How wide is your front bumper? - Page 4 - JeepForum.com
post #46 of 68 Old 08-30-2014, 05:39 AM
superj
But tj bumpersare made as thick as a tin can. My jeep came with one and I couldn't do anything with it because it was so flimsy. I bought a used stock bumper and am running that.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #47 of 68 Old 08-30-2014, 08:04 AM
Mambo_Dave
Originally Posted by RICEKILA View Post
"tanks"
Wait till you see where I put my ax --
I'm already considering using your tab-through-shovel-head idea (though not on the front - my pass-through tube is blocked by the bumper mount)... so please do PM me if you post your ax idea somewhere else - or I guess just put it in this thread
Mambo_Dave is offline
post #48 of 68 Old 08-30-2014, 09:19 AM
gtg413i
2003 WJ
Mine are chopped to the frame. Nice and thin.
Brian's Black Betty Build:
gtg413i is offline
post #49 of 68 Old 08-30-2014, 10:32 AM
Richard_
JeeperDon do you any more pics of your bumper ?
Richard_ is offline
post #50 of 68 Old 08-30-2014, 12:59 PM
RICEKILA
I might bolt it to the side over the rear tire or finding a TJ rear bumper --- make it a air tank and mount it on the face or on top - maybe / kinda / sort-of
I was once a tree house.
I lived in a cake.
But I never saw the way - the orange slayed the rake --
RICEKILA is offline
post #51 of 68 Old 08-30-2014, 03:19 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Here you go... The main plates making the box are 1/4" stock. The wings are 1"x3" 3/16" stock.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #52 of 68 Old 08-30-2014, 03:58 PM
bpounds
bpounds's Avatar
I like the idea of painting the tow hooks yellow. You can get hurt on those things, and having them stand out from the bumper is a good thing. Looks pretty good too.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is online now
post #53 of 68 Old 08-30-2014, 05:23 PM Thread Starter
snowplowdog
Thanks for all the responses & ideas. I think I'll chop it to about 54" & run it that way for awhile. If I like it I'll cap off the ends & paint everything. I would consider changing the bumper, but the bumper, frame, and winch plate, which was built using 1/2" plate steel, and are all welded together pretty solid and cutting it all off just isn't worth it.
On my last jeep I had replaced both bumpers with tube bumpers I had bought from Quadratec. I don't remember the brand but they were junk. 2 winters and both had rusted through. This thing is so heavy it would take 40 years to rust through.
Never attempt anything you don't want to have to explain to the EMT
snowplowdog is offline
post #54 of 68 Old 08-30-2014, 07:09 PM
JeeperDon
JeeperDon's Avatar
I think I found my next welding project! This is the rear bumper, have had it since 1998. It looks innocent enough when driving behind the Jeep, but at this photo angle I'm suddenly amazed it hasn't been a problem on the trail.
Since the Jeep is pretty tall, when working in the rear cargo area I have to straddle it. The hook pointing up has grabbed the crotch of my pants a few times, can be scary (especially when as you get older your pair of guy parts tend to hang down further).
Web Admin for
post #55 of 68 Old 09-01-2014, 11:12 AM Thread Starter
snowplowdog
Here are some before and after pictures. I cut 10" off each side of the bumper leaving it at 50". Now all that's left is to cap off the ends and then I can unbolt the winch and paint everything.
I also included a few pictures f the winch mounting plate and you can see why I don't want to try cutting it all off to put a different bumper on. I don't like the way the tow hooks look like theyre crowded by the gussets but I think I'll have to live with that.
post #56 of 68 Old 09-01-2014, 01:55 PM
JeeperDon
JeeperDon's Avatar
That big front face with the fairlead doesn't really do much on those outer edges. You could remove a couple inches off both ends of the face and not hurt any capability or strength.
Web Admin for
post #57 of 68 Old 09-01-2014, 03:58 PM Thread Starter
snowplowdog
I could cut about 3" off the drivers side but only about 1" off the passenger side. Awful lot of work to do it though, both the gusset and face are welded solid on both sides and it's 1/2" thick steel so I think I'll just leave well enough alone. It's bigger than it needs to be but theres enough room between the gusset and the hook to easily get a chain in there if need be so I can live with it. Maybe once I get the ends of the bumper capped and painted it won't bother me so much.
post #58 of 68 Old 09-01-2014, 07:42 PM
JeeperDon
JeeperDon's Avatar
I like to weld, so if it was me, I'd strip the whole thing down and start over. It's your Jeep, not the PO's any longer. As is, it's like buying a house and not painting over the old owners ugly colors.
Web Admin for
post #59 of 68 Old 09-02-2014, 12:08 AM
mike134
I kind of liked the looks of it when it was super wide. Made it look unique! Like you do a lot of ramming!
mike134 is online now
post #60 of 68 Old 09-02-2014, 10:50 AM Thread Starter
snowplowdog
Its a project I may consider when I have more free time but for right now with the hours I'm working, and bow hunting season almost upon us, I'm not going to be having much of that. I still have a list of other thing that need to be done before before I start heading up north every weekend to try to stick bullwinkle.
