How-To: TJ Axle Shaft Conversion - Page 7 - JeepForum.com
 1Likes
post #91 of 117 Old 11-13-2010, 08:35 PM
timatoe
timatoe's Avatar
Ohhh, gotcha, you were referring to smoothing the shaft itself for the seal. I think I misread it the first time.
timatoe is online now
post #92 of 117 Old 02-08-2011, 01:07 AM
two_much_talk
wish I would have found this sooner !!!
two_much_talk is offline
post #93 of 117 Old 05-05-2012, 02:41 PM
mitchs1224
question about the seals? i looked up the seal from napa # (11800) thats referenced on here, as well as the one from quadratech refrenced in another thread and they seem to be very diff. the one from napa looks like a thin o ring type seal and the one from quadratech that is recommended looks like a sealed bearing type oil seal any idea which one is right?
mitchs1224 is offline
post #94 of 117 Old 05-05-2012, 03:35 PM
NHfireLJ
NHfireLJ's Avatar
I'm pretty sure this has been cover numerous times in the thread, anyhow...
There is no seal on the passenger side differential with a 2 piece shaft, the seal is down by the disconnect , so when you install the one piece shaft you now need a seal on the passenger side diff... the axle tube isn't machine for a seal there (so there is no lip) in the tube, so the napa 11800 fits perfecly in there, just tap it in a 1/4 -1/2 inch or so...
Trust us, just get the Napa 11800, it'll work... There is also no need for a seal down by the disconnect now...
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #95 of 117 Old 05-05-2012, 04:50 PM
wayno32m
wayno32m's Avatar
He speaks the truth the NAPA 11800 (custom seal,kinda) fits perfect in the passenger side it is different from the (stock) drivers side . I did this MOD and it works
wayno32m is offline
post #96 of 117 Old 05-24-2012, 07:16 PM
mitchs1224
thank you!
i would like to thank jeep forums and everyone who answered my questions over the last few weeks, today i did the solid axle conversion and with the exception of a couple small brain fart's that where totaly my fault, the job went great, i pulled the carrier seated the new seal NAPA 11800!!!! , and replaced the drivers side seal while i had it apart, none of this would of been possible with out all the great info i found on here. the research i was able to do was irreplaceble!!
post #97 of 117 Old 03-19-2014, 03:30 PM
XJ93
Just because I plan on doing this myself in a couple weeks, the plastic "slinger", is it really needed? Not sure if $8 shipping is worth it for a $2.99 part if it isn't needed. Could I just put a seal on the end of the tube and call it good?
XJ93 is offline
post #98 of 117 Old 03-22-2014, 08:51 PM
Flajeeper1
1987 YJ Wrangler
Yes, Alloy USA makes axles seals for then end of the tubes. They have zerk fittings and help to keep water and mud out of the tubes.
http://www.4wheelparts.com/Drivetrai...&t_pn=ALY11103
Flajeeper1 is offline
post #99 of 117 Old 01-03-2016, 08:04 AM
mustanggarage
mustanggarage's Avatar
just FYI the pictures on this thread are not working. I appreciate the time you took to put this thread together and I still found useful information from the written parts. It is too bad I can't see the pics it would make it even better. but again thanks for doing the work of writing up the conversion.
My yj:
mustanggarage is offline
post #100 of 117 Old 06-16-2016, 03:17 PM
ThatGuyCollin
Does anyone have pictures on this? If I do this could I use the "outer piece" from my current axle. I am referring to the part that goes in the wheel bearing and is connected to the TJ axle shaft by the U-joint.
94 YJ 2.5 w/ 33x12.5's, 4.88s
ThatGuyCollin is offline
post #101 of 117 Old 06-16-2016, 03:53 PM
mustanggarage
this is where I did mine. I took some pictures, and did a bit of a write up on it. it starts towards the bottom of the page.
http://www.jeepforum.com/forum/f22/j...69/index5.html
as far as using your outer axle shaft my recommendation is to use the tj shaft and ujoint because it is stronger than the pre 95 ujoint. why do you want to use your outer shaft anyway were you not able to find a complete axle? because you can easily find them on ebay. you can swap in a 270 x ujoint if you decide to use your outer shaft. I just bought new shafts with new ujoints all as a unit.
My yj:
post #102 of 117 Old 06-16-2016, 05:01 PM
ThatGuyCollin
I was hoping to have matching u-joints without switching the driver side axle shaft. So the 270x works with a TJ inner and a YJ outer? Why does this work if they are different sizes?
post #103 of 117 Old 06-17-2016, 07:13 AM
mustanggarage
I know you can buy a ujoint for a 95 wrangler and swap it into a 90 wrangler. I did this on mine. I am not sure if mixing the shaft ends will work. if you want the same size ujoints, one option would be to use a non CAD cherokee shaft. pre 95 they have the same ujoints. I know the 95 and tj ujoints are the spicer 297 x. I wrote it wrong above. they are supposed to be stronger. I don't know if you can just swap the inner shaft or not. but it is pretty easy to swap both to the tj axle and then they would match. you can find the drivers side shaft on ebay for about 50.00 I THINK the tj ujoint will work in the early shaft but I am not sure about that. the reason I think that is when I went to oreilly to get my new ujoint they sell one that it is for 87-06 wranglers. so they must measure the same. some have a grease zerk, some don't. I think the ones without the zerk are stronger. sorry I wish I was more sure and could help you more, on this but I only know what I have done.
My yj:
post #104 of 117 Old 06-17-2016, 07:35 AM
ThatGuyCollin
I am just going to get the shafts for both sides. It is $30 from a local pull-a-part for everything. Then I will just put in new u-joints and call it good.
post #105 of 117 Old 06-17-2016, 08:32 AM
mustanggarage
that is what I would do. be aware the tj bearing hub will not work on the yj. once you get it on and put the brake disk on and tighten the lug nut, the wheel won't turn. so you have to use the yj hub. also, if most places tell you to use that napa 11800 seal. I found the EAS seal that I put in mine, I put the number on my page. anyway that seal is much easier to use.
My yj:
TJ axle shaft conversion in YJ YJ_Aaron YJ Wrangler Technical Forum 28 05-26-2011 11:50 AM
front outer axle seals and axle shaft runout... mudb8 TJ Wrangler Technical Forum 32 01-02-2011 12:49 PM
XJ shaft conversion question czjeeper YJ Wrangler Technical Forum 11 12-20-2009 06:35 PM
axle shaft touching pinion shaft kit05 TJ Wrangler Technical Forum 7 08-22-2009 12:42 PM
TJ axle shaft conversion? Lavacrawler YJ Wrangler Technical Forum 16 01-02-2004 09:39 AM
