Quantcast How will my jeep look with xx" tires on x.x" of lift? - Page 139 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > How will my jeep look with xx" tires on x.x" of lift?
Old 09-16-2009, 09:18 AM   #2071
Flingit1200s
Thanks antec!
88' Wrangler, 4.2 .30 over with Weber 32/36, AX 15, sye, 4:10 gears, Ford 8.8 and Dana 30 with 4:10's out of a 2.5, 3.5" BDS springs with MORE 5/8" shackles, no trac or sway bars, 33x12.5r15's on 15x8 American Racing Baja's.
Flingit1200s is offline   Reply With Quote
Old 09-18-2009, 01:13 PM   #2072
ldso
ldso's Avatar
ridin' high
So she's lifted! It took 3 days, a lot of help (shouts out to Shawn, Vinnie, Sammy, BK, Hartley, Dylan, everybody!), lots of new implements of destruction from Harbor Freight, trips to Lowes and Napa etcetera.
So Mabel the Jeep before:
jenny and lincoln :: Lift kit for Mabel :: IMG_4155
And after installing a 4 inch Rough Country lift:
jenny and lincoln :: Lift kit for Mabel :: IMG_4167
The gallery of the project:
New skills acquired: Grinding and replacing brake lines for sure.
'95 YJ 2.5L "Mabel", ax5, np231, HP30, JK d44, 285's, SUA lift, body lift, JK steelies, 4.10, winch, CB, Bestop seats
Axle swap thread
ldso is offline   Reply With Quote
Old 09-18-2009, 01:45 PM   #2073
mbecnel
I think your shocks are upside down ??????
mbecnel is offline   Reply With Quote
Old 09-18-2009, 02:38 PM   #2074
ldso
ldso's Avatar
upside down
If so then the old ones were too!
jenny and lincoln :: Lift kit for Mabel :: IMG_4157
I've been looking at some pictures though, and I think you may be right
Axle swap thread
Old 09-18-2009, 03:20 PM   #2075
mbecnel
Hey,
The only reason I thought they were upside down was I saw a post where someone else had put them upside down also...............Getting ready to do a lift so that'll help me out
Old 09-18-2009, 10:04 PM   #2076
ldso
ldso's Avatar
Hey,
I guess it doesn't matter, but maybe it's better to have the metal part closer to the ground than the rubber boot. Might be a little more durable. I'll probably flip 'em next time I check the torque on the suspension bolts.
Good catch, thanks
Axle swap thread
Old 09-19-2009, 05:42 PM   #2077
ROADDOG516
How do I add a picture on this?
YJ=THE LAST REAL JEEP!
1993 YJ 2.5
2011 Cherokee 5.7
ROADDOG516 is offline   Reply With Quote
Old 09-19-2009, 08:10 PM   #2078
DiabloYJ
You have to host pictures on a website before they can be posted here.
If you don't already have an account go register at Photobucket.com. They allow you to host images from your computer on their site. After you've uploaded a few pictures, just click on the pic you want to share with us and there will be several tags on the left hand side. Just copy the one on the bottom that says [IMG] and paste it here and your pic should show up!
"When Life starts to pass you by..............Downshift"
Then again that used to be my motto until I got the Jeep, now that doesn't even work half of the time.
GD Thread HIJACKERS Member #1
ΜΟΛΩΝ ΛΑΒΕ
-Justin
Originally Posted by 2006Sport View Post
Sometimes I wish I had leaf springs.
DiabloYJ is offline   Reply With Quote
Old 09-19-2009, 10:27 PM   #2079
ROADDOG516
thanks ill try it
1993 YJ 2.5
2011 Cherokee 5.7
Old 09-20-2009, 03:34 PM   #2080
2wheelmatt
Here's my 94 Sahara.
I've got 3.5 Superlift springs, Skyjacker nitrogen shocks, 1.25 over on the shackels, 33x12.5 Cepek FCII, and a Rampage swingaway in the back that I still need to install the lights on.
2wheelmatt is offline   Reply With Quote
Old 09-20-2009, 06:17 PM   #2081
Nates93yj
Nates93yj's Avatar
Rough Country 2.5 and 5/8s booms
33x12.50 Dayton Timberlines
NATE
2004 Jeep Wrangler Columbia Edition DD and Trail Rig
1993 Jeep Wrangler Nates93yj BuildSOLD
Nates93yj is offline   Reply With Quote
Old 09-26-2009, 09:11 PM   #2082
VACJ5
Can I see some YJ's with tube fenders... there are a ton of different brands out there... I am trying to get a feel for which ones I wanna install.
79 CJ5 Silver Anniversary Edition... revived & sold *sniff
91 YJ 4.0 L, with some stuff bolted to it... 3/4 Ton YJ
91 2 door Cherocar... in progress
BeachMetalWorks Custom CNC cut Jeep parts & more
VACJ5 is offline   Reply With Quote
Old 09-26-2009, 09:42 PM   #2083
Nates93yj
Nates93yj's Avatar
Those are Extreme Custom Fabs in the post above you, try in the picture reqeust thread
NATE
Old 09-27-2009, 05:36 AM   #2084
Sungard
Like the color............I have same................very crisp. I beleive this is 1 of the best color on YJ.......sure in my part of world...desert!
'95 YJ, 4.0, Rubicon Express 2.5" standard Lift Kit + 1" Daystar BL & 5/8 MORE Boomerang shackles with 32x11.50 BFG A/T's.
Sungard is offline   Reply With Quote
Old 09-28-2009, 01:35 AM   #2085
2wheelmatt
I'm a desert dweller too. Just a different part of the world. The color helps keep it looking clean...hides all the dirt.
Glock Forum
