Not very hard. Roll the window all the way down. Pull the weather striping around the top and then the squeegee felts (assuming you're replacing those too) Pull the vent glass, should be three screws along the outer edge and two on the door behind the panel, it should pull toward the middle from the top and then lift right out. Then crank the window up enough to get to the two bolts at the bottom edge of the glass. Once those are out, grab the top edge of the glass, it will slide right out (pull up and in a bit so it comes out toward the inside of the Jeep).
