how to remove soft top - JeepForum.com
post #1 of 17 Old 02-23-2002, 06:00 PM Thread Starter
slenderjoe
Hi,
I just bought a 1995 Jeep Wrangler and it is really cute being it is already raised, big tires, and new rims. It is also a soft top which I did want but now do not know how to take off. I do not know how to take off the windows from the half doors either. Does anyone know off a website that could help me out or just post instructions.
Feel free to email me or just make fun of me. I know I am new to the jeep world.
Thanks
I also need help on how to remove the windows from the half doors.
1988 Jeep Wrangler YJ (conversion)
Chevy 350 V-8
Edelbrock 1405 carburator
Wieand intake
GM Turbo Hydra-Matic 350 Tranny
New Process 207 C2 Transfer Case
4" body lift; helper leafs in rear
38" tires
slenderjoe is offline
post #2 of 17 Old 02-23-2002, 08:59 PM
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
Don't feel bad, it took me a while too when I first got mine last fall. It takes some time putting it down and back up. Once you get the hang of it you should be able to do it in 5 minutes or so. ok so here we go:
First the have doors:
1. Toward the front, there should be one snap, unsnap it, and grab either end from the bottom, pull it out and down to unhook the plastic strip from the rail.
2. once that is done, simply lift it off the half doors pulling it out of the three holes.
Now for the top:
1. Unzip and remove the side windows.
2. Unzip the rear window and your choice either unzip the horizontal zipper on top to remove the window, or just roll it up and use the 2 straps to hang it up.
3. There are two bars on each side that pivot right where the middle of the side window is, pull out the set pin and pull the bars hooked together down to relieve pressure.
4. Unsnap the snaps running along the top of where the door is.
5. Remember how the doors had that slider/rail system? Here it is again, along the rear corners, pull out the sliders.
6. By this time, the top should be loose enough to pull out the slider along the top of the windsheild.
7. Unhook the drip guards where the snaps were on both sides and let them fall downward.
8. Take the 4 bars that are still holding them up and push them as need be to adjust it so the top will come down. (Its hard to explain this one, but common sense should guide you through this part)
9. Then simply tuck the top in the back or remove it completely and your ready for some fun in the sun.
This is all assuming you have Factory OEM hardware. By the way, I'd like to warn you as being new to the Jeep community, we don't really use the word "cute" to discribe our Jeeps. They are rugged and manly
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #3 of 17 Old 02-23-2002, 10:34 PM
JeepBeep
Mine's cute when I wash it. All blue and spunky.
But there is usually a layer of dirt and mud covering her. *shrug* To each his own.
'01 XJ BONE STOCK (Not for Looong)
'95 YJ 2.5L 3" Sus.
ProComp MT 33s"
JeepBeep is offline
post #4 of 17 Old 02-24-2002, 10:49 AM
Mike611
Mike611's Avatar
Jeep's are not cute,,, especially lifted ones!!! There lean, mean, trail-machines!!! Lol, good luck with your soft top.
One tip,, if you don't give a damn like some of us, and have your top down in 40 degree weather, be carefull when putting it back on. If it is too cold, the fabric will not stretch, and you will rip it!! ( I'm on my 3rd soft top in 2 years)_ )
Just thought I would pass this on to ya!
Mike
95, 2.5L, custom bumpers, Flow's, 4 inch Skyjacker Super Duty, 33x12.50 MT's, 15X10 AR 767's, Hi-lift, Funk in the Trunk( two 12 inch subs ), soon to be locked and have one of those pully things on the front.
If you are going to be a bear, be a grizzly...
Mike611 is offline
post #5 of 17 Old 02-24-2002, 04:49 PM
KobeStopper
KobeStopper's Avatar
Actually, I was the one who posted this message but somehow someone else's name appeared, I just didn't want this person to be ticked off.
I did take off the top quite easily, however the windows for the doors are a different story. I cannot pull out those three bars because I cannot take off those squared covers which go around the three bars.
Thanks
1995 YJ on outlaw II
KobeStopper is offline
post #6 of 17 Old 02-24-2002, 06:15 PM
PuebloIV
I was just beginning to reply when I noticed your (actually your friend's) signature:
"1988 Jeep Wrangler YJ (conversion)
Chevy 350 V-8
Edelbrock 4 barrel carburator
Weiand intake
38" tires"
I was wondering why THAT person needeed help with a top.
PuebloIV is offline
post #7 of 17 Old 02-26-2002, 07:40 PM
KobeStopper
post #8 of 17 Old 04-05-2010, 02:10 PM
RoboFrance29
Resurrected!
I'm also in the same boat and I've found this thread to be the most helpful so far. My question is, is it vital to the process to unzip the rear window? Can I just follow the steps listed above and skip the rear window removal? Reason I ask is because the zipper along the passenger side of the rear window is stuck.
RoboFrance29 is offline
post #9 of 17 Old 04-05-2010, 02:39 PM
AngryBassets
AngryBassets's Avatar
Been awhile for my putting down soft tops but I'd have to say, yeah, that would be a mess without rolling the rear window up or removing it.
stale milk white 97 Police Package XJ (former FD gofer vehicle) bought in 11/08 w/ 41.6k**95 YJ 4cyl/5spd summer beater
Past Jeeps:97 XJ Sport 6cyl/auto, 00 TJ 6cyl/auto,95 YJ 4cyl/5spd 95 XJ SE 6cyl/auto, 93 YJ 4cyl/5spd
AngryBassets is offline
post #10 of 17 Old 04-05-2010, 09:18 PM
rinking
One little tip for ya! Those cute little straps that hold your back window rolled up, will scratch the crap out of your back window! Roll the window up with any dust or dirt on it, it's just like sand paper. With the top up and rear window zipped in, don't let the straps dangle/ flop around or they will scratch/ cloud up the plastic and it can't be reversed! I just bought a new top and cut the straps off it. If your back window is already scratched up, forget what I just said and roll it, and wheel it!
rinking is offline
post #11 of 17 Old 04-05-2010, 09:28 PM
YJake
Never seen a thread necro of this magnitude in my life!
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #12 of 17 Old 04-05-2010, 09:35 PM
raynmaker
I have a question to add to this.
How do you get the support bars off once the top is down. I have no way to secure it when its down so i was just going to take it off but havent figured that out yet.
Only time I've seen a "cute jeep" there was a girl in a bikini driving! O.O
Warning: This poster has infinite knowledge of useless information and redneck tendencies. Use info at your own discretion. :wave:
raynmaker is offline
post #13 of 17 Old 04-05-2010, 09:56 PM
newyj
there should be little straps that wrap around your down soft top rails and they lock into the side window rails
wave back dammit, don't leave me hangin!
yes, I wave at night too
newyj is offline
post #14 of 17 Old 04-06-2010, 05:48 AM
raynmaker
I seen that in a pic somewhere, but I only have one of those on mine Can those be ordered?
post #15 of 17 Old 04-06-2010, 06:51 AM
AngryBassets
Just saw them yesterday on quadratec's site; they are $4.99 I think.
Need help to remove soft top LGriffith TJ Wrangler Technical Forum 3 11-09-2009 06:39 PM
How do I remove soft top? Ursine YJ Wrangler Technical Forum 5 08-03-2009 12:35 PM
How To Remove Soft Top? jeffpettis YJ Wrangler Technical Forum 3 08-31-2008 02:36 PM
Please help, can't remove the soft top. AtlJeeper TJ Wrangler Technical Forum 11 09-29-2006 10:21 AM
97 Tj how to remove soft top GLADIATORTJ TJ Wrangler Technical Forum 1 03-24-2004 01:40 PM
