How to truss a Dana HD 44 or "44A" - Page 3 - JeepForum.com
post #31 of 33 Old 08-22-2012, 06:26 AM
MLJeeper
MLJeeper's Avatar
Originally Posted by tonymartin View Post
So did you change the front gear ratio to match the rear? I ask because you have said that this was a 3.73 and your stock D35 was a 3.07, so I take it you had to either change the front ratio or keep it at 3.07 (Which I'm not sure would work, would it?)
Nice work though, and it's held up so it must be half decent.
He mentioned mothballing the front driveshaft if he had to throw the 35 back in.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #32 of 33 Old 08-22-2012, 09:44 AM Thread Starter
Opihi59
from here it gets rough
Opihi59's Avatar
I changed out my front axle gearing as well to a matching 3.73 of course. Yes, there is no debate that they need to match.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #33 of 33 Old 08-22-2012, 10:52 PM
tonymartin
I thought as much. Didn't think it would work otherwise.
Thanks Opihi
93 Renegade|Home made add a leaf (by PO, changing out soon)|Rancho adjustable shocks|31x15 BFG AT's|15" GT alloys|AFE Headers|Red SpiderWebShade Trail Cage|Free Sense of Adventure
tonymartin is offline
Dana 30 with ARB locker qurstion "FLUID" gottkts YJ Wrangler Technical Forum 6 01-23-2010 10:38 AM
Clanking Driveshaft "ring" - Dana 35 + NP231 Panici TJ Wrangler Technical Forum 30 05-06-2009 07:37 PM
Blind Date: you meet a girl named "Dana". What do you expect of her? rain-gler Wrangler General Discussion 41 02-10-2009 07:28 PM
Help Deciding "how" to build my dana 44 and dana 60 Big-n-Broke-YJ YJ Wrangler Technical Forum 5 08-12-2006 06:03 PM
98 sahara with dana 35 rear. Which locker kit? Is it a "C" rupert14 TJ Wrangler Technical Forum 8 09-05-2003 09:55 AM
