How much are sway bar end links extended- 4" lift - JeepForum.com
post #1 of 6 Old 04-01-2010, 12:16 PM Thread Starter
chadroc
I have a 4" suspension lift and I'm going to put a sway bar on and will be making extended end links. How long should they be? Is it as simple as making them 4" longer than stock? Seems like that should work, but maybe there's something involved that makes it more complex than what seems odvious?
Thanks!
chadroc is offline
post #2 of 6 Old 04-01-2010, 04:25 PM
humbert810
If you want I can measure mine from my 4" kit. I never put them on
RED 1995 Wrangler YJ DD
Front and Rear custom bumpers
4" RC Susp. Lift
33x12.50x15 Firestone Destination MT's
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
humbert810 is offline
post #3 of 6 Old 04-01-2010, 10:28 PM Thread Starter
chadroc
That would be great! Thanks!
chadroc is offline
post #4 of 6 Old 04-01-2010, 11:01 PM
wrangler76
I'd just cut the stock ones and sleeve them with tube... then drill holes for tractor pins and you have a set of disconnects.... The goal is to have the sway bar about parallel to the ground when the suspension is in its neutral position...
wrangler76 is offline
post #5 of 6 Old 04-02-2010, 01:30 PM
humbert810
10" center to center.
4" RC Susp. Lift
post #6 of 6 Old 04-03-2010, 09:11 AM Thread Starter
chadroc
thanks for the help guys!
chadroc is offline
Rough Country 2.5" spring & 3/4" spacers extended sway bar links? drewtj05 TJ Wrangler Technical Forum 24 11-04-2009 12:18 PM
rear sway bar extended links safarimike TJ Wrangler Technical Forum 2 07-07-2008 10:04 AM
Sway Bar Extended End Links DixiesCJ3B TJ Wrangler Technical Forum 1 02-19-2008 11:55 AM
Rear extended Sway Bar links... CHRRRIS TJ Wrangler Technical Forum 7 04-22-2007 01:40 PM
Extended front sway bar links newbomb TJ Wrangler Technical Forum 5 09-04-2005 08:10 PM
