How to prime oil pump? - JeepForum.com
post #1 of 11 Old 08-14-2007, 08:00 AM Thread Starter
raStapiMpjaY
I am in the middle of a major overhaul to my 95 YJ 6cyl. I had removed the oil pan to replace the rear main seal and figured I might as well replace the oil pump while I was in there. The instructions with the oil pump state that it needs to be primed but the instructions in the Chilton manual said nothing of this. I searched the forums and turned up nothing. The guys at autozone said that the distributer turns the oil pump and for some cars/trucks there is a special drill attachment that turns the oil pump to prime it but there is none for the jeep.
How do you prime the oil pump???
raStapiMpjaY is offline
post #2 of 11 Old 08-14-2007, 08:02 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
EDIT: I stand corrected, follow advice below.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 11 Old 08-14-2007, 08:22 AM
dgm5186
When I installed my remaned engine, the manual said to prime the pump like you say. Alls I did was take a wood bit, grind down the end flat so it would fit into the notch in the oil pump and I turned it with a drill. Worked very well. You are not supposed to crank the engine to prime the pump. This would move the internals of the engine around without oil on/around them. This could damage the engine. Hope that helps.
dgm5186 is offline
post #4 of 11 Old 08-14-2007, 08:34 AM
hdfxrs91
1987 YJ Wrangler
You can also use an old or cheap flat-head screwdriver, cut off the handle, and use it in the drill.
hdfxrs91 is offline
post #5 of 11 Old 08-14-2007, 08:38 AM
EABiker
Any long screwdriver blade that would reach and fit the slot in the oil pump drive that the distributer fits into will work. Even a piece of all-thread mashed flat on one end and chucked in a drill will work! If you use the all-thread, cover the threads with duct tape so you do not scratch anything.
EABiker is offline
post #6 of 11 Old 08-14-2007, 10:05 AM
bigstinger
bigstinger's Avatar
when I put my toyota oil pump (22re) on the advice for that was to pull the plugs and let the engine turn over without firing. Apparently assembly lube is fine for the 4-5 seconds it takes to bring the oil pressure up...
I like the other advice better though...
4.0L Ford 8.8 4.56 lsd D30 SOA, 4.56 BFG 35 X 12.50 AT's
Ebay Bushwacker knock-off TJ flares - tuffy security console.
Stainless steel braided brake lines skyjacker pitman arm skyjacker hydros
Buy my unit bearings!
bigstinger is offline
post #7 of 11 Old 08-14-2007, 11:21 AM
jeepnguns
jeepnguns's Avatar
Better yet you can rent the tool from autozone for free and not have to destory another tool to do it. Just make sure you trun the pump in the right direction.
88 Wrangler
350 Chevy engine vortec heads Holley Pro-Jection
Ford T-18 Tranny
Dana 44s Detroits w/ 5.89s
38" Swamper SX
Lots of other random things and dents
jeepnguns is offline
post #8 of 11 Old 08-14-2007, 01:27 PM Thread Starter
raStapiMpjaY
thanks for all of the advice.... sadly autozone only had the tool for a GM and a Ford
I guess i will just use a screwdriver/bit when i remove the distributer
post #9 of 11 Old 08-14-2007, 01:46 PM
4.7stroker
I took my pump apart and cleaned/debured everything.
I then filled the pump with assy lube, this creates instant suction when the motor turns over.
The assy lube the motor was put together with will hold up just fine for the 2 seconds it will take to get oil pressure up using this method.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #10 of 11 Old 08-18-2007, 03:39 PM
JaySpencer66
I filled the pump with oil before I mounted it and then cranked the engine a few times with the coil wire pulled. I always do that kind of thing when ever I change the fluids.
/l , [____],
l---L--[]lllllll[]-
()_) ()_)----)_)
Member #1 of the "I Hate Torx Club!"
~anyone with a Jeep is an automatic member, and anyone can be member #1~
JaySpencer66 is offline
post #11 of 11 Old 08-18-2007, 05:37 PM
RIjon
ALWAYS prime with drill
Switch panels for our jeeps
2008 Toyota Tundra RCSB Supercharged
1998 Cherokee Classic ..... work in progress
RIjon is offline
replaced relays but Fuel Pump still doesn't prime lexinator02 YJ Wrangler Technical Forum 10 12-28-2009 10:29 AM
Fuel pump doesn't prime the system dswi YJ Wrangler Technical Forum 8 06-10-2009 06:35 PM
Oil pump replacement - need prime? 14erjohn TJ Wrangler Technical Forum 2 05-08-2009 11:45 AM
should i prime before i herculine? yjJeff YJ Wrangler Technical Forum 7 02-18-2009 09:55 PM
Jeep shuts off in prime noodles2049 YJ Wrangler Technical Forum 0 08-27-2005 02:08 PM
