How to tell if you have an internal or external slave - JeepForum.com
post #1 of 8 Old 05-13-2013, 10:04 PM Thread Starter
killakeane
1987 YJ Wrangler
Very novice question, im new to the whole transmission chatter.. I was able to figure out I had an ax-15 but as far as if its an ax-15i or ax-15 i am not so sure. if someone has a photo of each types (i wasn't able to find any) than I'd know which i have.. I need to put in a new slave as you may see from my previous thread a few hours ago. Thanks for the help! cheers!
killakeane is offline
post #2 of 8 Old 05-13-2013, 10:30 PM
TSEJEEPERS
From the FAQ
BA-10/5 - Peugot 5-speed behind the I6 from '87-March 9, 1989
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 8 Old 05-13-2013, 10:45 PM Thread Starter
killakeane
1987 YJ Wrangler
I've got the ax-15 not the ba 10/5 previous owner must've swapped it also have an 88 engine I figured that out when I changed the starter.
Staten Island, NYC
87YJ 4.2L 5 spd with some cool stuff done to it.
ΜΟΛΩΝ ΛΑΒΕ
US Navy Jeep Club Hull# 231
Maritime Offroading Club
post #4 of 8 Old 05-13-2013, 10:53 PM
TSEJEEPERS
Ok then.
Again from the FAQ.
http://www.jeepforum.com/forum/f12/b...-unit-1112094/
Does your slave look like this?
post #5 of 8 Old 05-13-2013, 11:21 PM Thread Starter
killakeane
1987 YJ Wrangler
negative, its got one line running into it and a smaller one running out adjacent too it, going too assume thats internal?
post #6 of 8 Old 05-13-2013, 11:23 PM
TSEJEEPERS
Yep that is what mine looks like.
You are going to have to pull the transmission.
http://www.jeepforum.com/forum/f12/r...-4-0-a-807579/
post #7 of 8 Old 05-13-2013, 11:29 PM Thread Starter
killakeane
1987 YJ Wrangler
while i have the tranny out, recommend doing anything else too it?
post #8 of 8 Old 05-14-2013, 06:50 AM
daviddoughty1
1987 YJ Wrangler
At least put a new front seal ...
daviddoughty1 is offline
ax-15 manual , beginner , help needed , slave cylinder
