How to truss a Dana HD 44 or "44A" - JeepForum.com
post #1 of 33 Old 04-04-2009, 09:16 PM Thread Starter
Opihi59
from here it gets rough
Opihi59's Avatar
There will be many disclaimers here, first off I want everyone to realize I live on a small island in the middle of the Pacific Ocean, the square mileage of my particular island is likely smaller than the size of the COUNTY you live in. The things I can get for my Jeep are limited then to what I can find in my backyard, it is very limited, and shipping anything out here larger than a maxi pad is cost-prohibitive. The Dana HD44, AKA the 44A--A for aluminum--has an aluminum center section. I don't know why Chrysler decided to do this to us, but they came this way on Grand Cherokees. The axle shafts themselves are stout, they have disc brakes. I wanted to change from my 3.07 to 3.73 for my own mild purposes, an axle swap was the route I took. Grand cherokees have coils, YJ's have leaf springs. Lotta things to change. While the ZJ clan wheel well enough on these, there are reports of damaging the alum housing by jacking up the rear of the jeep with a floor jack under the diff, and carrier bearing issues from flexion in the housing. A 3.73 Dana 44A came available before an 8.8 so I went with it. In order to strengthen this, I decided it would be fun to make a truss. This is simply how I did it, yeah, it can be a shovel to hang up on rocks (I am a mild wheeler) It would be more outta the way on top of the axle than underneath, but remember steel is designed to take stress best in tension rather than compression. AND, I can always swap to another axle if one comes available--I am patient.
First off--this is what I started with, only I remember it was in better focus...
Spend a little time cutting everything off with a cutoff wheel and you get something like this:
Carefully make a cardboard template:
Draw it out on 1/4 plate steel, and cut out with your angle grinder/thin cutting wheel, and some patience:
And you get this, cut another for the other side
Then tack them in place with a few spotwelds
MORE TO FOLLOW
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #2 of 33 Old 04-04-2009, 09:25 PM
shaggyjim
Cautiously Optimistic!
shaggyjim's Avatar
I have never been into a 44A bro but I have been told that the internals are not the same as other 44's. Have you looked into this? What did you find out?
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
shaggyjim is offline
post #3 of 33 Old 04-04-2009, 09:25 PM Thread Starter
Opihi59
Opihi59's Avatar
Next you need to bend up a hoop from some 2" 1/4 strap steel. With the help from the static weight of my handy 86 Yota, I got it made into the proper curvature
Then weld the strap in place
Then of course fashion/cut out a skidplate for the diff
Then struggle mightily to make a hoop, this is to go between the skid plate and encircle the pinion, it prevents the front of the skidplate getting torn off.
And you end up with something like this
Of course I had wire wheeled all the grime off the axle, and painted it to prevent rusting up while I was fabricating, looks better as well under the Heep.
MORE TO FOLLOW
Opihi59 is offline
post #4 of 33 Old 04-04-2009, 09:37 PM Thread Starter
Opihi59
Opihi59's Avatar
I read up a lot of information on the 44A from the Arctic offroad webpage, this axle came stock on V8 Grand Cherokees. I claim no special expertise on this particular axle, it's just what I managed to find on my island. I'll likely edit in a few more pictures. Next step after trussing was to put in my SYE, set pinion angle, weld perches and shock tabs, install, bend up brake lines, make adaptors for flex brake lines, fab up ebrake cables, etc--material for someone else's writeup.
At any rate, I have a few hundred miles on this now, everything seems to be doing quite well, and I'm happy enough with it. Since Rusty was looking for some "how to" threads, I decided to put this one in just in case it may be helpful to someone.
Opihi59 is offline
post #5 of 33 Old 04-04-2009, 10:37 PM
shaggyjim
shaggyjim's Avatar
Looks sick bro! I cant wait to see it on the Jeep. As long as its working I say its a good swap!
