How-To: TJ Axle Shaft Conversion - Page 5 - JeepForum.com
 1Likes
post #61 of 117 Old 06-28-2010, 10:31 PM
FlexinYJ
10-4. sounds good to me. thanks
"If parts aint flyin, YOU AINT TRYIN!!" Morris Mountain ORV Park.
FlexinYJ is offline
post #62 of 117 Old 07-10-2010, 11:11 AM
Zangief
Hey guys, I was wondering is there any reason that you can not reuse the cad housing once a one piece shaft is installed instead of cutting and drilling a steel cover plate?
Zangief is offline
post #63 of 117 Old 07-10-2010, 11:29 AM
Djsthe1
Once you install the TJ axle shaft you really dont need it. I reused my cover and left the shift fork on just so that I would still have the 4wd light work on my dash, that is really all it does once its not used to move the sleeve to engage the 4wd. If that makes sense...
Djsthe1 is offline
post #64 of 117 Old 07-10-2010, 11:36 AM
Zangief
Cool I just mainly wanted to see if the cover staying in place had any negative effects. Until I can cut out and drill a cover for it. Sounds like u can
Zangief is offline
post #65 of 117 Old 07-10-2010, 02:53 PM
-Deepskyy-
My wires to the CAD unit had been cut, but I have no issues with the 4wd. I've had to make a trip all the way back from the trails on the front axle only, so I know it works fine. I reconnected the wires to see if I could get the 4wd light to come back on, to no avail. Sometimes when I am in 4lo it will come on, stay on for a while, then go back off. Its a bit sketchy that it has been down there for 17 years but it still works.
Are you finding the Jeep Forum helpful?
"I never saw such fighting since God made me. The Americans fought like demons"
-Lt. General Charles, Earl Cornwallis after the battle of Guilford Courthouse NC
Originally Posted by Outatime05 View Post
Females are a dime-a-dozen. Jeeps are forever. Easy choice. Be indispensible or be gone. :wave:
Originally Posted by jeepdavetj View Post
We are Jeepforum. We can do the unthinkable. We are Jeep strong. And head stubborn. We are. JEEPFORUM.
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Red Jeep #543
-Deepskyy- is offline
post #66 of 117 Old 07-15-2010, 08:55 AM
BlazerJeepCombo
So correct me if im wrong, but this is the seal and part number from napa.(i hope the pic is wrong).
Store Locator | NAPA Online
BlazerJeepCombo is offline
post #67 of 117 Old 08-06-2010, 06:51 PM
nlq
Were do you take the XJ axle shaft to get balanced and what would the ballpark cost be. and which axle seal# is used for the converstion? How do they balance the shaft? Thanks
nlq is offline
post #68 of 117 Old 08-06-2010, 09:33 PM
BlazerJeepCombo
^ Now thats a helluva newb post.
post #69 of 117 Old 08-06-2010, 11:55 PM
timatoe
timatoe's Avatar
You don't get the axle shafts balanced. You may need to get the front drive shaft balanced and any driveline shop should be able to help you out with that. If you don't have or know of a driveline shop in your area, go to a local truck stop and ask them.
timatoe is offline
post #70 of 117 Old 08-08-2010, 05:50 PM
Muddy One
I am trying to do this now and for the life of me I cant get the seal to go in. I have bought two seals, one from Napa and one from Advanced and neither will go in. I am trying to get them on the passenger side, inside the carrier and it is not working. I have a 95 yj and I cant get this to work. The one from advanced is a National part # 710068. The Napa is SKF part # 11899
"95 YJ
Join today
and ohiotrails.org
Muddy One is offline
post #71 of 117 Old 09-13-2010, 01:45 PM
alex_c
I have a late 80's XJ axle with disconnect going into my TJ. Anyone have confirmed part numbers for the seals? I keep getting conflicting information everywhere. Searched extensively and read the Stu Offroad article.
alex_c is offline
post #72 of 117 Old 09-20-2010, 09:01 PM
Bigwilly
Axle seal #11800 from NAPA! not to be a jerk but the # was posted about 10 times on this post!
NAPA #11800
NAPA #11800
NAPA #11800
Im a relative newbie and figured that out!
Bigwilly is offline
post #73 of 117 Old 09-20-2010, 09:26 PM
Djsthe1
And... Most places can cross reference Napa parts..
Djsthe1 is offline
post #74 of 117 Old 10-22-2010, 08:10 PM
Rallen
Can a person buy a new passenger side axle? Versus one from a salvage yard. If you can, which one would you order. Used parts are scarce out here, maybe a used one on the net is possible.
Rallen is offline
post #75 of 117 Old 11-07-2010, 10:02 PM
srhcherokee24
so when i pull the axle shaft out what do i have to do with the seal on that side im kind of confused on it.
people ask me why i like to do the thing i do to my jeep,
srhcherokee24 is offline
TJ axle shaft conversion in YJ YJ_Aaron YJ Wrangler Technical Forum 28 05-26-2011 12:50 PM
front outer axle seals and axle shaft runout... mudb8 TJ Wrangler Technical Forum 32 01-02-2011 01:49 PM
XJ shaft conversion question czjeeper YJ Wrangler Technical Forum 11 12-20-2009 07:35 PM
axle shaft touching pinion shaft kit05 TJ Wrangler Technical Forum 7 08-22-2009 01:42 PM
TJ axle shaft conversion? Lavacrawler YJ Wrangler Technical Forum 16 01-02-2004 10:39 AM
