Quantcast How to put a 2007 JK electric swaybar in your YJ--WRITEUP WITH PICS - Page 11 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > How to put a 2007 JK electric swaybar in your YJ--WRITEUP WITH PICS
Old 01-12-2007, 10:13 PM   #151
hondacr21
hondacr21's Avatar
Is anybody have a 4.0 that has done this conversion and if so what radiator are you using and if you could send some pics. Thanks
1995 Sahara, Borla header, Rear stretch 103" wheelbase, Sniper Fab Comp Corners with 3" flare, SOA with .75" SL, 2 1/2" Rancho lift on 37"s MTR's on 15x8 eagle alloys. JB4x4 steering bracket, M.O.R.E., 8.8 with limited slip and 4.10's, AA SYE, modified XJ front driveshaft, Superwinch EPi 9.0, homemade boatsides, 6 point cage.
hondacr21 is offline   Reply With Quote
Old 01-13-2007, 02:48 AM   #152
paultyler
Uncle Paul has spoken...
paultyler's Avatar
Originally Posted by hondacr21
so you can rotate just the motor? If so about how far is it from the sway bar to the shortest part of the motor. I got about an inch from my sway bar to my radiator.
1 inch sounds really short. I think the shortest part of the motor will need about 2 inches. Is your engine/radiator stock? There is more than 4 inches clearance on mine. Look at the first two pictures in post #6 and you can see the clearance on mine.
My Jeep - Video
My Jeep in the Snow
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers, JK electric swaybar, T&T tube fenders, custom cv driveshafts, RE 4.5 XD springs, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s, AtoZ Rockers, Skid-Row Engine skid plate, Teraflex Bellyup, JCR Offroad 1 Ton TieRod, rock lights, RE hand throttle, M.O.R.E. roll cage, corners, 9000lb winch with synthetic cable in-cab winch controller (12voltguy.com), Dual Blue Top Optimas with 12voltguy dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline   Reply With Quote
Old 01-13-2007, 08:40 AM   #153
cueball
at a quick glance with a tape measure, i am a little more interested in trying to have this done on a TJ. There should be enough clearance under the sway bar cover for the motor. also, the above the frame/below the frame issue shouldnt be a big deal.
what i do see as being a potential issue is that i will need small YJ sway bar links.. stock links may be too long given the design differences on a TJ (until i lift it anyway - i was only planning a modest budget boost but that could work with stock YJ links).
$80 is a gamble, but i still may do it, as i can pass it on to a fellow YJer if it doesnt work for me and recoup my investment.
Bye to the old - 1988 6 cyl 5 speed with a 94 rollbar, tomken 2x4 rocker skids and homebrewed OBA.
Hello to the New - 1999 TJ Sport 4.0L auto.. stock for now
cueball is offline   Reply With Quote
Old 01-13-2007, 08:59 AM   #154
Cobra Jeep
I am with the others, there is something going on with your jeep. Because my rad is right on top of my stock bar, it is like 2 inches away.
Pic: http://img.photobucket.com/albums/v606/JeepsAndGuns/Warn004.jpg
I picked up my bar yesterday and just measured it, and from the top of the bar to the shortest part of the housing is like 1 1/2 to 1 3/4, so if it is gonna clear, its just barely gonna do it.
I have a question, what did you use to connect it to your end links? The bolts that attach to my stock YJ bar are tapered, and the I.D. of the bushing is 5/8in. The hole on the JK bar is not tapered and looks like its either 7/16 or 1/2. Did you just find a steel bushing to fit inside the stock YJ end link bushing?
'93 YJ 4.0L, AX-15, NP-231, SYE, CV, 8.8in rear, OME 2.5 lift, WJ knuckle conversion, Warn M10000 winch.
Soon to come: Hydroboost and a stroker.
'79 Cherokee Chief, 401, T-18/D-20 and hydroboost. Otherwise stock.
Future mods:Caddy 500, NV4500, NP205, high pinion D60 front and D70 rear. SOA with 35X12.50's on re centered H1 bead lock wheels. Warn 12K winch.
Cobra Jeep is offline   Reply With Quote
Old 01-13-2007, 10:18 AM   #155
paultyler
paultyler's Avatar
That's weird. I have a 4 banger. Maybe the radiator placement is different? Moose, does yours have plenty of room like mine?
