How to truss a Dana HD 44 or "44A" - Page 2 - JeepForum.com
post #16 of 33 Old 04-04-2009, 11:53 PM
shaggyjim
Cautiously Optimistic!
shaggyjim's Avatar
What was the weight like compared to the Dana 35?
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
shaggyjim is offline
post #17 of 33 Old 04-05-2009, 12:33 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
It should hold up okay for you there on the islands.
Edited my post due to corrections.
Joe Dillard is offline
post #18 of 33 Old 04-05-2009, 01:13 AM Thread Starter
Opihi59
from here it gets rough
Opihi59's Avatar
We have been imprinted into HP meaning High Pinion. I really don't know what it means in this particular application. I read up on it from this thread http://www.arcticoffroad.com/forum/s...p?t=826&page=1 But now I can't get that linky to worky, so I am lost. I'll try to troll thru the ZJ forum more on this and see if I can come up with more info, but that was the nomenclature that was used in this axle in the online stuff I read about.
Edited the thread, I had mistakenly put in HP D44 instead of the proper nomenclature HD D44
SHAGGYJIM I had to deadlift these axles and get them in and out of my Truck by myself, they seemed to be more or less equivalent in weight, but that is just me manually grunting them around. I can only say they are heavy (note sig line) It seemed to not weigh as much as the D30 I just had to haul down a flight of concrete steps today, by myself no less, and put in the cellar. I'll have to dig around and see if anyone knows the weight of a fully loaded 44A, D30 and D35.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #19 of 33 Old 04-05-2009, 01:33 AM
Joe Dillard
Maybe it means - Hawaii Proven.
post #20 of 33 Old 04-05-2009, 01:45 AM Thread Starter
Opihi59
Opihi59's Avatar
I am sending PM to another Jeeper who may be able to tell me how to make that link above work......something is missing.
Opihi59 is offline
post #21 of 33 Old 04-05-2009, 01:52 AM
Goobersbro
dude i know what you mean about having to carry those axles around dang there heavy. Nice work i really like how you did the skid and it all looks clean very nice
My marshmallow build
Goobersbro is offline
post #22 of 33 Old 04-05-2009, 02:00 AM
Joe Dillard
I went to that website & tried to search....I came up with this thread which was the only thread mentioning a D44:
http://www.arcticoffroad.com/forum/s...ight=Dana+HP44
post #23 of 33 Old 04-05-2009, 02:02 AM Thread Starter
Opihi59
Opihi59's Avatar
I'll find it......I know I will, I'm pretty sure it was Arctic. When I do, I'll post it up for everyone.
Opihi59 is offline
post #24 of 33 Old 04-05-2009, 02:04 AM
Joe Dillard
Cool - in the meantime, enjoy your new rear axle.
post #25 of 33 Old 04-05-2009, 12:33 PM Thread Starter
Opihi59
Opihi59's Avatar
Just curious, but what did you mean when you used the term "Dana HP44"?
More specifically, what's the HP part mean?
Joe D--Ummmm, I messed that up. I went back thru some of my original notes on this, it is HD not HP. Of course, I don 't know what the HD stands for. I'm still trying to find a better reference link as the Arctic link I had used for most of my initial research appears to be no longer there.
So......for the benefit of others being able to properly thread search, could you use your special moderator mad ninja skills and change the misleading (sorry, didn't mean to) title of my thread from HP to HD?
Opihi59 is offline
post #26 of 33 Old 04-05-2009, 12:39 PM Thread Starter
Opihi59
Opihi59's Avatar
Originally Posted by shaggyjim View Post
I have never been into a 44A bro but I have been told that the internals are not the same as other 44's. Have you looked into this? What did you find out?
Apparently the ring is 8.5 like other 44's, the pinion is heavier though, more like a 60. There is way less available in the aftermarket as far as lockers, Aussie made one, but it is in limited production and expensive. In the online article I am still searching for, there was mention of a South African manufacturer that made a different type locker for it, but that article is escaping me still. Eventually someone from the ZJ forum will pipe in with some info on this. Otherwise, I'm still searching....
Opihi59 is offline
post #27 of 33 Old 05-31-2009, 12:51 AM
MLJeeper
MLJeeper's Avatar
Excellent example of working with what you got. Nice job.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #28 of 33 Old 01-24-2010, 07:50 PM
redrubikee
1972 C104
Im pretty sure its just the aussie out there for the d44a, somewhere I read that the axle shafts are larger, but dont take my word for it. I went to the aussie site and they list for $399. Anyway nice work with the truss!
redrubikee is offline
post #29 of 33 Old 08-22-2012, 01:05 AM Thread Starter
Opihi59
Opihi59's Avatar
So I just saw this thread linked in another post, and figured I'd chime in with the promised followup for inquiring minds. I have over 30K miles since on this axle, it has given me no problem, but then again I don't run The Hammers or Moab every weekend. I haven't felt the need to find an 8.8 or a steel 44 as they are hard to come by. I did see a pair of Scout axles come and go, and a Vintage Grand Wagoneer front/rear as well. I have picked up the Jeep many times with a floor jack under the Trussed/Skidded aluminum pumpkin without concerns, so it is holding up well for me. I figure I'll wheel it til I break it, then Jackstand it and drive one of the other 4 vehicles in the stable until I find another axle, or toss the orig 3.07 D35 back under it and put the front shaft in mothballs. Mothballs that is until I come up with a replacement. It's meeting my needs and I'm not about to ship a custom built Currie out here. Until I win the Lottery.
Opihi59 is offline
post #30 of 33 Old 08-22-2012, 01:52 AM
tonymartin
So did you change the front gear ratio to match the rear? I ask because you have said that this was a 3.73 and your stock D35 was a 3.07, so I take it you had to either change the front ratio or keep it at 3.07 (Which I'm not sure would work, would it?)
Nice work though, and it's held up so it must be half decent.
93 Renegade|Home made add a leaf (by PO, changing out soon)|Rancho adjustable shocks|31x15 BFG AT's|15" GT alloys|AFE Headers|Red SpiderWebShade Trail Cage|Free Sense of Adventure
tonymartin is offline
Dana 30 with ARB locker qurstion "FLUID" gottkts YJ Wrangler Technical Forum 6 01-23-2010 11:38 AM
Clanking Driveshaft "ring" - Dana 35 + NP231 Panici TJ Wrangler Technical Forum 30 05-06-2009 08:37 PM
Blind Date: you meet a girl named "Dana". What do you expect of her? rain-gler Wrangler General Discussion 41 02-10-2009 08:28 PM
Help Deciding "how" to build my dana 44 and dana 60 Big-n-Broke-YJ YJ Wrangler Technical Forum 5 08-12-2006 07:03 PM
98 sahara with dana 35 rear. Which locker kit? Is it a "C" rupert14 TJ Wrangler Technical Forum 8 09-05-2003 10:55 AM
