how to remove bolts from from leaf springs - JeepForum.com
post #1 of 17 Old 02-13-2011, 03:40 PM Thread Starter
jnljeep
In the process of removing stock leaf springs from 92 YJ. Having a heck of a time removing the bolts holding the rear of the front leaf spring. Do I just knock it out or does it thread into place. I got the nut of back side just cant get the bolt out.
jnljeep is offline
post #2 of 17 Old 02-13-2011, 03:43 PM
dillonjm
2013 WK
Its probably rust welded to the metal sleeve inside the bushing.
Probably easiest to just cut the bolt to get it out with a sawzall or angle grinder (I prefer the grinder with a cutoff wheel)
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #3 of 17 Old 02-13-2011, 03:48 PM Thread Starter
jnljeep
Thank you very much. Been fighting this thing for a couple of hours now.
jnljeep is offline
post #4 of 17 Old 02-13-2011, 03:50 PM
ritjobbie
It's not threaded in there. Hit it harder, give it lots of heat. Heck, sometimes it's easier to burn out the bushing and go with new hardware.
If you are installing new springs, don't bother with the bolt. Cut the head off if it's preventing you from getting the spring off of the hanger. You are looking for 4.5" grade 8 bolts, 9/16" for the frame side and 1/2" for the shackle side. Home Depot sometimes only has 4" and 5", neither is ideal. Look for a Fastenal in your neck of the woods. Best store ever.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #5 of 17 Old 02-13-2011, 03:52 PM
bmac13sv
If the bushing is dry rotted, drill into the rubber part of the bushing all around the inner metal sleeve. this will free up the metal sleeve inside and let you get th bolt out (assuming its rusted to the inner metal sleeve of the bushing)
Jeep XJ. 3.5" Full spring pack Rusty's suspension. aFe cold air intake. 33x12.5x15" BFG TA KO's on Cragar Soft 8's. 60mm TB. JCR Offroad Stage 3 Front and Rear Bumpers. New 4.0L (victim of 0331 head). aFe cold air intake. Dynomax Catback.
BUILD THREAD: http://www.jeepforum.com/forum/f177/bmacs-2000-xj-build-1292498/
bmac13sv is offline
post #6 of 17 Old 02-13-2011, 03:57 PM
jbolty
jbolty's Avatar
cut off both ends of the bolt just inside the hanger, or close to the out side and spread it a little to get it out. The metal sleeve is rust welded to the bolt. use a right angle grinder. it will take forver with a hacksaw.
9/16 replacement
jbolty is offline
post #7 of 17 Old 02-13-2011, 04:04 PM
trucknut
i used an impact gun to break the bolts free.. then hit it several times with a maul hammer on the backside of the bolt while still keeping it turning with the impact gun. Once the treads caught on the shackle the bolt backed right out... awkward but effective
1994 Jeep YJ 2.5
My Save the YJ from the junkyard project...
2001 Toyota Tundra TRD
trucknut is offline
post #8 of 17 Old 02-13-2011, 05:26 PM
kvncot
1981 CJ7
The only luck I had removing the bolt was to drill out the rubber bushing. I found that the bolt was rust welded to the sleeve and the sleeve was rusty and expanded in the bushing making it impossible to get out with just a hammer. Drill all around the bushing and load it up with penetrating oil and it should come out with a hammer. You will definitely want to replace all of the hardware. Good Luck!
Easy's Good!
kvncot is offline
post #9 of 17 Old 02-13-2011, 05:48 PM
GEARHED
Need to keep track of this, I'm going to be doing the same myself and figured on cutting off the bolt heads but had no idea how tough they could be to get out (a maul? seriously?). Will probably drill out the bushing first and try it from there.
Old enough to know better, still young enough to do it.
1994 YJ to give the 89' company.
GEARHED is offline
post #10 of 17 Old 02-13-2011, 06:12 PM
kloppk
Agreed.
I've wasted way to may hours hammering and screwing around trying to get them out in the past.
Now if they don't come out after a few minutes I cut them off, remove the spring and drive the rust welded mess out of the bushing.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #11 of 17 Old 02-13-2011, 06:49 PM
trucknut
i was 5 minutes tops on each bolt... and the bolts where all good to use again
1994 Jeep YJ 2.5
trucknut is offline
post #12 of 17 Old 02-13-2011, 06:54 PM
jeepinvader
I had the exact same problem. I used a cut-off wheel on a 4.5 inch angle grinder to fit between the spring and the hanger, then it fell right out.
Free Chuck!
jeepinvader is offline
post #13 of 17 Old 02-13-2011, 08:07 PM
McFatter
i just lifted my jeep friday and had this problem on one of them. i used a c-clamp type pusher that one one end was big enough for the head of the bold to push through. about 30 seconds with an impact gun and it was out
McFatter is offline
post #14 of 17 Old 02-14-2011, 08:55 AM
jeepguy85
1987 YJ Wrangler
I had to drill the bushings on ALL of mine to get them out. Tractor Supply is also a good place to buy grade 8 CHEAP.
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #15 of 17 Old 02-14-2011, 09:03 AM
caver351
I had that problem on my 88. Spun it with an impact, and pried on it with a crowbar at the same time...finally came out.
1988 YJ - 4.2L - 5 speed - 4" Rough Country SUA Lift - 1" RC Boomerrang Shackles - OBA - Procomp 35x12.50s
caver351 is offline
Is there any way to remove those U clips on the leaf springs? Neo1130 YJ Wrangler Technical Forum 14 06-22-2009 10:37 PM
what is the best way to remove old leaf springs xboardr311 YJ Wrangler Technical Forum 8 04-22-2008 05:35 PM
Front leaf springs same as Rear leaf springs? JayJEEPguy YJ Wrangler Technical Forum 5 12-02-2003 10:53 PM
ProCrap Springs-Remove bottom leaf? SundevilYJ YJ Wrangler Technical Forum 5 09-28-2003 11:27 AM
