How to remove steering column assembly? - JeepForum.com
post #1 of 3 Old 06-06-2010, 10:43 AM Thread Starter
grimjeeperyj14
I have a 1990 yj manual trans with the tilt steering column. I need to replace it but am not sure how to go about removing it. What do I need to remove first?
-I plan on replacing it with a older style xj column.
Driving my Jeep is uncomfortable, loud and drafty.... and I love every minute of it
grimjeeperyj14 is offline
post #2 of 3 Old 06-06-2010, 11:49 AM
Opihi59
from here it gets rough
Opihi59's Avatar
This should be helpful.
Tilt Column Fix - Dale's Jeep Junk
And this.
http://www.fiero.nl/forum/Forum2/HTML/088020.html
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #3 of 3 Old 06-06-2010, 12:11 PM
Brown Dog
Vendor
Brown Dog's Avatar
Remove the instrument panel covers
Remove the steering shaft
Unplug the connectors and any terminals from the steering column
Remove the bolts that fasten the column to the firewall
remove the bolts that secure the bracket holding the steering column to the bottom of the instrument panel.
I don't think I messed anything, it's quite easy.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
YJ Horn Connection and assembly in Steering Column rrisher YJ Wrangler Technical Forum 20 08-04-2011 02:41 PM
quick steering column dis-assembly question Slickdaddydax YJ Wrangler Technical Forum 14 02-17-2010 01:49 PM
Steering Column Blinker assembly stagnok TJ Wrangler Technical Forum 6 09-10-2009 06:05 PM
How to remove steering column? Neo1130 YJ Wrangler Technical Forum 1 07-17-2009 10:07 AM
Do I remove steering column or wheel? jlavender YJ Wrangler Technical Forum 0 09-06-2004 02:56 PM
