How will my dana 35 handle a locker with 33's - JeepForum.com
post #1 of 11 Old 04-30-2006, 04:36 PM Thread Starter
renegadeyj
When I upgrade tires from a 32 to a 33 I think I will probably throw in a locker, if my axle can handle it. what are your opinions on this setup.
94 Jeep Renegade (no ugly fender flares) 4 inch ProComp lift 32x11.50 bfg mud terrains 4.0 liter HO Gibson Header, Flowmaster muffler, ford 8.8 swap
renegadeyj is offline
post #2 of 11 Old 04-30-2006, 04:44 PM
jeep loser
Havn't blown mine up yet.
5 % of people make things happen
65% of people let things happen
30% of people say "what happened?"
jeep loser is offline
post #3 of 11 Old 04-30-2006, 05:08 PM
atomicmoose
Just call me Moose
atomicmoose's Avatar
Works for some and not for others.... Just make sure you have spare parts with you.
atomicmoose is offline
post #4 of 11 Old 04-30-2006, 05:58 PM
RockWoRM
RockWoRM's Avatar
Do U have gears? The lower ya go, the more chance ya take. I would go with a auto locker like a No-Slip or such. Good unit for not too much money. I would deffinately get some kind of truss. Those D35 tubes flex like most don't know. One reason guys do break them. Go easy on the skinny pedel and U should be OK.
I ran this combo on 33's for a few years with zero probs.
http://65.42.106.152/forums/showthread.php?t=727690
Had a truss... but I allready sold it.
WoRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #5 of 11 Old 04-30-2006, 05:59 PM
GrimJeeper91
GrimJeeper91's Avatar
I haven't had any problems and my D35 has been locked for 6 years. If you are going to lock it maybe consider a Super35 kit that comes with a locker and high strength axles. I drive mine like it has a D35, carry spare shafts and everything else I need to fix it on the trail (unfortunately that all adds up to about a 100 pounds of extra gear I need to tote around). I have an auto so that helps absorb some of the shock loads. While we all know the D35 is the greatest, how long it lasts is usually up to the driver. I've seen a couple break in person and MANY videos on the internet and in EVERY case the breakage was driver error.
Example 1:
Observed: No forward progress due to loss of traction (results in bouncing in place)
Drivers Solution: Mash the go peddle (bounce more and higher)
Result: Snap
Example 2:
Observed: No forward progress due to things being in a bind (great traction everywhere so tires are not turning)
Result: Snap
I have seen the about two examples time and time again. Unfortunately everyone blames breakage on a crappy D35 instead of crappy driving.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
post #6 of 11 Old 04-30-2006, 06:09 PM
Bob_R
I have had one also for several years now. I did add the bigger axles for a better feeling of security. I'm fully locked with 4:88s, it's great, no problem crawling over lots of rocks, as already said just don't be stupid. Have fun.
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL TREAD LIGHTLY
Bob_R is offline
post #7 of 11 Old 04-30-2006, 09:20 PM
z71offroader
z71offroader's Avatar
it depends on a few things which most have been already discussed. such as how hard are u on it, how low of gears ur running, and also which locker ur using, and what power ur pushing to them.
i see u have the 4.0 so 4:10s or 4:56s is probably the ratio ur looking at?
93 YJ- SOA, R.E 1.5" Leafs, Custom paint, 35x16 Boggers,15x10 97 series rockcrawlers. Diamond plated interior and exterior, Tera SYE/CV DS, Herculined Tub, Bestop, Warn Bumpers w/ 9.5ti, 8.8" rear, D30 front, both ARB's with 4:88's, Super 88, Posi-Lok, Alpine Stereo, Tuffy Security, Hella Fogs, ProComp Spots, and much more.
07 2500HD D-Max CC LB Black Ranchhand Bumpers, MBRP 5" Straight Piped Exhaust, Edge Evo, N-fabs, 305/65/18 BFGs on Black Motos, much more soon to come!
(Sold)03 Z71- 33x12 BFG Muds, American Racing Victor Teflons, K&N intake, Gibson Exhaust, Ranchand bumpers, Hypertech programmed, Hella Spots, 12" JL sub, and much more.
z71offroader is offline
post #8 of 11 Old 04-30-2006, 09:32 PM Thread Starter
renegadeyj
Right now I have stock gears, but I think when I go to 33's I will switch to 4:10's. I think though now that I have thought about it, I dont really want to spend money on an axle that I will replace, because after I get out of college I plan to spring it over and run 37's. I may just try and find a cheap 8.8 and do an axle swap. I just cant see myself spending alot of money on a crappy axle.
post #9 of 11 Old 04-30-2006, 10:05 PM
paultyler
Uncle Paul has spoken...
paultyler's Avatar
It will not be a problem, especially if you have a 4 banger. Less horse power means less chance of breaking. I ran a Detroit in a D35 for 2 years. Went over the Rubicon twice, and other trails of similar quality. I don't think I even got close to breaking. You simply have to drive in a controlled fashion. Be aware of what you have.
I recently upgraded to D44s because I got sick of the response people gave me when they learned that I had a D35.
You have a 4.0 so you need to be more careful with the power you apply in hardcore situations.
My feeling about the D35 is that the ring and pinion is as likely to break as the shafts. I have a friend who broke the ring and pinion on his D35 on the gatekeeper at Rubicon. The shafts held up fine. That is the problem with a Super 35 kit. It gives you D44 strength shafts but leaves you with a weak ring and pinion.
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers,
, custom cv driveshafts,
, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s,
, Teraflex Bellyup,
, rock lights, RE hand throttle, M.O.R.E. roll cage,
, 9000lb winch with synthetic cable
(12voltguy.com), Dual Blue Top Optimas with
dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline
post #10 of 11 Old 04-30-2006, 10:12 PM
crazymon01
crazymon01's Avatar
i am runnin 32's with the 410's and locked with lock rite locker and havent had any problems yet.. i bout to upgrade to 33's jus take it easy. jus remember u may be drivin a gernade with the pin pulled..
4.0
I6
ARB snorkle
307 -> 411 gear swap
lock rite locker on the dana 35
33 x 12.50 Mickey Thompson radial MTZ
4.5" Rubicon Express heavy duty Suspension Lift
currie boomerang shackles
8,000 lbs. Winch
bikini top
tonneau cover
pictures??
crazymon01 is offline
post #11 of 11 Old 05-01-2006, 01:08 AM
Alheim
Originally Posted by GrimJeeper91
Example 1:
Result: Snap
Example 2:
Result: Snap
Haha, excellent post GJ
'95 YJ 123bhp 4-banger powerhouse.
UPDATE: 2.5L ENGINE RETIRED; she was still running strong at 212,000mi.
4.0 swap in progress.
Alheim is offline
How Does the 6-speed Handle 33's w/3.73 gears? 1badxj TJ Wrangler Technical Forum 36 02-13-2010 03:14 PM
how will my jeep handle in the snow with a front auto locker? Rayne TJ Wrangler Technical Forum 11 01-18-2010 09:22 PM
Detroit locker Dana 35 w/4.56 and 33's yellowjp79 TJ Wrangler Technical Forum 31 06-15-2009 09:04 PM
dana 35, 33's would you add a locker? rollmeover YJ Wrangler Technical Forum 7 12-31-2003 09:39 AM
Can the 4-Banger Handle 33's? kdavis TJ Wrangler Technical Forum 14 05-27-2003 05:41 PM
