How strong is the factory driveshaft? - JeepForum.com
post #1 of 17 Old 10-18-2007, 06:11 AM Thread Starter
lturley
How many of you run the factory driveshaft with the u-joint straps? How important is it to install the u-bolts in place of the straps? You ever have the u-joint break the straps?
lturley is offline
post #2 of 17 Old 10-18-2007, 08:16 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
The factory drive shafts are just fine. Some have destroyed them but that was after significant rig mods. You can install ubolts on them but IMHO, I would rather have a Ujoint blow and take the straps off then dig into the drive shaft.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 17 Old 10-18-2007, 08:32 AM
grenMEG
So the driveshaft will most likely not be affected by anything balance wise, but depending on your pinion angle (the degree of your rear axle and its relation to your t-case) you could be running in to a vibe/u-joint problem. If you are drop t-case, or get a SYE for the t-case, or change the spring perches on your rear axle. If this isn't the case, that you are not running a lift, then you should be fine replace the straps and u-joint, and inspect your yoke because when the straps snapped might of taken some thread with it. If you wanted you could get your shaft balanced again, thats your own call.
yes i have had the u-joint break the straps, it was a cold winter morning sitting at a street light, light turns green...Jeep shakes here a snap...pop it in to 4HI and drive to my house in front wheel drive, and then i did the same thing all the way to the parts store too.
My friend just did it @ st.mary's GLacier, sucked going down a decent as this snap happened . Had to push the jeep, take out the driveshaft and go back home in front wheel drive. I always carry a spare U-joint but my friend wasn't thinking.
grenMEG is offline
post #4 of 17 Old 10-18-2007, 09:04 AM
bigrobby
i've broken the straps. as far as the actual driveshaft, you will break numerous things before it goes. as for me i've broken the straps, spider gears, the slip yoke itself twice, and the 1310 u joints will definietely go before the shaft itself
92 yj, 4.0 H.O. with crane cam 753901 and lifters/ ford 8.8 track lock and disc rear/3.73/ 231 HD chain & sprocket/ Teralow HD SYE/Tom Woods DS/ bout 4 inches mixed susp lift/ 33" BFG muds/ crapload more.
MY THEORY OF PERPETUAL SPENDING: if i've built my drivetrain strong enough to where i can't break it anymore, i clearly don't have enough power. Strokin' is in the future.
bigrobby is offline
post #5 of 17 Old 10-18-2007, 09:12 AM
jeepster93
jeepster93's Avatar
I must just be unlucky...
jeepster93 is offline
post #6 of 17 Old 10-18-2007, 10:42 AM
bigrobby
oh yeah i forgot about that, my bad. i was thinking the actual shaft splitting which i've never seen. but unless you have the bigger u joints which i think was only 94 95 then the u joints and the slip yoke are usually first to go. nice work on that one jeepster
bigrobby is offline
post #7 of 17 Old 10-18-2007, 01:37 PM
Matt87YJ
Matt87YJ's Avatar
1987 YJ Wrangler
Like Rusty said I doubt you'll break the D/S unless your rig is heavily modified and you beat the crap out of it. I've broken quite a few U-joints on mine and slung the D/S out of the jeep while driving and I had to buy a new muffler because of it. I wouldn't replace the straps with something else when the straps are cheap and make the U-joint fairly easy to change. To be honest I kinda wish I still had the straps instead of what I'm running now, it was alot faster to change them before.
'87 Wrangler, Stroked with a few other toys...
Matt87YJ is offline
post #8 of 17 Old 10-18-2007, 01:46 PM Thread Starter
lturley
Thanks guys.
lturley is offline
post #9 of 17 Old 10-18-2007, 02:47 PM
E_ROCK
I am going to disagree. Stock shafts are very thinned walled. There are pretty weak and don't hold very wall against any type of rock damage. Once they dent it doesn't take much to twist them up.
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #10 of 17 Old 10-18-2007, 03:46 PM
slater03
PUT U-BOLTS IN! One of my straps broke causing an expensive series of events. First the strap broke and released the driveshaft. It flopped around til it hit the exhaust whcih crushed it. The impact broke both halves of the t-case and shredded some inside stuff and it dented the driveshaft in. But I just swapped in an 8.8 to fix the strap problem.
