How to seal NP231 yoke? - JeepForum.com
post #1 of 10 Old 03-23-2009, 11:41 AM Thread Starter
planedog
I couldn't find the "seal washer" to seal the fron output yoke on the 231 so I tried black RTV but it didn't work. How have you folks been sealing the splines through the yoke? Thanks
planedog is offline
post #2 of 10 Old 03-23-2009, 01:10 PM
Jkanly
http://www.jeep4x4center.com/jeep-tr...-231-parts.htm
you need number 11. I don't think you can do it any other way.
the seal is $8 at advance autoparts iirc
l _____
/l
,[____],
l---L 0lllllll0-
()_)-()_)--o-)_)
Jkanly is offline
post #3 of 10 Old 03-23-2009, 01:16 PM
jdarg
IIRC there's a little rubber seal with the spine pattern around it that fits inside the yoke. It sites between the yoke and the big nut. The quadratec diagram does not show it.
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline
post #4 of 10 Old 03-23-2009, 01:17 PM Thread Starter
planedog
Thanks, Jkanly. I guess I should have been more specific. When I took this 231 apart there was a rubber washer of sorts under the nut that holds the front output yoke on. I was unable to find this seal washer, tries RTV, and now the splines are leaking a lot. What I am trying to figure out is how to seal those splines? Thanks.
planedog is offline
post #5 of 10 Old 03-23-2009, 02:03 PM
ctm
RTV will work if you clean off the splines on the shaft and the yoke with brake cleaner, then let it dry and put on the RTV. Let the RTV set up for 5-10 minutes before you assemble. FWIW I've never seen that crazy washer on any other yoke. By the way I use Dynatex RTV , I found it much better than the permatex autozone stuff.
ctm is offline
post #6 of 10 Old 03-24-2009, 07:38 AM Thread Starter
planedog
Thanks, I picked up some 3M gray RTV yesterday that is supposed to do the trick. When I put it back together I just put some black RTV under the nut, where the washer was, and it leaks like a seive!
planedog is offline
post #7 of 10 Old 03-27-2009, 08:05 AM Thread Starter
planedog
To answer my own question, and to help others who might be interested, the way you can seal the fron yoke on a NP231 is to use grey RTV. I used black when I assembled the case and when I took it apart it was still not set up. I guess the transmission fluid reacts with the black for some reason. I sealed it with 3M grey RTV making sure that there was plenty of it on the splines of the yoke and under the nut, immediately put fluid in and have no leak at all as of now, 2 days later.
planedog is offline
post #8 of 10 Old 03-27-2009, 08:36 PM
azgurney
It got the yoke sealing washer from the Jeep dealer. It is only a few dollars.
91 Wrangler 4.0 5sp
8.8 4.10 explorer axle, 33x12.50x15 x-terrains,Rancho 2.5 lift and shocks, Goforit 1" motor mount lift, 1" body lift, sailcloth top with tinted windows
azgurney is offline
post #9 of 10 Old 06-06-2011, 03:15 PM
NHfireLJ
NHfireLJ's Avatar
Found the parts at extreme terrain.com
Front Output Seal for NP231 Transfer Case 4338893
Yoke Washer Front Rubber For 1987-07 NP231, NP242, NV241, NV249 4210973
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #10 of 10 Old 06-06-2011, 04:46 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
Use the splined washer and the sealant. Have all parts clean, dry and free of oil. Torque to spec.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
XJ NP231 Front Yoke Douglas S. YJ Wrangler Technical Forum 1 12-01-2009 09:34 AM
NP231 front yoke antec YJ Wrangler Technical Forum 10 07-07-2009 06:21 PM
D44 rear pinion seal vs. NP231 transfer case seal thejafe TJ Wrangler Technical Forum 14 06-14-2009 01:24 PM
NP231 Seal....Seal alone or bushing also? 72RatCamaro YJ Wrangler Technical Forum 10 01-29-2009 10:12 AM
np231 slip yoke-buy new or used? JEEPINWI YJ Wrangler Technical Forum 7 11-10-2005 08:21 AM
