How will my jeep look with xx" tires on x.x" of lift? - Page 219 - JeepForum.com
 3Likes
post #3271 of 3491 Old 06-21-2013, 08:00 AM
zte87
GIVE IT THE ONION
zte87's Avatar
4 inches of lift on toyo 37-14.50-15 mounted on 15x10's with 4 inches of back spacing!
zte87 is offline
post #3272 of 3491 Old 06-24-2013, 02:00 PM
AmmitOsiris
OME 36R on all four corners with an inch of shackle lift sitting on 4 33x12.50x15 Goodyear MTR/Ks on a 15x8 wheel with 2.5 inches of backspacing
[IMG]http://i1114.photobucket.com/albums/k534/AmmitOsiris/Mobile%20Uploads/7A2ADD58-928D-4E02-8362-7753C5727E79-481-0000001D2FE20178_zps8af179cb.jpg[/IMG
AmmitOsiris is offline
post #3273 of 3491 Old 07-01-2013, 10:06 PM
amerdt4
SOA W/Rubicon Express 1.5 springs and 1" shackles . 8" total lift on 35x12.50r15 .4.0L Dana30 4.10 Ford 8.8 4L10
amerdt4 is offline
post #3274 of 3491 Old 07-11-2013, 06:22 PM
yjbruiser
zte87 you have any flex shots? i like that jeep. mine is disrepair at the moment but hopefully soon i will get everything back together and it will get back on the trails.
yjbruiser is offline
post #3275 of 3491 Old 07-11-2013, 07:37 PM
zte87
GIVE IT THE ONION
zte87's Avatar
since this is't the thread for this I will post one but keep in mind I get about more flex than this!
Ok maybe one more!
zte87 is offline
post #3276 of 3491 Old 07-11-2013, 10:21 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
That Zte... Always camera shy.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #3277 of 3491 Old 07-12-2013, 04:02 AM
saintk99
4.5 bds 33x12.5x15
saintk99 is offline
post #3278 of 3491 Old 07-12-2013, 04:19 AM
amerdt4
I'll tell you I wasn't a fan of the MetalCloak fenders until I saw your jeep . Totally changed my opinion ! Great looking Jeep! Makes me miss my red one .
amerdt4 is offline
post #3279 of 3491 Old 07-17-2013, 12:14 PM
BrandonYJReed
2016 JK Wrangler
3.5" BDS springs and 1" booms in the front, 5" BDS and 5/8" booms in the rear. Equals 4.5" of lift. 35x12.50 with 3.75 bs.
'16 JK Sport
-2.5" TF Spring Lift
-315 BFG A/T
-3.73
BrandonYJReed is offline
post #3280 of 3491 Old 07-18-2013, 09:15 PM
zte87
GIVE IT THE ONION
zte87's Avatar
Originally Posted by Mike95YJ View Post
1995 Jeep YJ
Rubicon Express 4.5" Extreme Duty
1" M.O.R.E Body Lift
TJ Flares
35x12.50 BFG MT's on 15x8 Rockcrawlers
Are you running a longer shackle in the rear?
zte87 is offline
post #3281 of 3491 Old 07-18-2013, 10:02 PM
Sparrows
I will play (p.s. Zte you make me want to burn my jeep then throw it off a cliff then run it over with a bulldozer then pee on it)
Anyways, OME 2.5" springs, BESRK 1/2" shackles, tj cut rears, metalcloak 4" overlines front, 35" dick cepek crushers.
Grrrrrrrrr only one pic will work. Oh well you get the idea!
Cheers
June '13 YJOTM
Sparrows is offline
post #3282 of 3491 Old 07-18-2013, 10:15 PM
zte87
GIVE IT THE ONION
zte87's Avatar
Cheers
SEEEEEEEEEXY as always brother!
zte87 is offline
post #3283 of 3491 Old 07-19-2013, 11:32 AM
Ripper3494
I don't think I've posted up my final stance. 3.5 bds springs and i lost the front cloaks
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #3284 of 3491 Old 07-19-2013, 01:06 PM
zte87
GIVE IT THE ONION
zte87's Avatar
Is hat with the 3.5 bds springs? They look like they really settled in!
zte87 is offline
post #3285 of 3491 Old 07-19-2013, 01:37 PM
Ripper3494
Well sorta the front mounts I put on are oober low profile so it sits lower but yea they settled quite a bit. But evenly on both sides so i don't care too much haha
build thread:
RC vs BDS
"project Cheap Jeep" - 5-6" Lift - Looking For Oem Shocks For "xx" Lift Jeepwood YJ Wrangler Technical Forum 4 11-26-2009 07:32 PM
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
How tall is your jeep with 4" lift and 33" tires? patrickregan TJ Wrangler Technical Forum 28 10-29-2009 06:57 AM
tires (32" tires with 2" lift and 3 speed auto w/ 3.07 gears) libertynewyork TJ Wrangler Technical Forum 15 10-20-2009 10:03 AM
Can I fit 33" tires on my Jeep with a 3 1/4" lift? crawlr TJ Wrangler Technical Forum 15 12-07-2008 08:02 PM
