Quantcast How will my jeep look with xx" tires on x.x" of lift? - Page 143 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > How will my jeep look with xx" tires on x.x" of lift?
Old 11-11-2009, 01:49 PM   #2131
clgielin
Life is Grand
clgielin's Avatar
2003 WJ
Can't help with the front.
Chris
2003 WJ 4.7L
Build Thread Here: 2003 WJ
Michigan Tech Jeepers #4
Utah JeepCrew #16
clgielin is offline   Reply With Quote
Old 11-12-2009, 01:32 PM   #2132
Jsplurge
How would 33's or 35's look w/ 18" wheels on 4" of lift...
Was looking into getting either the 33" or 35" Nitto Mud Grapplers on an 18" XD Series Diesel wheel, need some photos/ input I have a 94" Wrangler 4.0L and I also plan on swapping in the 8.8/ 4.10 axle. Thanks in advance guys.
-JG
94' YJ, 33" Toyo M/T's, 6" lift, 15" Xtreme Pro-Comps Black, D30F/8.8 locked Rear, Cut front Fenders, TJ Flares, ARB Safari Snorkel, Swapped CJ Tailgate, Pacesetter Header and a lot of other doodads that broke me.
http://i65.photobucket.com/albums/h2...ep/photo14.jpg
Jsplurge is offline   Reply With Quote
Old 11-12-2009, 02:01 PM   #2133
Sungard
Thanks.........I think I will go with the pair.....rear looks
'95 YJ, 4.0, Rubicon Express 2.5" standard Lift Kit + 1" Daystar BL & 5/8 MORE Boomerang shackles with 32x11.50 BFG A/T's.
Sungard is offline   Reply With Quote
Old 11-12-2009, 09:28 PM   #2134
cubewhiz
cubewhiz's Avatar
3.5" BDS, 5/8" M.O.R.E. boomerang shackles in front (haven't gotten the chance for the rear yet)
33x12.50R15 Toyo Open Country M/T on 15x8 Cragar Soft 8 wheels
95 YJ with 2.5L 4 banger engine, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My Build Thread
Originally Posted by TheRealOldjeep View Post
LOL, you think something might be sub-par compared to a Smittybilt product? Are you new?
cubewhiz is offline   Reply With Quote
Old 11-13-2009, 10:26 AM   #2135
Rohdawg
89 Yj
Okay, here goes. She ain't pretty but she'll be getting new shoes and paint (Hemi Orange) next week.
89 YJ, 4.2L I6 automatic, 2.5" RC lift, 1" RC Boomerang Shackles, 33x12.5 Trxus STS, Trac bars are in the blue trash can
Rohdawg is offline   Reply With Quote
Old 11-15-2009, 11:13 AM   #2136
agentr855
Originally Posted by MosinMe View Post
Flat stock springs with a 1" boom shackle lift (pretty much stock height) with TJ flares and 30"s.
Flex shot
flex? how bout this? (4.5'' RE 33'' claws 1'' bl)
_______ Only in a YJ
/l ,[_____],
l---L -[]lllllll[]-
()_)-()_)--o-)_)
agentr855 is offline   Reply With Quote
Old 11-15-2009, 04:10 PM   #2137
berretaman
warn front bumper w/ grill guard
here is my 91 with the warn front , i also have the rear but someone has already posted what the rear looks like
berretaman is offline   Reply With Quote
Old 11-16-2009, 08:07 PM   #2138
Shinobi
Spring over with 4" Wapred RC springs :P
Shinobi is offline   Reply With Quote
Old 11-17-2009, 08:49 PM   #2139
davidselite737
95 YJ with 35's SOA
This one is ugly, but amazing offroad. No fenders. Comp cut yj stock springs up front. XJ stock springs in back. 35" tires. did have 42's.
" The path of least resistance, is the path of the loser"
davidselite737 is offline   Reply With Quote
Old 11-19-2009, 03:07 PM   #2140
imstillatwork
Here is mine.
33's + 1" shackles + ?????? springs. Can someone tell me how tall my springs are?? Driver side bottom edge of tub is 25" passanger is 26"...strange or just saggy spring from the driver?
Are my shackle angles good enough?
imstillatwork is offline   Reply With Quote
Old 11-19-2009, 03:12 PM   #2141
Barrio
Originally Posted by imstillatwork View Post
Here is mine.
Shackle angle looks alittle steep, I bet it rides like a school bus. Try loosening them up (safely, the torq specs are somewhere on here) and lube'em up. If you loosen them all up it might level out your rig. Might. Also those shackles look huge, Im a big fan of the Boomerang shackles my self. Your leave sag could be a result of the big shackles.
www.offroadjunkies.net
www.pgh-offroad.com
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline   Reply With Quote
Old 11-19-2009, 05:34 PM   #2142
agentr855
any one have 4" soa with 35" tires with .5" shackel???? looking to take my 4.5" rubi lift and do a soa pics would b nice for insperation!!
/l ,[_____],
l---L -[]lllllll[]-
()_)-()_)--o-)_)
Old 11-19-2009, 06:30 PM   #2143
Barrio
You would probley want a spring UNDER set up. 4" SOA would be upwards of a foot of lift.
If you are rubbing with the 4.5" kit, add TJ flare and cut the fenders. The 1/2 shackle would also help alittle bit as well. And as alway the much fear last resort of the 1" body lift.
Thy the tj flares or even tube fenders front and rear, keep that center of gravity down as much as you can.
Once again 4" spring over would be the high light at Monster Jam.
www.pgh-offroad.com
Old 11-19-2009, 08:21 PM   #2144
imstillatwork
It rides like a bus. Yes.
They are 6" center to center, so that's 1" lift, right? I'd like to swap them out for 1/2 inch lift, I can afford to loose 1/2 inch height.
I've loosened them up already, it improved. I later realized that I only loosed and greased the shackles, not the spring bushings on the frame.
Will a shorter shackle improve ride from what you can see?
Old 11-19-2009, 08:52 PM   #2145
Barrio
As far as shackles, and this is me, go with a greasible boomerang shackle with zerks. Get your self a good grease gun as well. 6" shackle eye to eye I believe is 1" of lift, I think stock it 4" eye to eye. I have 1" lift booms on my heep.
As far as ride quality goes, loose the sway bars and track bars if you havent already done so. I will ride alot better. Make sure your tire pressures are right and ride quaility will get better as well.
EDIT:
I went back and looked at your pictures, I see the sway bar is toast. Good. Attack the tack bar next.
LUBE,LUBE,LUBE....TORQ, TORQ, TORQ!
www.pgh-offroad.com
Glock Forum
