How wide is your front bumper? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > How wide is your front bumper?
ORS4x4: New Product!Aluminum Quick Release Fire Extinguisher Mounts from ORS4xKinetic Recovery Rope from ORS4x4
Unread 08-25-2014, 09:07 PM   #1
snowplowdog
The PO of my Jeep decided to make his own front bumper.
I don't have a problem with it other than it seems to be a bit on the wide side for my taste. It looks to be cast iron pipe, welded in place with a strap welded around it from the top to the bottom of the framerail. It is solid and i pity the person that pulls out in front of me. I'm not going to take it off since it's on so solid and will outlast almost any bumper I could buy comercially. I do think I am going to cut it down close to the size of an OEM bumper, cap the ends, and smooth it out and paint it. Does anyone know how wide an OEM bumper is, or if you have one on your rig measure it? Thanks
Never attempt anything you don't want to have to explain to the EMT
snowplowdog is offline   Reply With Quote Quick reply to this message
Unread 08-25-2014, 09:22 PM   #2
Reno72
Reno72's Avatar
Man, that's a cattle pusher. Stock metal without end caps is 54", my new one is "50". I'd get it at least inside the tires.
Reno72 is offline   Reply With Quote Quick reply to this message
Unread 08-25-2014, 10:07 PM   #3
Fuzzy_Wuzzy
How wide is the front of the chassis? Mine is just a piece of channel iron welded between there.
Fuzzy_Wuzzy is offline   Reply With Quote Quick reply to this message
Unread 08-25-2014, 10:13 PM   #4
ODB-XK
I'd cut that down to inside the tries as well. When I pulled my bumper off to weld some stuff on it the Jeep actually looked better without it LOL.
ODB-XK is offline   Reply With Quote Quick reply to this message
Unread 08-25-2014, 10:32 PM   #5
jbolty
jbolty's Avatar
This is about 5" too wide on each side. I'm always snagging it in tight turns.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote Quick reply to this message
Unread 08-25-2014, 10:56 PM   #6
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Mine is 42" at the widest point then cut on a 45* angle
'89 YJ The Smurf Build Thread
'99 XJ Black Betty Build Thread
Tom95YJ is online now   Reply With Quote Quick reply to this message
Unread 08-25-2014, 11:06 PM   #7
Mambo_Dave
Based on my personal experience with wheelin', I think it highly depends on where you wheel.
jbolty, above, for example - he's in a drier area with rocks to climb. I can see having both front tires available to grab rocks.
On the other hand, I used to wheel in Pennsylvania on the slick clay and rolling hills. I've slid down and damaged the front of the vehicle on a tree as I skidded by... so for those areas I'd want full frontal protection. The wheeling was more mud based than rock-crawling based.
The Pennsylvania experiences are why I bought this front bumper. The advantage it has over you cast iron pipe is that it does come up higher on the sides to expose the front tires. Even if it was as wide as your pipe bumper, it wouldn't really get in the way much more for actual wheeling.
Obviously the cast iron pipe can protect your rig pretty well, but it was also done as a cost- and/or time-saving measure, so if you aren't happy with it ... cut it.
I think you need to resize your picture so that it fits into the forum, first , and then consider what all there is to hit in Wisconsin, and if it makes sense to keep the entire width or that style of bumper at all.
Mambo_Dave is offline   Reply With Quote Quick reply to this message
Unread 08-25-2014, 11:13 PM   #8
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Bumper?
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
My Jeep
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
www.rubiconramblers.com
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 02:43 AM   #9
zte87
GIVE IT THE ONION
zte87's Avatar
Mines just right IMO!
zte87 is online now   Reply With Quote Quick reply to this message
Unread 08-26-2014, 07:33 PM   #10
RICEKILA
A little shorter than my shovel --
I was once a tree house.
I lived in a cake.
But I never saw the way - the orange slayed the rake --
RICEKILA is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 08:14 PM   #11
snowplowdog
Looks like I am going to cut it off just outside the framerails....now what to use to cut cast iron...
Unread 08-26-2014, 09:01 PM   #12
Tom95YJ
Tom95YJ's Avatar
. I used a sawzall
Unread 08-26-2014, 09:32 PM   #13
RICEKILA
Originally Posted by Tom95YJ View Post
. I used a sawzall
Ditto
I lived in a cake.
Unread 08-26-2014, 09:49 PM   #14
Mambo_Dave
Agree with the Sawzall. I've tried other methods - even a diamond bladed gas saw... Sawzall was faster and easier.
Unread 08-27-2014, 06:47 AM   #15
Shadownwpa
Like said above, it depends on how much you think can snag between the tire and frame. In PA there's alot, so I brought mine out about 1/3 the way across the tread.
http://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
Shadownwpa is online now   Reply With Quote Quick reply to this message
