how much would a 6 inch lift cost? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > how much would a 6 inch lift cost?
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 03-07-2010, 06:14 PM   #1
cutch1400
Jeep YJ Suspension Lift
i wanna get this lift kit but i know you have to get alot of other stuff change when you get a lift kit this big, what will i have to get changed or order and how much should you think it should cost to get installed so i can make sure im not getting riped off.
cutch1400 is offline   Reply With Quote
Unread 03-07-2010, 06:53 PM   #2
jeepercreeper77
i have a bds 5"lift in my jeep now. you will have to do the sye and get a slip yoke driveshaft(you can use a xj front shaft). but even after that you my have to get a transfer case drop because of the steep driveline angle.i did all the work my shelf so.to be honest if i knew it was going to be such a pain with the driveline angle i would have went with a 4" lift.lower center of gravity.
90 wrangler,4.2l,1" MML,CRT HEI Dist.,34/34(interco) weber, hurst shftr,5spd,5" BDS lft,f-d30/r-8.8,5/8 lft booms,1" bl,tflex belly up,JB convs. SYE,gdyr mtr35s,hurc'ed,smit src frt bump,gen-r rear bump w/tire carrier,f&r tube fenders,psc knokrs,r gen-rgt ful conr gurds,duel bat.,BIC,m8000
jeepercreeper77 is offline   Reply With Quote
Unread 03-07-2010, 07:01 PM   #3
beachedjeepyj
First off what are you trying to achieve with this lift? What size tires are you going to run ect... You will definitely need a sye and cv drive shaft (around 500$). Depending on what size tires your going to run your going to drop over 1000$ in new rubber and wheels, any tire 33" and up your going to probably need to re gear your axles or replace your rear for a stronger axle. Running stock gearing on 33" with the 4 banger is going to be slug.
[QUOTE=Jeep89JV;9284099]Do I let others drive my rig? No -- Why, because if this ship sinks i'll be the captain and I go down with this ship.[/QUOTE]
[url]http://www.jeepforum.com/forum/f12/motorcraft-carb-swap-961766/[/url]
beachedjeepyj is offline   Reply With Quote
Unread 03-07-2010, 07:07 PM   #4
cutch1400
na i havent order it i just sold my four wheeler so i have cash for the lift, should i just got wiht the 4 inch lift?`
Unread 03-07-2010, 07:25 PM   #5
beachedjeepyj
A 4 inch would be more sensible but may still require a sye and cv drive shaft, then if you need more clearance you could add a 1" body lift and some tj flairs.
Unread 03-07-2010, 07:29 PM   #6
cutch1400
i have tj flairs and a 3 inch body lift.
Unread 03-07-2010, 07:32 PM   #7
beachedjeepyj
What size tires are you planning on running because a 2.5 lift will give you enough clearance for 33s and you'll most likely not need the sye/cv drive shaft combo.
Unread 03-07-2010, 07:33 PM   #8
cutch1400
i have 33 tsl super swampers right now but once there bald i want 35" inch boggers.
