#2086 | |
[IMG]
[/IMG]33" maxxis on cragar soft 8..4" suspension lift...1"shackle
[color="Black"][center][size="4"][font="Showcard Gothic"][color="Black"][url="http://groups.jeepforum.com/Built_Not_Bought"][color="Black"]Built Not Bought #56[/color][/url][/font][/size][/color][/center][/color] [QUOTE=ziebartrob;8192765]I find that if you stick it in from a left or right angle instead of straight down it works no problem.:p[/QUOTE] |
#2087 |
Updated Photos:
33x12.50-15 KM2's on 15x8 Allied's (3.75bs) ~ 3.5" Black Diamond with 5/8" MORE's ~ Rugged Ridge TJ Flares
__________________ "The only physical problem Obamacare won't be able to fix, is bustin' your @$$." – Dennis Miller |
#2088 |
Hey Nacho
Cool looking jeep. Where did you get the sliders ? |
#2089 |
Thanks; I got the sliders from a local state business www.wildbuiltfab.com It's listed as their 'Stomper' series in a diamond plate with countersunk bolts and 3/16" thick.
They only tuck under the tub about 1.1/2" or so (unlike AtoZ's or others), but that's all I need as I don't do much heavy rock crawling. I ordered them made for YJ length and then had to cut them with my angle grinder to fit between my TJ flares, rather than tucking them under. I also used a 1/2" countersink bit to drill a lower row of holes to increase fastener bond onto the side of the tub. Well, because the grinding caused too much heat I had to repaint, I used the 'universal' formula of Rustoleum Hammered black and they turned out more gray, unlike my rear bumper which is the 'Metal' formula. It's still a shade of gray/black, but much darker by comparison. Anyhow, I was going more for step use because the bar is as low as they come, for my wife ... And also for appearance, rather than for extreme duty use. Although they work just fine for your typical Jeeper. Later Holmes.
#2090 |
SOA with add-a-leaf in front (it was 1 1/2" lower in the front after the stupid soa kit....built terribly) 32x11.5x15 BFG All-Terrains....need bigger tires now.
#2091 |
whose Jeep is this?
#2092 |
1995 Yj
2.5inch suspension lift 3inch body lift total of 5.5inch of lift. 35inch pro comp x terrain tires. Tj flares
![]() ![]() ![]() ![]() Last edited by jeep159; 10-06-2009 at 09:06 PM.. |
#2093 |
89 yj
9" soa 44 tsl's 14 wide american racing wheels ![]() ![]() ![]() |
#2094 |
1.5'' Suspension Lift with 2'' body lift
31x12.50x15 BFG Mud Terrains ![]() Does anyone know if I could fit 33's under here? |
#2095 |
I doubt it, you should be fine with 32's but from the way the picture looks, you would probably need to add a 2.5" lift
1992 YJ Wrangler 4.0L, NV3550, 2.5" suspension lift, 32" BFG M/Ts, lots of other cool stuff RED JEEP CLUB MEMBER #494 |
#2096 |
I have an odd question. How much lift would I need to FULLY flex the suspension on 35's? I assume it's dependent on a number of things. I want a one inch body (so i can keep the frame clean) and Boom Shackles. So what size springs?
Thanks. EDIT: Im also putting some flat fenders on it and maybe doing a little work to the rear as well.
2003 Ford F-350 Extended Cab Long Bed 6 speed. 93 YJ 4.0 AX-15 2.5 Springs. 31" tires Last edited by kimber_Da; 10-11-2009 at 11:50 PM.. |
#2097 |
94 YJ - 2.5 ProComp Lift - 5/8" MORE Shackles - 32x9.5 TSL Bias
#2098 |
Some flexation - no pile of rocks is safe...
4" RC lift 235/75x15" http://marmot.dudeabides.net/gallery/albums/lift-kit-for-Mabel/flexation1.jpeg http://marmot.dudeabides.net/gallery/albums/lift-kit-for-Mabel/flex2.jpeg http://marmot.dudeabides.net/gallery/albums/lift-kit-for-Mabel/flex3.jpeg http://marmot.dudeabides.net/gallery/albums/lift-kit-for-Mabel/flex4.jpeg ![]()
'95 YJ 2.5L "Mabel", ax5, np231, HP30, JK d44, 285's, SUA lift, body lift, JK steelies, 4.10, winch, CB, Bestop seats Axle swap thread |
#2099 |
click free....
1992 YJ -2.5 Old Man Emu lift, RC 1-1/4" Boom greasable shackles, JKS Discos, 1" Daystar BL, 33x12.5x15 BFG AT KO's mounted on 15x8 Cragar soft 8's, flush mounted tailights, SJFab front bumper, TKH Fab swingout tire carrier welded to a Dirtworx rear bumper, Tuffy stereo console, RC SS Extended brake lines, Home brew plate relocation bracket, Magnaflow Cat, Dynomax Cat back, No track bars front or rear 1997 XJ - 4.5 RC coils + extra OEM spring isolator(6.5" actual front), OME medium duty springs+OME extra leaf + Teraflex 1.5 shackles (6.5" actual in rear), OME Long travel shocks, OME SS, IRO Adj TB, IRO Adj LCA'S, IRO Adj Uppers, RC Control arm drop brackets, JKS Quicker Discos, SYE / XJ shaft, 33x12.5x15 BFG AT KO's on 15x8 Cragar soft 8's, RC SS extended Brake lines, Hella 500's 1996 ZJ - RE 2 inch BB w/shocks (rides like crap), OME SS, 31x10.5x15 General Grabber AT2's - SOLD |
#2100 |
click free....
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