"Witty quote here"
slater03 is offline
post #11 of 17 Old 10-18-2007, 04:26 PM
fratis
fratis's Avatar
ok this is the deal: straps vrs. diy ubolts.
the straps are a good thing for a couple of reasons, some mentioned.
the straps are designed to hold with the proper amount of force on the ujoint cap without deforming it no matter how tight you get the bolts. ubolts can be tightened until the caps are out-of-round. it doesn't take much for this to happen, and in our enthusiasm as 4wheelers to keep things from breaking, is easy to do. when the cap deforms it will cause the needle bearings to gouge the ujoint inner surface. the needles can wear to the point of eating themselves and the cap will fail. *
the straps will typically fail long before anything else bad happens. these typically go way before the ujoint itself goes potentially avoiding much costlier driveling damage. you should be able to throw a shaft without any major damage. dented muffler is usual. the tangs on the ujoint, little teeth designed to hold the cap from shifting laterally, often break off.
its not a simple case of swapping ubolts out for the straps. you have to drill out the threaded holes. once you've done this there will be very little "meat" on the yoke left around the ubolts. after drilling, before i even installed the ubolts, i decided never to do this again.
not long after the conversion i proceeded to stretch and deform 2 sets of ubolts as well. so considering the drawbacks and the fact that they didn't perform much better, i think its not a worthwhile use of time.
if you want to convert to a ubolt style strap then do it right and buy the kit with the yokes that are machined properly for this. its like $50.00.
*Powertrain Industries supplier of commercial driveshafts and ujoints.
fratis is offline
post #12 of 17 Old 10-18-2007, 05:15 PM
dave_dj1
every time i've seen the straps break, so did one or more of those pesky little 8mm bolts that hold it to the yoke, not a trail fix! i had to drive home in front wheel and then take the yoke off, weld some washers over the broken remains in the yoke, then weld a nut to the washer and unscrew what was left......i have to have a front strap break though.
Wheel it like ya stole it!
dave_dj1 is offline
post #13 of 17 Old 10-18-2007, 10:27 PM
fratis
fratis's Avatar
this is a good point. i think this one would be a "con" for straps and a "pro" for ubolts. i havent had to do this for a few years as im using a companion flange.
ive been able to unscrew them with needlenose pliers. i used to keep some items in the box to back out the remainders as well.
fratis is offline
post #14 of 17 Old 10-18-2007, 11:50 PM
ImRaptor
Few weeks ago I had my straps bust, well it was actually one of the little bolts that went. I had some luck on my side for this particular incident. First, I was nearly stopped when it went so it did very minimal damage. Only a dent into the exhaust. And second, I have 2 spare complete axles in my garage.
I made up a new pinion yoke to hold ubolts and have two others that I can use for straps again if I ever feel the need.
So far the Ubolts have held up well, but like fratis said you have to be careful tightening them as to not wreck the ujoint.
I didn't tighten them any harder than I would the strap bolts and then just put some thread locker on them to keep them from backing off.
Your mom is using you to get to me. How sad is that....
for me.
ImRaptor is offline
post #15 of 17 Old 10-19-2007, 04:44 AM
doug_1994
doug_1994's Avatar
To save on down time, or trail fixes like mentioned above. I drilled out the threads on my corp. 14 rear, but I still use the straps. I got tired of ripping the heads off of those pesky bolts also. So now when it happens all I gotta do is pound them out, and insert new bolts. Sometimes the straps can get deformed, but a little bit of banging on them they go right back into shape.
I'm not sure about other rear ends, but there is plenty of beef on mine.
Doug
Wise men speak because they have something to say;
Fools because they have to say something.
Plato
doug_1994 is offline
Factory front driveshaft lengths richmond1273 YJ Wrangler Technical Forum 1 07-08-2009 02:34 PM
Factory Driveshaft Boot clamp removal. Need Answer ASAP Wrangler_91 TJ Wrangler Technical Forum 2 04-18-2009 02:37 PM
Ford 8.8 and factory driveshaft Alabamaranger YJ Wrangler Technical Forum 7 09-22-2008 09:10 PM
factory cv style driveshaft? will_982 YJ Wrangler Technical Forum 7 07-18-2008 06:35 PM
How strong is the factory roll bar? stalbotvsp YJ Wrangler Technical Forum 27 03-27-2008 09:06 PM
