How-To: TJ Axle Shaft Conversion - Page 6 - JeepForum.com
 1Likes
post #76 of 117 Old 11-08-2010, 02:26 PM
alex_c
Went to NAPA and they didn't have the part ANYWHERE, nor did any other parts stores.
Not Any Parts Anywhere...lol
and yeah, I read about 10 posts saying the 11800 seal didn't work for them, so pound sand noobie
I found one that works though
alex_c is offline
post #77 of 117 Old 11-08-2010, 04:43 PM
Djsthe1
Originally Posted by alex_c View Post
I have a late 80's XJ axle with disconnect going into my TJ. Anyone have confirmed part numbers for the seals? I keep getting conflicting information everywhere. Searched extensively and read the Stu Offroad article.
Going by this post I'm wondering why you are posting in this thread looking for a seal. This thread is about the total opposite of what you are doing, its about going from a disconnect to a full shaft from a TJ or XJ. So if you have a TJ and are looking for advise to do the opposite maybe you should look in the TJ forums but my guess is that you can not put a split shaft into a TJ axle because you do not have the disconnect fork or even the space to install the sleeve to engage the two shafts together.. But.. if you are just swapping the full axles, then you would just have to ask any counter person for the seal that fits the late 80's XJ axle tube.. right?
Djsthe1 is offline
post #78 of 117 Old 11-09-2010, 03:58 PM
alex_c
I don't think you understand. I'm putting the disconnect axle into my TJ, but using the TJ shafts and knuckles. Why the hell would I want to put a split shaft into a TJ housing? That's ludicrous. Why don't I pull my 4.0 and put in a 2.5 while I'm at it?
I am essentially doing exactly what is being discussed here, the only difference is that the axle will be under a TJ, not an XJ.
alex_c is offline
post #79 of 117 Old 11-09-2010, 07:32 PM
Djsthe1
Your right.. I don't understand, why would you be swapping axle tubes..
Djsthe1 is offline
post #80 of 117 Old 11-09-2010, 08:13 PM
timatoe
timatoe's Avatar
He's swapping the entire D30 into his TJ, probably because the XJ and YJ D30's are high pinion and the TJ is low pinion.
timatoe is offline
post #81 of 117 Old 11-09-2010, 09:07 PM
Djsthe1
Ahhh good point, just not used to TJ guys wanting to install YJ stuff on their jeeps, usually its them trying to prove that they are better in some way..
Djsthe1 is offline
post #82 of 117 Old 11-10-2010, 12:22 PM
alex_c
IT'S FROM AN XJ
LOL
alex_c is offline
post #83 of 117 Old 11-10-2010, 02:18 PM
Djsthe1
OK, Alex... please explain to us because clearly we don't understand...
Djsthe1 is offline
post #84 of 117 Old 11-10-2010, 06:52 PM
Bigwilly
Seems as though he is in his own little world!
Bigwilly is offline
post #85 of 117 Old 11-10-2010, 07:12 PM
Djsthe1
Yea, I understand its from a XJ its still a VAD system, why install it in a TJ then use the full axle shaft? And how he stated Napa didn't have the 11800 seal "ANYWHERE", Napa just like any other parts store is more than gladly order it for you annnnd any other part store can cross reference the part number for you.. Well thats how I got mine and it works fine..
Djsthe1 is offline
post #86 of 117 Old 11-11-2010, 12:06 PM
mudmovers
My friend is doing this conversion right now (it's being done to an XJ, but the tech is the same). You are correct, the housing is not machined for a seal to be installed in the center section. The seal will fit in the CAD housing, as the original tech article explains. If you smooth the area of the axle where the seal will ride, it should be fine. He used a fine grit sanding disc and smoothed out the rough stuff, and the polished with an emery cloth to get it more like a machined sealing surface. I anticipate that it will seal fine, and there is less headache of dealing with the removing the pumpkin. Time will tell for sure! Good article to the OP, btw, and thanks for the tip about the drivers side seal being correct...I found this forum through searching for information about what seal to use.
Jon
mudmovers is offline
post #87 of 117 Old 11-11-2010, 07:36 PM
alex_c
I went to napa with that number, and they did not have one that matched that part number in any of the locations in my area. They could order one but it would take weeks. I went elsewhere and found something that worked.
I'm putting a XJ HP d30 into my TJ for a few reasons:
High pinion = better DS clearance and drive line angles.
No crush sleeve = Easier to change pinion seals/work on the axle in general
4.10 gears = Could not find a TJ axle available for a good price that had 4.10 gears to match my 8.8
Reverse cut gears = Gears "pull in" when being driven, as opposed to a low pinion setup that "pushes away". This results in a stronger R&P setup.
I couldn't find one with 4.10 gears without the VAD. I removed the vacuum actuator, shafts, knuckles etc from the housing, made a block-off plate and I will replace everything save the housing and gears with TJ stuff. Why? So my unit bearings and brakes are TJ parts, not XJ stuff. This saves me from having to buy all new parts. I COULD use a cable disconnect system and retain the two piece shafts, but I would rather not spend the $250, and I like the idea of less moving parts. Also, my TJ shafts use bigger U-joints than the XJ shafts that came with the axle assembly.
...why would I NOT use the full axle shaft when my jeep was never set up for a VAD system to begin with?
alex_c is offline
post #88 of 117 Old 11-11-2010, 08:10 PM
timatoe
timatoe's Avatar
Originally Posted by mudmovers View Post
..... You are correct, the housing is not machined for a seal to be installed in the center section. The seal will fit in the CAD housing, as the original tech article explains......
That's all fine, but if you put a seal in the CAD section the axle shaft will destroy it, as it's not machined to have a seal in that spot, but it is at the pumpkin. Same process applies at that location though if the seal won't quite fit, light sanding/grinding etc...
timatoe is offline
post #89 of 117 Old 11-11-2010, 08:39 PM
mike_breaker_5
a relatively simple task has become a tragic train wreck. it's not brain surgery. just relax, drink a beer or 12, and just goose-fraa-baa.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #90 of 117 Old 11-13-2010, 01:00 PM
mudmovers
Your point is correct, Timatoe, if no other precautions are taken. But my hope/expectation is prepping the axleshaft in the area where the seal will now sit, if installed in the CAD housing, will allow a good seal without the additional headache. Will report back after a bit to see how it goes My only concern is about runout along the length of the axleshaft and having a seal in the middle, rather than at either extreme end. The seal fits nice on the area the smoothed out where it will ride in the middle, but runout could be the cause of failure, if it happens.
5 in YJ? ....yup!
TJ axle shaft conversion in YJ YJ_Aaron YJ Wrangler Technical Forum 28 05-26-2011 11:50 AM
front outer axle seals and axle shaft runout... mudb8 TJ Wrangler Technical Forum 32 01-02-2011 12:49 PM
XJ shaft conversion question czjeeper YJ Wrangler Technical Forum 11 12-20-2009 06:35 PM
axle shaft touching pinion shaft kit05 TJ Wrangler Technical Forum 7 08-22-2009 12:42 PM
TJ axle shaft conversion? Lavacrawler YJ Wrangler Technical Forum 16 01-02-2004 09:39 AM
