how to replace lower steering shaft & bearing??? - JeepForum.com
post #1 of 1 Old 04-02-2006, 01:51 PM Thread Starter
raStapiMpjaY
I have now replaced every major sterring component and I am down to the steering shaft/column bearing as being my problem.... I have used the search (in this forum, other forums, & google) and still cant come up with a descent set of instructions, hell even my Chilton's book makes no mention of it...
I plan on replacing the following:
Lower steering shaft
Plastic Steering column bearing retainer lower
Steering column bearing lower
does anyone have any pointers, tips, or even brief instructions how to do this (and possible problems i might encounter?
can this job be done in a couple of hours with basic hand tools?
thanks in advance!
raStapiMpjaY is offline
Lower steering shaft bearing replacement - With pics! Fernando YJ Wrangler Technical Forum 91 04-29-2016 09:38 AM
lower steering column bearing Que89YJ YJ Wrangler Technical Forum 6 02-07-2011 02:36 PM
Anybody replace the output shaft bearing to cure vibes? Chris_ TJ Wrangler Technical Forum 5 05-08-2008 04:50 PM
Lower Streering shaft bearing Alabamaranger YJ Wrangler Technical Forum 5 02-11-2008 09:58 PM
how to replace lower steering column bearing? ah77 YJ Wrangler Technical Forum 4 08-04-2006 06:28 PM
