How much yoke inside tail housing? - JeepForum.com
post #1 of 4 Old 05-12-2013, 08:32 PM Thread Starter
Rproject
1987 YJ Wrangler
Having dropped a drive shaft on a previous rig, I'm eternally leery of losing another, especially on the trail. So tonight I marked my rear drive shaft and did some measuring. I have 1.5" of the yoke expose and 2.75" inside the tail housing. Does this sound right? Does it sound safe? Should I have any concern about dropping my rear drive shaft on the trail?
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #2 of 4 Old 05-12-2013, 09:53 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Depends on how much wheeling you expect to do. The more flex you have, the more travel the shaft will express.
Luck Favours The Prepared
Anticanman is offline
post #3 of 4 Old 05-13-2013, 06:05 AM Thread Starter
Rproject
1987 YJ Wrangler
Maybe I need to rephrase the question:
For those who are not running an SYE kit, how much of your drive shaft is exposed from the tail housing and how much is still stuffed up inside there at rest? I'm trying to gauge mine. I believe I should be just fine with 1.5" exposed and 2.75" inside the housing, but I have no real way to test it other than on the trails.
1996 White ZJ
Rproject is offline
post #4 of 4 Old 05-13-2013, 06:17 AM
kahanabob
How much further in will it go? guess if you unbolted it at the rear end and them push it in all the way would give you that info. might be it will only go in another inch? as far as your question, everyone will have a different amount depending on various lifts they have. think what you have is fine, IMO.
kahanabob is offline
