookin to put a 38 x 15.5 Mickey Thompson Baja MTZ and i dont kno what rim will give me the right offset to fit that tire under my jeep i have a enough clearance height wise but how did u make it fit width wise on your jeep?
[COLOR="DarkOrange"]19XX-Jeep YJ[/COLOR]
-Chevy 350, Procomp 6" CSC Lift, 2in body, Lokar Shifter, SYE and CV Driveshaft, 35x12.5 Mickey Thompson Baja Claws
Mudzilla is offline   Reply With Quote
Old 04-08-2005, 04:38 PM   #112
Hackle
Keep in mind I have owned it and been building it for 10 years. I or my friends do 98% of the work so labor is cheap. I am not rich by any means I just do one project at a time.
Old 04-08-2005, 08:05 PM   #113
atomicmoose
Just call me Moose
I hear ya...I am just impatient
Old 04-12-2005, 11:52 AM   #114
JayJEEPguy
Here are the latest pics showing my lift and etc...
3" Rusty's leaf springs, 1" DayStar bodylift, 5/8" M.O.R.E. Boomerang shackles, and TJ flares.
Tires are 33x12.5x15" B.F. Goodrich All-Terrain T/A KOs on 15x8" Cragar 397s with 4" of backspace.
Jason T.
'05 Saab 9-5 Aero: Black. Turbocharged Swedish goodness
'04 WJ:Special Edition. V8, QTII, 2"BB, Bilsteins & 245/75/16" Goodyears
'02 WJ:4.7L, Selec-Trac. Totalled 9-12-07. Click to hearKolak 3" exhaust sound clip
http://www.cardomain.com/id/MourningWoody
JayJEEPguy is offline   Reply With Quote
Old 04-28-2005, 08:23 PM   #115
Roadkill43
Well this thread has been here for a while, I might as well post my jeep in here too...
This pic was taken when the lift was just installed, a 2 inch BDS lift with no lift daystars and 31x10.5 inch BFG mudterrains
This is the current setup with the springs all nice and broken in
and finally the flex shots.
The 31s rub just a little at full flex. Any bigger and I would be in trouble. Ohh and the bump stops are useless now.
1991 Black YJ, 2.5, Herculined, K&N, Electric Fan, Posi-Loc, 2" BDS, 31" BFG MT's, American Racing rims, Aussie Locked rear, Tuffy lockboxes, Daystar shackles, AtoZ rockers, SmittyBuilt SRC bumpers, 100W KC Daylighter Fog lights, and more to come….
"Being smart is just like driving a jeep, you still get stuck just farther from help."
My Rig
Roadkill43 is offline   Reply With Quote
Old 04-28-2005, 08:56 PM   #116
RideRed04
You've got quite a bit of downtravel hiding in there. Try removing the shocks and measuring for new ones. Your spring clamps are probably also to tight. If it doesn't see much trail time, then disregard previous statements.
1989 YJ: 3.5" of lift, 36" irok's, warn 9.5ti, d44's
1998 XJ classic for DD, a little lift, a little tires
RideRed04 is offline   Reply With Quote
Old 04-28-2005, 09:03 PM   #117
Roadkill43
Well it does see the trail quite often but its also my daily driver. That and I tend to take pictures right after I wash the thing. New shocks I thought of but loosening the spring clamps I haven't. Thanks for the tip.
My Rig
Old 04-30-2005, 10:54 AM   #118
MBrit13
This may sound dumb, but what are the spring clamps?
Also, do you get less flex if your u-bolts are really tight? When I was installing my lift kit, I was following the instructions of the Rubicon Express booklet. I torqued it down to what they said. Later, I looked at the Procomp U-bolt instructions, and they had around 20 ft/pounds lower for the suggested tightness.
Is it a bad thing that the ends of all 8 u-bolts in the back are slightly bend outwards?
1994 2.5L Jeep Wrangler (5spd)
Rubicon Express Extreme-duty 2.5" lift
31x10.50 BFG Mud-Terrains
Diamond Plate rocker guards and Herculined
Dynomax Cat-Back and Catco catalytic converter
Eagle Scout Jeep Owner
Black Jeep Club v2.0 member #45
MBrit13 is offline   Reply With Quote
Old 04-30-2005, 10:57 AM   #119
RideRed04
Tighten those U-bolts down good, they don't affect flex, and they will break off the center pin on the spring if they shift. The spring clamps are the clamps about half way between the center of the spring and the end of the spring that hold the leaves together. Most aftermarket leaves have a U shaped clamp with a bolt at the top to hold them. If you loosen that bolt a little, the leaves can move more freely. As for your u-bolts being bent outwards, I guess I'd have to see a picture. If your u-bolts are cocked at an angle, then I'd say you should get them perpendicular to the axle. If they are just bent from hitting stuff, get an angle grinder and cut them off at the nut like you should have right away
Old 05-01-2005, 09:27 PM   #120
MBrit13
Thanks, and yea you are right about how I should have cut the bolts at the nut before. I have scraped a little with those bolts, but they were bent out after I first tightened them. The problem is that I only have a Saw-zaw, and it would take forever to cut 16 bolts down to the nut. Would a grinder be much faster?
Glock Forum
