How strong is the factory driveshaft? - Page 2 - JeepForum.com
post #16 of 17 Old 10-19-2007, 07:50 AM Thread Starter
lturley
I appreciate the advice, I think I can make a wise decision now. I am going to leave the straps alone until something happens, I am a pretty conservative off-roader wehn compared to the dedicated rock-crawler. Thank you.
lturley is offline
post #17 of 17 Old 10-19-2007, 07:58 AM
E_ROCK
Originally Posted by dave_dj1
every time i've seen the straps break, so did one or more of those pesky little 8mm bolts that hold it to the yoke, not a trail fix! i had to drive home in front wheel and then take the yoke off, weld some washers over the broken remains in the yoke, then weld a nut to the washer and unscrew what was left......i have to have a front strap break though.
I started to carry pinion yokes for that same reason. We our club had similar problems this summer. It is pretty easy to just change out the yoke on the trail. It is a good idea to grind a little grove into the pinion nut and a matching mark on the pinion. That way you can get the pinion pre-load right back to where it was. This works for my D44s, but I am not sure what you do if you have axle with crush sleeves.
Then later at home, I have had good luck of putting the pinion in a vise and using small chisels to back the broken bolt out of the threads. Maybe I just have been lucky.
Garage Monkey, Wheeling Junkie
E_ROCK is offline
Factory front driveshaft lengths richmond1273 YJ Wrangler Technical Forum 1 07-08-2009 02:34 PM
Factory Driveshaft Boot clamp removal. Need Answer ASAP Wrangler_91 TJ Wrangler Technical Forum 2 04-18-2009 02:37 PM
Ford 8.8 and factory driveshaft Alabamaranger YJ Wrangler Technical Forum 7 09-22-2008 09:10 PM
factory cv style driveshaft? will_982 YJ Wrangler Technical Forum 7 07-18-2008 06:35 PM
How strong is the factory roll bar? stalbotvsp YJ Wrangler Technical Forum 27 03-27-2008 09:06 PM
