How will my jeep look with xx" tires on x.x" of lift? - Page 53 - JeepForum.com
 1Likes
post #781 of 3491 Old 10-29-2007, 12:49 PM
PanthrosRevenge
PanthrosRevenge's Avatar
clickless
'95 Wrangler
2.5L
Rear Aussie
31X10.5X15 Hitech AT's
2.5" Rubicon Express SD Lift
Midland CB w/ 4' Firestik II
PanthrosRevenge is offline
post #782 of 3491 Old 10-29-2007, 08:17 PM
Wild Hare
91 yj 2.5l 4 cyl, explorer 8.8 rear 4.88's welded, dana 30 front 4.88's welded w/cable posi lock, TNT Customs Y-link coil conversion front with stock ZJ front coil, rear is now a TNT customs double triangulated rear with stock tj front coil w/ 1/2 coil cut and looped. TNT front tube fenders w/flare, TNT rear crusher corners w/flares, 37-12.5-17 BFG muds on 17x9 predators on 2" spacers.
Wild Hare is offline
post #783 of 3491 Old 10-30-2007, 04:46 PM
Stout95YJ
Here's my 95 YJ 4"RE std with stock(235/75/r15) awaiting 33" muds
Stout95YJ is offline
post #784 of 3491 Old 10-30-2007, 05:43 PM
snb73
My winter project; 87 YJ, SOA with RE 2 1/2 inch springs, stock shackels, 33 x 12.50 Yokohama Geolander MT.
Help make it click free please!
snb73 is offline
post #785 of 3491 Old 10-30-2007, 07:35 PM
PRCE7
1987 YJ Wrangler
click free
PRCE7, 87 YJ
stuff for sale: Posi-Lok 4X4 cable set-up, Warn differential guard, NP 231, YJ OEM drive shaft, Ford 9 inch rear-end, Dana 35, Front 1" extended bump stops, XJ Grille with both bezels, Dana 20, Torque Flight 727, here is the full detail:
PRCE7 is offline
post #786 of 3491 Old 10-30-2007, 07:44 PM
PRCE7
1987 YJ Wrangler
click free
PRCE7, 87 YJ
PRCE7 is offline
post #787 of 3491 Old 10-31-2007, 08:24 PM
snb73
Thanks PRCE7.
Steve.
87/94 YJ, SOA w/ RE 2 1/2 springs, 33 x 12.50 Yokohama Geolander MT's
snb73 is offline
post #788 of 3491 Old 11-04-2007, 07:23 AM
DonnyG77
5.5" total lift and 33s
3.5" D!ck Cepek Race Series lift, 1" lift shackles, 1" Body lift, 33x12.50 15s on 15x10 steelies.
Don
90 YJ-3.5" D!ck Cepek Lift, 1" Shackles, 1" BL, 33 12.50s on 15x12 Eagle Alloys.
92 F-150 Daily Driver
DonnyG77 is offline
post #789 of 3491 Old 11-04-2007, 08:25 AM
Jeffro06
Jeffro06's Avatar
It appears your photo requires a password.
Jeffro06 is offline
post #790 of 3491 Old 11-04-2007, 12:12 PM
DonnyG77
hmmm. Does this link work for you? http://img136.imageshack.us/my.php?i...jeepva2zf3.jpg
Don
DonnyG77 is offline
post #791 of 3491 Old 11-04-2007, 06:28 PM
Jeffro06
Jeffro06's Avatar
Yep...and this works even better...
For DonnyG77
Jeffro06 is offline
post #792 of 3491 Old 11-04-2007, 06:30 PM
Stout95YJ
anyone have a pic of their YJ with 33x10.50's
post #793 of 3491 Old 11-04-2007, 08:12 PM
dutywilliam
Fabtech 3.5 and 5/8 More Boomerang shackles
Just installed the front locker so I was just testing it out in the woods behind my buddies house...
These pics are with 33 12.50 Dunlop Mudrovers with fabtech 3.5 inch lift with 5/8 more boomerang shackles front and rear, with no front or rear track bar and with the sway bar disconnected
dutywilliam is offline
post #794 of 3491 Old 11-04-2007, 08:22 PM
cooltc2004
If I may
4" Suspension Lift, 2" Body Lift, 33x12.5" Interco TrXus Tires
cooltc2004 is offline
post #795 of 3491 Old 11-05-2007, 11:42 AM
Rodeo1488
By These Things I Stand !
Rodeo1488's Avatar
Clickless...........
Originally Posted by cooltc2004
If I may
White Jeep Club Member #1488
"Sometimes, there's Justice.......Sometimes, there's Just Us. "
- Living my life on a Thin Blue Line -
Originally Posted by HolidayJeep
If that doesn't work, here's what you do. Buy a bunch of burritos and tie them to pieces of string. Then tie the strings to your Jeep. Then, when the meskins come out of the house drawn by the smell, you drive away. The meskins will chase burritos for miles and miles.
Rodeo1488 is offline
"project Cheap Jeep" - 5-6" Lift - Looking For Oem Shocks For "xx" Lift Jeepwood YJ Wrangler Technical Forum 4 11-26-2009 07:32 PM
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
How tall is your jeep with 4" lift and 33" tires? patrickregan TJ Wrangler Technical Forum 28 10-29-2009 06:57 AM
tires (32" tires with 2" lift and 3 speed auto w/ 3.07 gears) libertynewyork TJ Wrangler Technical Forum 15 10-20-2009 10:03 AM
Can I fit 33" tires on my Jeep with a 3 1/4" lift? crawlr TJ Wrangler Technical Forum 15 12-07-2008 08:02 PM
