How to replace intake/exhaust gasket on a 2.5? - JeepForum.com
post #1 of 12 Old 12-02-2010, 11:25 AM Thread Starter
TheNewbie
I just found a huge leak in the intake gasket on my 95 2.5 that's been causing it to run at 3000 RPM. I have the Haynes manual, but it makes replacing this gasket look like a 2 day project.
It pretty much has me taking off every single bolt, hose and wire on the manifold. But it only has a section on removing the manifold, not just replacing the gasket.
Do I really have to remove the throttle body, PS pump, all vac lines, EGR tube, radiator hose, etc...
Has anyone done a write up on this? I've searched but haven't really found anything too helpful.
Also, I usually use Permatex for sealing gaskets, but it says it's only for gaskets that don't come into contact with fuel. What should I use to seal this gasket?
Thanks
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #2 of 12 Old 12-02-2010, 12:42 PM Thread Starter
TheNewbie
I just went ahead and tried to do it without taking all that crap off. For anyone who may search and find this later you have to remove the PS pump bracket, but the rest can stay on. I just unplugged the vac lines under the throttle body to let it move more, and disconnected some electrical connection on the intake manifold itself. Not sure what it was. There isn't much room to clean the mating surfaces, but it should work.
Does anyone know what I can use to seal the gasket though? I know Permatex and RTV aren't good to be in contact with fuel. But I don't know what I CAN use.
post #3 of 12 Old 12-02-2010, 12:46 PM
Que89YJ
http://www.jeepforum.com/forum/f12/h...ifold-1063245/
The 2.5 and 4.0 are close. You have a little more room. The middle bolts on the bottom are a @##$#%$#. Also make sure and check your exhaust manifold for cracks while you have it apart.
Que89YJ is offline
post #4 of 12 Old 12-02-2010, 02:11 PM Thread Starter
TheNewbie
Thanks, doesn't look like he used any sealant at all.
post #5 of 12 Old 12-02-2010, 02:50 PM
MLJeeper
MLJeeper's Avatar
Your pretty much right on, thats how i did mine although the back bolts are really tough if you have big hands. What gasket did you get? the one i put on was crush gasket. Someone else mentioned checking the exhaust manifold for cracks, definitely do this, mine was cracked bad, actually looked like it had exfoliated in some areas.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #6 of 12 Old 12-02-2010, 04:57 PM Thread Starter
TheNewbie
This is one of the only times that I'm thankful for my tiny girl hands.
And the gasket is a Felpro gasket. It's one piece for both the intake and exhaust, and it's pretty thick so I'm guessing it's a crush gasket, although I've never heard that phrase used before.
I'm guessing that means I can just torque it down and it will crush itself into the gap and not need any sealant. Is that what that means?
It's pretty much ready to go back together, but I decided to let the carb cleaner and degreaser that I used to clean it dry for a while before I put it back together. I went through 2 full cans before I felt it was really clean. It's hard to get in between the head and manifold to really scrub it to shiney metal like I normally do with gasketed surfaces, but I'm fairly confident that it's at least grease and grime free.
post #7 of 12 Old 12-02-2010, 05:25 PM
MLJeeper
MLJeeper's Avatar
Yeah it should have aluminum or something on it that will let the manifolds crush into it when you torque them down. You dont want to use any sealant on the exhaust side.
MLJeeper is offline
post #8 of 12 Old 12-02-2010, 05:29 PM Thread Starter
TheNewbie
You say "on the exhaust side". Should I use it on the head side but not the side facing the manifolds then? Or just don't use any?
post #9 of 12 Old 12-02-2010, 05:58 PM
MLJeeper
MLJeeper's Avatar
You should not need to use any. Does the gasket have the metal i referred to?
MLJeeper is offline
post #10 of 12 Old 12-02-2010, 06:01 PM Thread Starter
TheNewbie
Thanks
Yep, one side is metalic and the other looks like a regular type of gasket material. And it's got to be at least 3/16" thick.
post #11 of 12 Old 12-02-2010, 06:03 PM
MLJeeper
MLJeeper's Avatar
Thanks
No sealant required
MLJeeper is offline
post #12 of 12 Old 12-02-2010, 06:45 PM
SteveJcoYJ
i actually managed to leave the p/s bracket on, the last time i had it off i left the one recessed bolt off so i wouldnt have the remove the pump to remove the intake
SteveJcoYJ is offline
need to replace intake/exhaust manifold gasket.? fishmanwill YJ Wrangler Technical Forum 1 07-08-2009 01:55 PM
intake/exhaust gasket question spoiler73 YJ Wrangler Technical Forum 5 04-23-2009 03:20 PM
i4 exhaust/intake gasket ... which way does it go ? intenseblu YJ Wrangler Technical Forum 3 10-25-2007 08:00 PM
Help: Intake, exhaust and gasket :brickwall funJ YJ Wrangler Technical Forum 8 07-07-2006 06:31 PM
Intake/exhaust gasket questions rollerized YJ Wrangler Technical Forum 0 05-04-2006 01:53 PM