Jim...
post #6 of 33 Old 04-04-2009, 10:44 PM
Alvy
Nice clean job, looks great. At a quick glance it almost looks like an 8.8. Looks like tubes and center are plugged to hold them together as well. Question, being that the tubes and center section are dissimilar metals, can they not be welded like most do to their 8.8's?
1993 YJ, AX15, 4.0L, 8.8 LSD w/3.73's, Lock-rite locker in front, S.O.A. JB4x4 high steer bracket, BrandonYJ 1" Booms, Rugged Ridge SS S.Y.E. XJ drive shaft, 35x12.50 BFG KM2's, Chevy Cavy seats, woods camo paint, 200,000 miles and still goin strong!
1993 Cherokee Country AW4,4.0L, 3.55's, 4" blocks in back, 4" TJ springs front, 31x10.50 BFG A/T, Ford Red paint, recently finished with 4wd conversion
Alvy is offline
post #7 of 33 Old 04-04-2009, 11:23 PM
shaggyjim
shaggyjim's Avatar
Ok after looking at your photos again I just gotta know....... Whats with the bar code on the pinion bearing support?
Jim...
post #8 of 33 Old 04-04-2009, 11:31 PM Thread Starter
Opihi59
Opihi59's Avatar
No, you can't weld the tubes into the alum housing like it is popular to do on 8.8's....I'm not quite sure/certain of the technique they use to hold the tubes in. It looks like a hole is drilled/cast into the alum in several places where the steel tubes are stuffed in, then a weld is built up from the steel into the alum. Doesn't weld them together, it just fills the hole. Either that or superglue.
Opihi59 is offline
post #9 of 33 Old 04-04-2009, 11:32 PM Thread Starter
Opihi59
Opihi59's Avatar
The bar code was on it when I got it, I just cleaned the road salsa off it, prepped around it and put masking over it when I painted the axle. I figured it may mean something to someone at some point, maybe even me, so I "preserved" it.
Opihi59 is offline
post #10 of 33 Old 04-04-2009, 11:34 PM
shaggyjim
shaggyjim's Avatar
OCD man I love it!
Jim...
post #11 of 33 Old 04-04-2009, 11:44 PM Thread Starter
Opihi59
Opihi59's Avatar
I didn't take any photos of it in, but this one you can see the skid, and skid hoop. Seems it showcases the CV shaft more though. Suppose I'll have to take some more photos before too long.
Fixin' to roll it in here, it's upsidedown in the photo of course.
Opihi59 is offline
post #12 of 33 Old 04-04-2009, 11:48 PM
lclark2074
is that a pulse or a short arc welder you got
lclark2074 is offline
post #13 of 33 Old 04-04-2009, 11:50 PM Thread Starter
Opihi59
Opihi59's Avatar
Millermatic 180 Mig Argon, etc. Wife said, sure...you can buy a welder.....
Opihi59 is offline
post #14 of 33 Old 04-04-2009, 11:51 PM Thread Starter
Opihi59
Opihi59's Avatar
OCD man I love it!
Yeah, and no matter what they say, the meds don't help
Opihi59 is offline
post #15 of 33 Old 04-04-2009, 11:52 PM
93jeepyj
Nice work, looks good. I must say this is a first Im interested to see how it hold up.
93jeepyj is offline
Dana 30 with ARB locker qurstion "FLUID" gottkts YJ Wrangler Technical Forum 6 01-23-2010 11:38 AM
Clanking Driveshaft "ring" - Dana 35 + NP231 Panici TJ Wrangler Technical Forum 30 05-06-2009 08:37 PM
Blind Date: you meet a girl named "Dana". What do you expect of her? rain-gler Wrangler General Discussion 41 02-10-2009 08:28 PM
Help Deciding "how" to build my dana 44 and dana 60 Big-n-Broke-YJ YJ Wrangler Technical Forum 5 08-12-2006 07:03 PM
98 sahara with dana 35 rear. Which locker kit? Is it a "C" rupert14 TJ Wrangler Technical Forum 8 09-05-2003 10:55 AM
