How-To: TJ Axle Shaft Conversion - Page 2 - JeepForum.com
 1Likes
post #16 of 117 Old 02-15-2010, 07:45 PM
simpkijd
simpkijd's Avatar
Originally Posted by Fire1kubota View Post
I think you missed my question..it really wasn't about the seals, but the shafts....
can I just replace the passenger shaft? and not the driverside...
Thanks
Yes. I see no reason you cannot replace just the Passenger side.
One day my Jeep will be .....
simpkijd is offline
post #17 of 117 Old 02-16-2010, 11:03 AM
timatoe
timatoe's Avatar
You can replace just the passenger side, but then you'll have two different sized u-joints.
timatoe is offline
post #18 of 117 Old 04-13-2010, 04:14 PM
panther967
i was curious on how difficult was doing this swap process and is their anything i should or shouldnt do?? I also would appreciate some pics if u have them available?? thanks for your time..
panther967 is offline
post #19 of 117 Old 04-13-2010, 05:45 PM
iowajeepers
A couple things.
1. Late model XJ shafts are one piece and come with the bigger u-joints. In my area, they are easier to find than TJ shafts. That might help someone.
2. I did the same conversion (with XJ axles) and did get a mild leak on my DD. Nothing bad enough to check between gear oil changes though.
1994 YJ, 2004 WJ, 1976 C3, 2015 Slingshot, 2001 ZX6r
iowajeepers is offline
post #20 of 117 Old 04-13-2010, 05:56 PM
panther967
thanx for the info.. what years should i be able to use for shafts??
post #21 of 117 Old 04-13-2010, 06:42 PM
iowajeepers
97 or newer XJ
post #22 of 117 Old 04-13-2010, 06:48 PM
IP076
I'm going to a local yard and they have a 99XJ there that I'm hoping still has the axle shafts. They also have some grand cherokees, will any of those work?
IP076 is offline
post #23 of 117 Old 04-14-2010, 11:27 AM
IP076
Yeah, I'm an idiot...the Grand Cherokees are IFS...duh...
IP076 is offline
post #24 of 117 Old 04-14-2010, 12:42 PM
muddy93
1987 FSJ Wagoneer
Only the new grand's are IFS. I used to have an 02 grand, and it was SFA.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #25 of 117 Old 04-14-2010, 01:54 PM
SimonTuffGuy
[I'm That Good]
SimonTuffGuy's Avatar
I'm on the lookout! Thanks for the thread.
What did you do to make your 4WD light work again?
SimonTuffGuy is offline
post #26 of 117 Old 04-14-2010, 04:17 PM
Area.3.Fiftyone
Yes.........
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #27 of 117 Old 04-14-2010, 06:01 PM
IP076
Were they Dana 30s too?
Yeah, and did anyone worry about the light? or just say screw it?
IP076 is offline
post #28 of 117 Old 04-14-2010, 06:30 PM Thread Starter
H3RTCH
Live Free or Die.
H3RTCH's Avatar
There's a write-up somewhere on here about changing the vacuum actuated 4WD light over to an electric one. I'll see if I can dig it up.
EDIT: Found it! Its in this thread.
I have heard that ZJ's have CV joints, not u-joints. Yes they will work, but not as strong.
2004 Jeep WJ Grand Cherokee Overland - My DD
1988 Jeep MJ Comanche 4.0L - Dad's
1999 Jeep WJ Grand Cherokee Limited 4.0L - Mom's
H3RTCH is offline
post #29 of 117 Old 04-14-2010, 07:25 PM
SimonTuffGuy
[I'm That Good]
Perfect! Thanks for the information. Next junkyard trip I'll have to keep an eye out for some XJ's... Seems that any Wrangler which hits the yards NEVER have anything left on them... :P
post #30 of 117 Old 04-15-2010, 01:34 AM
timatoe
timatoe's Avatar
Just an FYI, I believe the larger U-joints started going in in '95, I pulled a D30 from a '95 and it has the larger joints.
timatoe is offline
TJ axle shaft conversion in YJ YJ_Aaron YJ Wrangler Technical Forum 28 05-26-2011 11:50 AM
front outer axle seals and axle shaft runout... mudb8 TJ Wrangler Technical Forum 32 01-02-2011 12:49 PM
XJ shaft conversion question czjeeper YJ Wrangler Technical Forum 11 12-20-2009 06:35 PM
axle shaft touching pinion shaft kit05 TJ Wrangler Technical Forum 7 08-22-2009 12:42 PM
TJ axle shaft conversion? Lavacrawler YJ Wrangler Technical Forum 16 01-02-2004 09:39 AM