You can always put some sort of spacer in between the frame and the bracket to lower it 1 /2 inch.
As for the bolts, I went to the hardware store and bought some metal sleeves and slid them into the bushings so it is set up like your shackles.
My Jeep - Video
My Jeep in the Snow
Old 01-13-2007, 10:24 AM   #156
hondacr21
hondacr21's Avatar
I figured out what is wrong with mine whoever put the 2"bl even made or they came with these 2" radiator drop brackets so you dont have to cut the shroud a little I took them off and I have about 3" bwteen the radiator and the swaybar. and you say you can rotate the motor 360 degrees? sweet hopefully it fits
Old 01-13-2007, 02:36 PM   #157
YJNate
i just junked my stock swaybar i should get my JK swaybar next week sometime. i cant wait hopefully it all goes well....
YJNate is offline   Reply With Quote
Old 01-13-2007, 06:15 PM   #158
Cobra Jeep
ok, next question. I was out messing around with my jeep and I measured from the JK's bar centerline to where the link hooks up then went and measured my YJ. It looks like the JK bar is gonna end up over top of the axle because the "arms" are longer. Do you have a closer pic of your end links, cant really see them in the pics on the first page real good.
Old 01-13-2007, 07:45 PM   #159
paultyler
paultyler's Avatar
I addresses that in the write up. You may have to weld on some tabs to the top of the axle to connect the links there. However, I was able to use the links where they already were.
My Jeep - Video
My Jeep in the Snow
Old 01-13-2007, 08:31 PM   #160
00Vert
Originally Posted by 98formulaLS1
ok heres my plan...
voltage AND/OR current can both kill a motor.
The lack of current carrying capacity can kill the motor, not the current itself. As long as you use large enough gage wires to and from the motor, you will have plenty of capacity. All we have to worry about is the proper voltage. Go for your test, that's why I suggested it. The wrong voltage will cook motors whether either too high or to low. Too low a voltage is even harder on an electric motor than too high. That's why power companies sometimes have to pay for new refrigerators when voltage drops too low. That's also why a 6 volt starter will work fine on 12 volts but not the other way around! Find out the proper voltage, then we can duplicate it with the proper calculation.
00Vert is offline   Reply With Quote
Old 01-13-2007, 09:10 PM   #161
NewdRiver_
Paul, is your setup waterproof?
Join us in JeepForum IRC!
#jeepforum on Freenode
New to me '00 XJ. 4" lift, 31's, purchased December '10. DD.
'85 (somewhat) Chevy/Ford/Honda/Jeep CJ-7. 5" lift, 35's, built May '08. Neighborhood terrorizer/sound polluter.
Originally Posted by IRC
<AoA> im hot in general
<topfuel> ahha, found it
* topfuel sets ban on AoA!*@*
NewdRiver_ is offline   Reply With Quote
Old 01-13-2007, 10:07 PM   #162
paultyler
paultyler's Avatar
Yes. Just use gasket sealer when you put it all back together!
My Jeep - Video
My Jeep in the Snow
Old 01-13-2007, 11:17 PM   #163
julietkilo
FLY DIVE JEEP SKI
julietkilo's Avatar
yup, go back a few pages in this post and read my calculations post. It can tell you how to calculate for amperage.
julietkilo is offline   Reply With Quote
Old 01-14-2007, 09:01 AM   #164
Paul04TJ
If you rotate it 360 degrees, you will run into the same issue.
Try it at 180 degrees.
Any one do a TJ yet?
Red Jeep Club Member # 269
'04 Wrangler 'X'
Rubicon Express 2 in lift
31x10.5 Goodyear Duratrac
15X8 Soft 8's w/4.0" backspace
Paul04TJ is offline   Reply With Quote
Old 01-15-2007, 08:26 AM   #165
FSTG60MAN
Has Anyone Found The Voltage For The Electromagnet Yet?
sold the zj back in a yj, skyjacker 7000 absorbers, bfg 31x10.5x15 all terrains, hella lighting, highlift and more tow straps than god.
FSTG60MAN is offline   Reply With Quote
Glock Forum
