How to Paint My Wrangler - Page 2 - JeepForum.com
post #16 of 23 Old 05-01-2012, 06:33 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Originally Posted by hesserdude07 View Post
here it what it looks like with quality prep and paint... AND yes u have to look close.
THAT was painted with what? Certainly not rusto with foam roller?
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #17 of 23 Old 05-01-2012, 06:53 PM
hesserdude07
Painted for less than $500. And NO thats not rusto and a brush or roller. Those are tools for painting a house or shed, NOT your jeep or any other car for that matter!!
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
post #18 of 23 Old 05-01-2012, 09:01 PM
crackedcornish
Originally Posted by bpete123 View Post
Wait so you used roll on bedliner on the exterior and then primed it then finished with a topcoat? Wouldnt it be really hard to paint over bedliner?
no, I used duplicolor spray on bedliner on the exterior..it has a much finer texture than the roll on I used on the interior, and was easy to prime and topcoat
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #19 of 23 Old 05-01-2012, 09:35 PM
90yeddy
that is an aesome picture. Ihad to look twice before i realized that was a reflection not just a picture of your shop
90yeddy is offline
post #20 of 23 Old 05-02-2012, 07:51 AM
crackedcornish
nice, but after just one light wheelin' trip in the east and it would look like this
that's why a lot of the guys around here use the bedliner on the exterior..it helps hide the pinstripes
post #21 of 23 Old 05-02-2012, 08:53 AM
crackedcornish
Also thank you for the photos....I think that safety orange is exactly the color i was looking for
if I were to do the exterior today (I acquired my bedliner and paint last year), I would get Monstaliner in the newly released color
Apocalypse
http://www.jeepforum.com/forum/f43/i...-liner-875162/
post #22 of 23 Old 05-02-2012, 03:31 PM
devoX13
Im doing monsta on the interior and exterior as soon as i acquire a new tub or repair my current one. OD Green on the outside and black on the inside
devoX13 is offline
post #23 of 23 Old 05-02-2012, 06:28 PM
ZigZac
If you want to do a "quality" job on the "cheap" I would suggest doing all your bodywork and prime it. Finish sand the whole thing with 320 grit and use a red scotchbrite in all the hard to hit areas and corners/cracks. Then use a decent sealer before topcoating. On a jeep I would use Shopline PPG. It's PPG's budget friendly line. Use a Singlestage Urethane topcoat and lay it down nice. At least three coats and you can sand/buff it if need be. Go to any PPG paint supply and ask about shopline. You can also get "decent" industrial coatings. Get an HVLP gun and practice on a bit of scrap metal to get the hang of spraying sides to see how much overlap you can get before it runs. I used a Dupont Singlestage Urethane on my beasty and never buffed it and it's great. It's got good build as well for any scratches that come my way. That being said I did paint and bodywork for 12 years, so as far as spraying technique I had that down. Another word of advice would be to have a compressor good enough to hold a steady 90 psi under full load. And pay attention to considering a watertrap filter. Hot compressors send out hot air and as it cools in the airlines it condensates thus shooting water out with your paint. All paintjobs are 90% prepwork. Good luck to you!
ZigZac is offline
jeep , paint , wrangler
no-wax paint? on a 1992 wrangler? wth is this? iamthemellowman YJ Wrangler Technical Forum 31 11-07-2015 01:27 AM
Suggestions for Paint on my wrangler RyMully Wrangler General Discussion 4 02-14-2011 07:25 PM
97 Wrangler Paint??? Laxstar46 TJ Wrangler Technical Forum 2 07-14-2007 03:40 PM
Wrangler Paint gqmonsieurgq TJ Wrangler Technical Forum 7 01-23-2005 12:05 AM
Wrangler Paint Warranty MnWranglerX TJ Wrangler Technical Forum 8 08-31-2004 10:58 AM
