-   -   How much are sway bar end links extended- 4" lift (http://www.jeepforum.com/forum/f12/how-much-sway-bar-end-links-extended-4-lift-1003791/)
chadroc 04-01-2010 12:16 PM
I have a 4" suspension lift and I'm going to put a sway bar on and will be making extended end links. How long should they be? Is it as simple as making them 4" longer than stock? Seems like that should work, but maybe there's something involved that makes it more complex than what seems odvious?
Thanks!
humbert810 04-01-2010 04:25 PM
If you want I can measure mine from my 4" kit. I never put them on
chadroc 04-01-2010 10:28 PM
That would be great! Thanks!
wrangler76 04-01-2010 11:01 PM
I'd just cut the stock ones and sleeve them with tube... then drill holes for tractor pins and you have a set of disconnects.... The goal is to have the sway bar about parallel to the ground when the suspension is in its neutral position...
humbert810 04-02-2010 01:30 PM
10" center to center.
chadroc 04-03-2010 09:11 AM
thanks for the help guys!
The time now is 02:01 AM.
